Pages: [1] 2 3  All   Go Down
  Print
Author Topic: CMS-GE with CMS-OF and OF2200  (Read 28462 times)
Rob-GB
Offline Offline
« on: July 10, 2010, 02:49 PM »
This is in part a review and in part, a how to!
My recent Festool purchase was posted under Festool, Fixy & Fate! So further to this and prompted by Chris Meggersee, so here we go.
As part of the Festool System way of thinking the CMS set up brings a lot to the party. It is adaptable, robust and good looking. ( Suzy says that describes Clint Eastwood, Eek! well, at least he's got 'wood' in his name Laughing)
Anyway we want pic's so here is the base unit that lets possibilities and imagination run free.
The base unit CMS_GE in its folded position.
End view showing the NVR switch, this one is for the UK site requirements and has plugs/sockets for 110v power.
Cable storage, lazily illustrated.
With legs extended/unfolded it matches the height of the MFT/3. Bottom right of the picture shows the adjustable foot to counteract against uneven floors.
The router table top, laid in place, this is a stunning 7mm thick of high grade aluminium. I even double checked my micrometre, to be sure.
The slotted screws in the above pic relate to the cams (2no). These lock the table down to the CMS base unit.
This router table top, is apparently a new version (it is what I was informed), it now accepts the OF1010, OF1400 and OF2200. So a different table is not required for each model.
How's it done?
Supplied as standard, going clockwise from the left, we get the dark grey centring ring (473810) for the OF1010, the light grey centring ring (473809) for the OF1400
and the Festool green one for the OF2200.
« Last Edit: July 10, 2010, 03:31 PM by Rob-GB » Logged
Problem? No such thing! Only a solution waiting to be found:- RJ
"A $2 guppy swims......" Deke
Rob-GB
Offline Offline
« Reply #1 on: July 10, 2010, 02:49 PM »
From here on we will deal with the OF2200, because that's the one I have.
First, with the table upside down, insert the green centring ring in the table then remove the base plate that is on the router.
Now we need the Protective Cover, I believe this is designed to stop dust getting into the router through the bottom vents. There has been some mention of this as a problem in some threads. Like all the parts it has its part number moulded into it. (473449).
Insert this with the part number readable from this view, and the oval indent over the square 'bolt'.
Rotate clockwise to this point, there is a ratcheting sound and firm stop.
Plunge the router to it's lowest point. Place the router over the centring ring, there is no play in the fit, with the guide post opposite the fine height adjuster side under the cutting depth adjuster. Then install the 'Journal' as it is described. This prevents the router rotating around the centring ring. This Pic shows the position with the journal and small knob.
Journal in position, the 6mm tab into the table for this router.
Tightened up.
Install and tighten the three clamps.
« Last Edit: July 10, 2010, 03:14 PM by Rob-GB » Logged
Rob-GB
Offline Offline
« Reply #2 on: July 10, 2010, 02:50 PM »
Release the router plunge lock, make sure the raise and fall mechanism is engaged.
The operating handle for the mechanism fits above and below the table for ease of use.
Flip the table over, ease the router and rise and fall mechanism into the opening, then connect the far edge( with the cup and round hinging edge) first. When installed give the slotted screws a half turn to lock into place. Looks neat.
Festool supply a range of bushings to cater for a variety of bit radii.
The router table fence, would not be lost on some high end shaper/spindle moulders!
This is a serious bit of kit, it may be ali' but it is weighty ali'.
To aid with adjustment there are metric scales and the table is etched with reference lines either side (at the 41mm mark here).
Also included are the clear plastic 'Shaw Guard' and the dark plastic hold down, both easily adjustable, and lift back out of the way for cutter adjustment/ installation.
The infeed part of the fence has a large indexed knob to allow for a planing action type of cut.
« Last Edit: July 10, 2010, 03:15 PM by Rob-GB » Logged
Rob-GB
Offline Offline
« Reply #3 on: July 10, 2010, 02:50 PM »
The rise and fall handle in the table face position. It takes 14 full turns to go from the lowest to highest setting. The action is smooth and easier than I imagined.
