« Reply #10 on: August 28, 2018, 09:47 AM »
Peter: I agree with you.
The two products are “aimed” at two different market segments.
Ergo... Though they invariably will be compared - It’ll be an “apples and oranges” comparison.
One needs to view Festool’s new Separator in light of Festool’s continuing business model and market focus - Which is primarily the “on site” tradesman.
The entirety of their product line has always been dedicated to “portability” (even the fold-up MFT’s).
The “woodworking” segment of the tool business is minor in comparison to the potential/actual construction trade segment.
Given that consideration, neat as their new Separator is, other than the space saving “stackability” atop a Festool Dust Extractor - I, as a “workshop” woodworker - Won’t be inclined to trade my Dust Deputies in for this new product, neat as it apparently seems to be.
Were I an “on site” tradesman - Moving my tools/equipment about regularly - I be “chomping at the bit”, awaiting its availability.
« Last Edit: August 28, 2018, 10:03 AM by Joe Felchlin »
FESTOOL: CT26 and CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides and Extensions, OF1400 EQ Plunge Router, OF1010 EQ Plunge Router, HL 850 Planer, RO125 FEQ Rotex Sander, LS 130 EQ Linear Detail Sander, DX93E Detail Sander, C12 Cordless Drill, CXS Cordless Compact Drill Driver, SYS-Centrotec-Set, Domino XL DF 700 EQ Plus Tenon Joiner Set, Domino DF 500 Tenon Joiner | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIGS: D4R 24 Pro Dovetail Jig, FMT Pro Mortise & Tenon Jig | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
