I purchased the HSK 80 x 130 Hand Sanding Block (496962) thinking that a block with DC could be handy even around the shop. I have become so accustomed to not having dust in the air when sanding that I now even notice it from small hand sanding jobs. Even from just cleaning up board edges. The 80 x 130 seemed like the size to get since it is about the size of most traditional blocks. It also uses the same abrasive sheets as the LS130 (which I already had) and the RTS400.
I also got two different hoses to use with it. One Anti - Static (456745) and one Non- AS (495019).
The block is a nice size with a well shaped grip.
In some ways this review is more about the hoses than the sanding block. Suffice to say that the block sands as it should
![Smile [smile]](http://festoolownersgroup.com/Smileys/default/smile.gif)
This picture shows the D27 , D22 AS, and D21.5 (D22) non-AS hoses side by side. The block can be used with any of these. There is a significant difference in outside diameter of the D27 and the D21.5 as can be seen in these pictures.
The non-AS 21.5 can be attached directly to the sanding block air control fitting as shown in the first picture above.
The D27 and D22 use a rubber downsizing adapter to allow the regular hose connection to fit the block port. The AS D22 could be attached directly but the fitting is loose in the hose and would need to be built up with a couple wraps of tape.
The best hose to use with the block is the D21.5 non-AS. It is really light weight and super flexible. It hardly was a hindrance at all. The following two pictures are to show the flexibility. One thing to note is that this hose does not come with any tool end connector. The connector comes with the sanding block, and has a suction let off built in. I found that it worked well about half way open with the vac (CT33) set to about 2/3 power. This hose is very light weight and thin walled is obviously intended for use with the sanding blocks. I would not expect it to hold up well to a lot of abuse such as crushing or being folded into a crease / kink. I am not going to test its durability to the breaking point. It should be fine for its intended use.
The D27 is OK in a pinch but quite clunky with the regular hose connector, not real flexible and really too heavy.
The D22 AS is just about as clunky and heavy feeling on the block. It is a little more flexible. This is an interesting hose in that at the vac end it starts out as a D27 and gradually tapers to the D22 at the tool end. I actually think this might be a good hose to use with jig saws.
Here are a couple in use shots. It was nice to be able to give a light hand sanding between coats of laquer on this piece without having laquer dust in the air.
It can also be used very nicely with interface pads for roundovers and such.