Also included is the guard for use with guided cutters with curved workpieces.
Oh! For those of you who are wondering where to put the handwheel for the rise and fall, any of the rounded or squared keyhole location points will do nicely, the handle stem has been machined to suit.
Thanks for looking in, hope it is of interest or help.
Rob.
P.S. Photo's taken with A Sony Alpha 350, using a 3.5-5.6/18-70 Sony lens and a Cosina 1:3.5-4.5/19-35 Wide angle lens. For those who wish to know.
« Last Edit: July 10, 2010, 03:08 PM by Rob-GB » Logged
Festoolfootstool
Offline Offline
The trouble with Bob is its all about Bob
« Reply #4 on: July 10, 2010, 03:03 PM »
I like the adjustable infeed fence.... can you get infeed/outfeed extension tables for longer work pieces?
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Rob-GB
Offline Offline
« Reply #5 on: July 10, 2010, 03:16 PM »
Yes. and a sliding table with fence. It is a cool bit of kit.
Festoolfootstool
Offline Offline
« Reply #6 on: July 10, 2010, 03:32 PM »
Rob it does look like a very nice bit of kit. I have the trend prt and t11 what I like about that is the router attaches is seconds tool free with no loose parts to lose. but it is not as sofisticated as the festool...
Peter Halle
Global Moderator
Online Online
WWW
« Reply #7 on: July 10, 2010, 03:47 PM »
You can also use the MFT/3 as an infeed or outfeed table.
jonny round boy
Offline Offline
« Reply #8 on: July 10, 2010, 04:16 PM »
And, since it has the 'V' groove, and is the same height as the MFT (and therefore the same height as the Kapex on either the MFT Kapex or the new stand) you can use the new KA-UG Kapex extensions as infeed/outfeed tables, too.
Dontcha just love a system? Big Grin
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - T12 drill - PS420 jigsaw - OFK500 trimmer
WarnerConstCo.
Offline Offline
WWW
« Reply #9 on: July 10, 2010, 05:19 PM »
Man I want one of those.
Dovetail65
Offline Offline
« Reply #10 on: July 10, 2010, 05:39 PM »
When I want a router table I want it set up and not have to take the router out when I need to route by hand.
When I want a table saw I want the table saw  ready to go while still having my circular saw ready to go.
In short I do not think these integrated systems are so great.  I want everything separate ready to go and be used within seconds of each other. I do not want to mess around changing configurations.
The CMS set I don't ever see being such a big item in the US. Personally I want a table saw that weighs something, even if it is a portable saw. I want a better, heavier, smoother, flatter  top than this system offers and as I said I would rather have all separates to make the work flow go smoother. Moving MFT's around is not what I want to do either. Once we set up our job site for a month long job its like a little shop and we set up stations and don't want to mess around changing configurations every-time we need a different tool. I do not cross cut much on a small table saw of the CMS size, but the sliding option does look neat on it the though.
In short I do not think there is a great rush for Festool to get these over here in the USA because most people I know(90% which are in the trades as there primary income) and the general public are not going to buy these. Now on this forum maybe the fans will, but the general public in the US I personally do not think so. Festool seems smart and this may be the most important reason they are not selling them here, they just don't think  they will make enough profit to warrant it. It's a business. If they thought it would make them multi-millions of dollars they would get UL approval in a matter of months or weeks and would be selling them here. Now in this economy even guys that want them may not be able to afford them so most likely we will not see them for a long time, if ever.
« Last Edit: July 10, 2010, 05:52 PM by nickao » Logged
harry_
Offline Offline
« Reply #11 on: July 10, 2010, 05:55 PM »
Just one?
Chris Meggersee
Offline Offline
I'm addicted to Festools.
« Reply #12 on: July 10, 2010, 06:39 PM »
I stand to be corrected here but to my knowledge the Preciso CS isn't in the US either and that would suit your needs perfectly wouldn't it? So then the next question would be "Why aren't they rushing to push the Preciso through to the US?" Most likely it is being held up for the same reason as the CMS.
