Author Topic: HSK 80 x 130 Hand Sanding Block and hoses  (Read 92940 times)
Offline andreasg
Re: HSK 80 x 130 Hand Sanding Block and hoses
« Reply #90 on: October 19, 2015, 01:06 PM »
Not sure what I did wrong with my last post, but my comment was "hidden" inside the quote. Here it is:
Anyone tried this lightweight hose for electric sanders? We´re told to turn down suction to halv anyway. Just curiuos, since often the weight of the hose "messes up" the balance of some of the tools. And just got a reminder of this issue since I´m gonna give my ceilings a small "rub" with a sander before painting. Don´t have the 150 ec ets yet, but it´s probably next:) It´s a light one, but up on a chair with 8 feet of hose in the air, that changes a little.
Offline Magpal
« Reply #91 on: October 20, 2015, 04:24 AM »
Yes the holes will line up with, because they both use the same sandpaper.
But you'll also need the spring load mechanism of the LS130 base plate (490302).
(Attachment Link)
Thanks for the picture! The modification looks plausible, but it may not be worth it price wice compared to just buying the LS130 (okay, it is way more expensive, but at least you then get a proper tool).
Offline SRSemenza
« Reply #92 on: October 21, 2015, 12:26 AM »
      If thinking of using the gray hose ( super light) with power sanders remember that it is not anti-static.  Might be  an issue / might not.
Online leakyroof
« Reply #93 on: October 21, 2015, 08:38 PM »
. Good point... [cool]
Offline PreferrablyWood
« Reply #94 on: October 28, 2015, 04:37 PM »
I'm thinking of making my own HSK 93 X 175 using a stick fix pad for the RS 300 EQ, my abrasives are all for this sander and I'm not interested in getting the 80 x130 size. I would make the bulbous top piece out of wood, and the suction section out of some suitable plastic material. The only thing missing would be the valve for controlling airflow.. that wouldn't be hard to rig up..
So I'd just need to buy the Stickfix pad, 21.5mm hose some wood for the "handle" material for the suction section and the valve. It won't be cheaper to make than buying the Festool block but will save me a bundle in abrasives..
RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline mike_aa
« Reply #95 on: April 10, 2016, 09:40 PM »
@SRSemenza
Resurrecting this old thread.  Based on your earlier review I finally pulled the trigger on the 21.5 hose and the HSK sanding block to go with it.  Seth, I was wondering if you are still finding yours useful and if you have any new insights.
Thanks, Mike A.
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #96 on: April 10, 2016, 09:44 PM »
Not Seth---but I love my HSK and 21.5 hose.
Offline SRSemenza
« Reply #97 on: April 11, 2016, 10:11 AM »
Yes, I still use it. In my usage I would call it an occasional tool. But just the right thing for some jobs. Nothing new to add though.
Offline JimSpence
« Reply #98 on: April 11, 2016, 09:27 PM »
Used mine today to knock down filler I had put in plywood voids I filled during the machine sanding phase.  All tools were put away and I was ready to start priming , and then saw these patches.  It was so easy to grab the HSK, with the long flexible hose and take care them.  Dust extraction is not perfect, but much better than old school.  Hobbyist here.  No regrets.
TS55, DF500, OF1010, Carvex, Vecturo, C15, CXS, RAS115, ETC EC 125, RO90, CT 26
Offline BMAC
  • BMAC Construction & Consulting Ltd.
« Reply #99 on: April 12, 2016, 12:34 AM »
I use mine on flood repair projects and did so today to sand down the drydex (sparkle) filler I used to fill/smooth out new MDF casings mitre joints, after I glued the mitre joints with 2P10 adhesive.
Makes for quick work and minimizes dust contamination to the work area (not 100% and that's okay as flooring has been disposed of)
Bruce
Support services for the Fire and Flood Restoration Industry. Specializing in custom cabinetry restoration and millwork.
Offline mike_aa
« Reply #100 on: April 12, 2016, 11:57 AM »
Thanks to Seth and all of you who answered my question.  I plan on trying it instead of the RTS400 to sand a few small drywall ceiling patches to see how well that works.  It looks like I'll be finding lots of other uses for it down the road.
Mike A.
Offline Duck76
« Reply #101 on: April 16, 2016, 12:34 PM »
I grabbed one to sand some drywall touch ups while repainting our bedroom. Kept everything nice and tidy. Even the wife thought it was great!