Also to my knowledge the CMS system (is that not what the "S" stands for in CMS?) is not designed to be a permanent saw or router table. I can see where you are coming from though. I know I would much rather buy the Preciso CS over the CMS and table saw attachment. However the latter would save me about R10 000 and allow me to save space in my shop as I could potentially throw away my table saw and router table. Understand where I am coming from?
To Rob,
Thanks for the review. It is much appreciated. Once you get comfortable with it please let us know what it is like and how you feel about it. Eg Is it very simple to use, is extraction clean and good, are there things you would like to see changed or added?
PS300EQ Jigsaw - OF1010EBQ Router - DF500 Domino - RO125FEQ Sander - C12CE Drill - TS55EBQ Saw - CT22E Dust extractor - DTS400 Sander
Wish List: Anything not listed above in the catalogue.
Corwin
Online Online
« Reply #13 on: July 10, 2010, 06:47 PM »
I think that the CMS system would be a hit here in North American markets if enough of the tool inserts were to also come our way.  I can see how the TS saw and maybe even the jigsaw modules might be a problem getting UL approval here.  Hope this is not the case, but it could go that way, and that may make this CMS fail here as I don't see this being successful if only the router module is available.
To Rob,
Yeah, what Chris said!   Big Grin
Shirt Size:  L
Dovetail65
Offline Offline
« Reply #14 on: July 10, 2010, 07:10 PM »
I just do not buy the UL approval thing at all. If it were that they would change the tools in question  and get it done in a month if they really wanted to. This has been talked about at least 4 years and nothing takes 4 years to get through. So to me it is a business decision. Festool engineers are more than smart enough to make a few quick changes to get UL approval if they wanted to.
I just do not think the American woodworkers in general would be receptive to the idea. And the Preciso CS is exactly the type tool I am talking  about that Americans don't like. It is a light weight system and even advertised as that. Not a heavy sturdy machine like we are used to in the States. It may take a bit longer for Americans to warm up to the lighter weight tools.
We are biased here on Festool forum as we know and love Festool. Still to this day I have never ever been on a job site here in the US where anyone had a Festool and most still never even heard of Festool except me. And the Festools have been here and out quite a while. Most carpenters and woodworkers that I know in the US want bigger heavier machines even if they have to make the laborers lug them around.
I had some carpenters over here last week and showed them some of my shop and they were not impressed by the Festools at all, especially when they asked about cost.
Festool probably knows what they are doing and they may not believe certain tools will make them money here or they would be here. I think once they believe the tools can be profitable for them the tools will get here.
The tools may be a hit here on the Festool forums and for people that already have and/or know Festool. I am not so sure it would be such a hit with carpenters and woodworkers here in the states in general.
IMHO at this point I believe it just has to be about profit, not UL approval.
« Last Edit: July 10, 2010, 07:19 PM by nickao » Logged
EcoFurniture
Offline Offline
WWW
« Reply #15 on: July 10, 2010, 07:44 PM »
Well said! I noticed the same when on site....People ask about it, but as soon as you go into some details, they start laughing and call you stupid for spending sooo much money... At my workplace, I have even been told not to use my Festools in the shop anymore.... Go figure.
Corwin
Online Online
« Reply #16 on: July 10, 2010, 07:46 PM »
In this little corner of the country, none of the above holds true.  Several companies in my little town have nice assortments of Festools.  And I am certain that this CMS would be a hit here -- and the Preciso CS too.
Shirt Size:  L
Dovetail65
Offline Offline
« Reply #17 on: July 10, 2010, 08:19 PM »
Wait a second, I did not say you can't buy them and many stores sell them. I said on real working job sites I have never seen them, that's the difference. If you are in the trades and see them at most jobs then that is surly a minority as most everyone I have talked to on the forums and read about have the same experience I do on actual on sites.
Mostly the guys here are the guys that have Festools on site and that's about it. If the job sites in your area have workers that actually use Festools on site I would be very very surprised. Chicago and the extended suburbs are a pretty big area and I have jobs I see through 5 counties and the city itself, still no Festools on any job sites I have ever seen to date, union and non union.
Who would these be a big hit with on actual job site in the US? The CMS stuff is lightweight and flimsy and I would never bring that to a union job site , it would get ruined for sure. I think maybe the one man show would use the CMS not a crew of guys running around working their asses off, sharing tools, at least not here yet.
The job sites need tough tools that take a beating where guys can share, I just do not see Festool breaking that market in the US for years to come. In Shops maybe, but its big construction that can sell a lot of tools, not the small amount of people here on the forum.
In this economy there is no way a Carpenter is spending anymore money they can with worrying if they are even working tomorrow. I think Festool is smart waiting it out for now.
« Last Edit: July 10, 2010, 08:26 PM by nickao » Logged
PeterK
Online Online
« Reply #18 on: July 10, 2010, 08:40 PM »
I just don't understand the UL thing. How is it that Harbor Freight can have a store section full of crappy electrically operated tools selling for cheap? They seem to have no problem getting UL licensing. How is it that Home Depot can sell hundreds of cheap light fixtures that always seem to be changing versions and they have UL stamp? Are the Chinese the only ones who know how to go through the UL approval system? Dremel constantly changes their power tools, Milwaukee seems to be constantly introducing new tools. Guess you just have to manufacture in China now. Sears is always coming out with revised household vacuums and carpet cleaners with UL stamps. Appliances change frequently requiring updating of their UL stamp. Curious.
Rob-GB
Offline Offline
« Reply #19 on: July 10, 2010, 09:13 PM »
Yeah! Big Grin
My decision, for getting the router table, was influenced by several factors. Firstly, I wanted a router that was better than the Dewalt version of my old Elu 177E. I have both and the Dewalt one is a pain to use. The Festool OF2200 ticked all the right boxes.
 Having been plunged ( Wink ) back into a lot of on site joinery work, due to the economic downturn, I got fed up with making MDF router tables to get out of a fix.
No longer did I have a workshop full of seriously big kit to rely on, what I needed was a workshop that could go with me in my little van. The CMS modular system was an obvious choice, due to it's flexibility in usage options. The advantage of buying one at the same time as the router was fiscal, there is a cost saving when buying a complete set.  Grin
I want to get the TS75 later and a table insert, the TS55 is great but not man enough for tablesaw applications (in my view). (The TS55 is available with a CMS package but not the TS75!) Huh?!
Weight, was another factor. I currently live in an apartment, have no garage or workshop space, so all my kit has to be carried upstairs to our spare room when not required on site. Add in to this mix my back injury woes... well,  weight really is a 'weighty' issue.  Sad
Chris, I will certainly report further as and when I get a chance to put both router and table through an on site workload. This review is thanks to both you and to the Festool kit I used saturday morning, TS55 and Parallel Guides that got a days work done in half the time, so I had time to do this.
Regards Rob
P.S. Any questions, will be answered to the best of my knowledge.
Rob-GB
Offline Offline
« Reply #20 on: July 10, 2010, 09:28 PM »
I remember an earlier post where you mentioned this. At the end of the day you know you have reliable and quality tools, as for being asked not to use them.... jealousy is a green eyed monster! Just not Festool green.  Grin Hope you find a better friendlier place to work soon.
Rob.
WarnerConstCo.
Offline Offline
WWW
« Reply #21 on: July 10, 2010, 11:26 PM »
The CMS with the router was not in any way flimsy.
I personally, would rather have the CMS with the 2200 in it vs. a immobile stand alone shaper.
Trust me, I would like a shaper but, I still like to be portable.
I have laid my hands on the cms and it is one well built tool (item).
Very hand for making tongues and groves for a custom floor install, one-off trim replication on site, and so on.
I rarely do any work in my garage/shop (1400 sq/ft) but, I do like being able to set up quick do the work and then pack it back up and store it in the corner.
harry_
Offline Offline
« Reply #22 on: July 11, 2010, 12:36 AM »
With one exception, the only time I have seen Festool on a job site was when I brought them there. The one exception was a plumber with a C style drill.