Offline RKA
« Reply #102 on: April 16, 2016, 01:07 PM »
I added the interface pad for blending patches into the surrounding wall.  The set up works great for the smaller stuff.  Most of the mess is either contained or falls straight down rather than floating across the house. Love the small hose Seth recommended too, very light and flexible with more than enough length to allow me to work my way around a bedroom without having to reposition the extractor.
-Raj
Offline JimD
« Reply #103 on: April 23, 2016, 08:03 PM »
Instead of a smaller hose, I like to use a router speed control on my rigid shop vac when using my little Festool hand sander.  Works great.  My dust deputy gets most of the dust but the key thing is the dust doesn't go all over.
Offline w802h
« Reply #104 on: April 23, 2016, 08:19 PM »
In a pinch a 6 inch disk and a hole punch will cover almost all the bottom.  Sometimes there's a grit that I want that's "outside the box"
Offline Magpal
« Reply #105 on: April 24, 2016, 02:23 PM »
Seth,  great review especially the hose durability test. I'm alittle shocked you haven't made block sander and hose /accessories  fit neatly into systainer. What size sys would it all fit into?
Well hey now, look at that. A Sys- II holds the 5m hose perfectly  [big grin]
I may not keep it in a Systainer. I want this to be handy so it will probably be kept hanging near the vac , ready to use.
(Attachment Link)
And the attic  compartments will hold the 80 x 130 abrasives just right  [cool]
(Attachment Link)       (Attachment Link)
Do you think it would be possible to use a SYS-I for the hose or would that be way to tight?
Offline JimSpence
« Reply #106 on: April 26, 2016, 10:20 AM »
SYS-1 will be too tight.  I tried putting the 21.5mm hose and HSK-80-130 sanding block in a SYS-1, but had to move up to SYS-2.
Have a picture to illustrate, but the attachment is failing.
Offline JimSpence
« Reply #107 on: April 26, 2016, 10:27 AM »
Once more...with feeling:
HSK 80-130 with 21.5mm hose in a SYS-1.
So yes, it's too tight.  SYS-2, on the other hand, will hold it comfortably,and is easy to pack-up.
« Last Edit: April 26, 2016, 10:33 AM by JimSpence »
Offline Magpal
« Reply #108 on: April 26, 2016, 01:18 PM »
Great, thanks for trying it out @JimSpence[smile] I will probably go for the SYS-II with lid compartments then.
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #109 on: June 19, 2016, 01:05 AM »
I ended up putting my 21.5mm hose, and both my 80mm-130mm and 115mm-226mm hand sanding blocks into my empty SYS-3, that my 3.5m sleeved hose came in.  Still room for a small supply of abrasives as well.
Thank you Seth for starting this incredibly helpful thread on the Festool hand sanding system.   As of today, this thread has 42,249 views, and counting!
« Last Edit: June 19, 2016, 01:10 AM by McNally Family »
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline nycwoodworker
« Reply #110 on: January 04, 2018, 11:03 PM »
Reviving this old thread as it's incredibly useful for what I'm looking at!  The main reason I'm looking to use this is to keep dust from sanding between Primer/Paint coats (SW KA+).
For those who used it, I have a couple questions
1) Do you think that I'll still need to go over this with a microfiber cloth if I use the vaccum attached hand sander or would that be enough?
2) Would the suction, turned all way down on Midi and port open on this cause too much suction for a sanding between paint coats?
3) Is this as helpful on normal woodworking projects or mostly other uses?
Thanks everyone!!!
Offline SRSemenza
« Reply #111 on: January 04, 2018, 11:29 PM »
Thanks everyone!!!
I don't know specifically on that paint. But the suction as you describe should be fine. I do think you will still need to vacuum or otherwise go over the piece again to be sure you get as much  dust as possible off the surface.
« Reply #112 on: January 04, 2018, 11:38 PM »
Thanks everyone!!!
After using the hand sanding blocks, I go over the sanded piece with this:
https://festools-online.com/498527-festool-nozzle-universal-brush-ct.html
I also think it could not hurt to use your microfiber cloth just to make sure you get all the dust.
Online rst
« Reply #113 on: January 05, 2018, 07:21 AM »
I use the vac sanding block, brush and then always use a tack cloth.
Offline CBRacerX
« Reply #114 on: June 23, 2018, 08:22 PM »
Thanks for this useful thread. I just got two HSK blocks and ordered the light and easy hose. Let the occasional drywall sanding begin!
Offline Kodi Crescent
« Reply #115 on: June 25, 2018, 09:48 AM »
I use this exclusively for drywall; it's indispensable for sanding drywall.  When I speak to others about drywall repair, I forget how much I take these tools for granted.