I don't know about you Nick, but around here the majority of union carpenters make concrete forms for bridge work. I have yet to meet a union carpenter that does any finish work. I do a lot of my work in metro-Boston and granted it ain't Chicago, but still...
Quote
I would have to agree that the CMS stuff could/would get pretty beat up in a general crew work environment, I do not think that would be the case for finish crews. The finish crews that I have worked on simply had too much respect for everything that they did or touched. Framers on the other hand.......
Quote
Shared tools definitely take more abuse, but a lot depends on the crew. The CMS or any Festool products are not really tools for framers. Finish guys have a much different attitude and It seems to me that the more refined the work, the more refined the worker and as such the better the tools (and everything else) are treated. Big iron is for shops, not for job sites. Job sites need portability and adaptability. and before you head down the road about dedicated tools, it is not about want or not want, it is about able or not able.
Using the CMS as an example. Yes, I think that we would all prefer to have dedicated router tables with motors. However I can only think of a handful of times when I actually needed one on a job site. Having something like a CMS would give me that option. I do not see a CMS as a `production tool`, but more accurately a tool to help me produce. I'll show you my emergency router table in another thread.
Quote
NO ONE wants to spend more than is necessary. Guys are starving out there. Tradesmen (companies) are downsizing. There are no margins for carrying extra people any more. There are fewer laborers to carry that heavy metal you referred to earlier. My Bosch 4000 table saw now sits in my garage for a saw that weighs 1/2 as much. There are also no margins for replacing disposable tools. The downtime alone can be the difference between brand X and a Festool.
I think Festool waiting it out is a double edged sword. Now is the time when guys in the trades are trying to adapt to a changing marketplace. I think that many if not all of the NAINA products couldprovide a means to that end.
I will agree, in part, to your earlier post about it might take time to for Americans to warm up to the idea(s) of.....
Nigel
Offline Offline
« Reply #23 on: July 11, 2010, 02:57 AM »
          There's a lot of interesting points in this thread.I have the cms/OF 1400/ts75.
 Nickao you make some valid points.
 It's definitely not flimsy  but having said that I agree that I wouldn't let a crew use it.Like you say it would get ruined.I see it as a tool for a one man band.I don't think it's aimed at large company use.
 I would'nt like having a single circ saw ts75 to take out of the cms for handheld everytime,it would be a right pain.I have the ts55 for that but  the 75 is very useful occasionally for thicker timber or long cuts in oak for example when the 55 will trip out.
 As for weight,well since I got the cms my heavy site saw just doesn't get used anymore,same for my old router table [waiting for someone to take it away].I don't miss the weight of either of them.
 Another strange thing is that although I have 4 routers I now only really use one!Doesn't matter if it's in the module I'll take 2 mins to take it out.I think it's worth the small effort.The of1400 is very quick to install in and out of the module.On site you can have handheld and table mounted and change between the two very rapidly.
 It all depends on what space/workshop/vehicle you have.Like Rob-GB I have a little van and some of the sites I work on are compact.No room for separates.
In the US you probably have much more space?Perhaps there are areas with small sites though.This is where the cms is unique and unbeatable.There simply is nothing to compare for portability,versatility and accuracy.
 For the cost,well I reckon all would agree it's expensive but then Festool are not famous for cheap tools.
« Last Edit: September 29, 2011, 01:11 AM by Nigel » Logged
danjames
Offline Offline
« Reply #24 on: July 11, 2010, 04:19 AM »
Nigel,
You hit the nail right on the head, I am a boat builder and space is always very tight on a boat, I run the same set up as you - cms, ts75, of1400, and I always work on my own, it is the best set up that I have had to date, the saw is the most time consuming tool to take in  and out, but once you have done it a few times it is easy and not to slow, but as you say just leave it in there and use the 55 for all other cuts except for all but the deepest - hardest cuts.
Dan.
jmbfestool
Offline Offline
« Reply #25 on: July 11, 2010, 05:44 AM »
The Kapex MFT table ISNT the same height its taller than the rest of the MFT tables. So the UG-kepx extensions arms dont fit on the Kapex MFT table I tried cus I own both.
Any way Im glad I found this topic because I am buying  the CMS-GE and CMS-OF this monday I was going to order it friday just gone but I had to think about its over the weekend because I gotta buy a core drill and Core drill cutter set  and I am thinking of buying MFT 3 bench but I have seen the MFT 3 VL GB now that only has two legs and attaches to the MFT3  so it would replace the CMS-GE
I dont know which to buy. Any help?!?!?
Nigel
Offline Offline
« Reply #26 on: July 11, 2010, 06:27 AM »
        jmb,
 I wouldn't go for the MFT 3 VL myself for site work cos you always have to have the mft3 with you.A right pain to have to set it all up just to rip a piece of wood.Different for  constant workshop use though.
  Incidentally I would recommend to you and ROB GB to get the sliding table as I reckon it's a gem.Very light and quick to attach with 2 thumbscrews.You can also lock it as a little extension table to increase ripping capacity,the standard base being a bit shy on that score.
       Dan,
    I agree the saw being the most time consuming especially if you change the riving knife which I find awkward.I also cut that wire off that holds the depth arm to the module!Just could not get on with it...As for swapping the modules after a few goes it gets a lot quicker.
jonny round boy
Offline Offline
« Reply #27 on: July 11, 2010, 07:17 AM »
The MFT Kapex is shorter than the MFT3, not taller. And, what I said was:
They are all the same height, 900mm.
Michael_MA
Offline Offline
« Reply #28 on: July 11, 2010, 07:33 AM »
Congrats Rob, on a very good choice !
Very nice review of a great Set.
I can completly understand your decision for the CMS system. I also dont like to carry heavy equipment around and try to be as flexible as possible without loosing options. I've got the OF2200 as well, but standalone in the Kit Version without the CMS. I'm stiil using the OF1010 for small application in my former Basis 1A (former CMS system)  table in change with an ATF55 plunge saw.
A table Router does not have to be tons in weight to be called sturdy and robust. I fact, it is much more sturdy than lot of table Router on the market today. I have seen quite a few made out of sheet metal in very light constructions and without molded Aluminium parts. So not only consists the CMS of molded Aluminium parts, they are also in forged quality because Festool uses high quality die-cast processes. The only thing, which i had had some hassle with my older system was the change of the router and Plunge saw.. the insets itself are quicly changeable, but the tools in the inlets not. so this is the reason, why i have additonal the OF1400 for hand work, the OF220 for tough work, and a TS55 for cutting sheet goods with different rails.
Would be great, if you give us little more insight on the usage of the CMS OF2200 and your experience..
kind regards, Mike
« Last Edit: July 11, 2010, 09:03 AM by Michael_MA » Logged
"..The only thing necessary for the triumph of evil is for good men to do nothing.."
                       - Edmund Burke, British Statesman and Philosopher -
Festool addicted since 2004
danjames
Offline Offline
« Reply #29 on: July 11, 2010, 08:49 AM »
JMB,
I had the same dilemma when I had to decide what way to go, as in should the module be attached to my mft3 or not.
In the end I got the VL which is attached, I figured that I have always got my MFT with me ( I can't do much without a work bench on the job ), so with the VL it can also be an extension of the MFT and with the MFT right next to the VL I can rip-cut much wider pieces of timber as I attach the fence to the front edge of the MFT, I did not want to be limited to cutting up to only 180 mm or whatever it is.
I use two fences, for normal ripping I use the dedicated ripping fence I think it is the CL70, this is  attached to the VL module and when I need to cut something that is wider than the module I use fence that comes with the unit, that is the protractor head and ali fence, set at 90 degrees but calibrated to my saw blade in the VL unit so that it is parallel and then I measure to the sawblade to establish the width, and clamp the far end of the fence down to stop it moving.
For me this has been a good thing and allows me to use the module not just for small rip cuts it is like having a bed extention to the saw, I hope that this is understandable.
Thanks - Dan. Smile
Pages: [1] 2 3  All   Go Up
  Print
Jump to:
