Author Topic: Loving the Carvex  (Read 13398 times)
Offline Svar
Re: Loving the Carvex
« Reply #30 on: May 03, 2018, 04:08 PM »
Having used a TS55 (owned), TS75 (still own) and the MT55cc (own) I can tell you the Mafell falls somewhere between the TS55 and TS75 in terms of perceived cutting power. The MT55cc has never bogged down on me whereas the TS55 did.
That is partially because MT55 has 1.8 mm blade, while TS55 has 2.2 mm. A ~20% difference.
« Reply #31 on: May 03, 2018, 04:35 PM »
Possibly using an HKC blade on a TS 55 would help the down on power problem.
Offline MAK
« Reply #32 on: May 09, 2018, 01:56 PM »
I have refrained for a long time before saying anything about my carvex.  Don't get me wrong my van is full of festool and I love the tools and had them for many years, but the carvex drives me mad.
I've had the 400 had repaired replaced, then got the 420 and had it repaired twice  replaced then repaired and it's gone again.
Blade always falling out foot coming loose now the light stays on all the time. I've spoken to festool and rep several times.
I think it's rubbish and poor quality.
I had a Makita before and never any issues.
I've lost all hope with it ( not with other festool stuff)
Just waiting for a better one to come along or wait for a mafell battery powered one to come soon.
Kapex & UG, TSR55, MFT3, OF1400, C15, CXS, Carvex, Midi, T18, EHL65
Rts400, CTL26, TSC55,  BHC18
Offline yetihunter
« Reply #33 on: May 10, 2018, 10:37 PM »
For most of the time I've owned the Carvex, it has been an out of adjustment, blade-rattling POS. I'll put it and both of my Trions up for sale for $25 each to help finance a good jigsaw.... the Mafell methinks
Yikes! Anyway, the P1CC is seriously a beast.  I've done cuts with fine blades with zero pendulum action that other machines would require setting 3 and a rough blade.   It's a timber framing tool, though, so I would expect that power (and with great power comes great heat).
I'm sure you know all of the good news, so I'll mention a few gripes/growing pains so that they don't catch you by surprise.
You have to lock the foot, foots, feet, footsies beyond the point where you think you're breaking the lever/catch to secure it.  Otherwise, it will come loose and that beast will dance and then come flying at the operator.   Obviously, once the operator knows this, it is no longer an issue.
It gets EXTREMELY hot and fast.  That's the caveat of being extreme, I suppose.
The caveat of barrel grips is that your hand is meant to be precisely on the hottest point.
The angle foot can be annoying.  It bevels one direction, so you have a 50/50 chance of putting the foot on the wrong side and then having to take it off, turn it around, and put it on again.
Internally, the logic board is not mechanically secured.  It's supposed to be a friction fit between plastic (no screws), but it's generally floating a bit.  The speed adjustment is definitely floating, and flimsey.
It does what it's supposed to do, though.
The P1cc is a jigsaw and not a timber framing tool. Mafell has these, but they are not jig saws by any stretch. I have a P1cc and have had a Trion and Carvex. I bought the Carvex to replace the Trion that had reached its end of life. It was a complete disappointment that pushed me toward the P1cc. I think I would have been just as happy with another Trion, but that said I am not at all disappointed with the P1cc and like that it works with the Mafell rails. Mine has never gotten extremely hot as you describe, but definitely has been warmer than one might expect. The foot and latch are non-issues that never affected me and I have never had a problem attaching the foot or having it come loose. That might be because I took a few minutes looking it over before using it. As for the logic board I don't see how this is an issue. I've never heard of it causing any problems. The P1cc is a well-built tool that has a long life ahead of it.
I was being playful and cheeky.  I love my P1cc.
Re: Loving the Carvex...Carvex, Trion & Mafell Dust Comparison.
« Reply #34 on: June 03, 2019, 11:31 AM »
Thinking about this further, maybe I should run a quick comparison of a Trion, a Carvex and a Mafell. I’d probably use the same new Trion blade on all 3 saws.
A dust removal comparison will be interesting.
That would be cool if you did that. Interesting too...
Hey @leakyroof
Yesterday I was cleaning up the Carvex & Trion so I could put them down the road. Then I remembered this thread from last year and decided to run a quick comparison of dust collection between them and the Mafell P1 cc.
Some standards were set:
1. A new Festool Trion S 75/4 FSG blade was used on each saw.
2. No orbital action was used.
3. All 3 saws were set to approximately the same speed.
4. No chip guard was used.
5. A triggered CT 22 on max suction was used on each saw, that way the length of time the vac was on was approximately equal.
6. A scrap 7" wide piece of 3/4" ply was used.
Carvex photos 1-3, Trion photos 4-6 & Mafell photos 7-9. The stunner is when you compare photos 2, 5, & 8 to each other. There's a channel inside of the base of the Mafell that blows the chips across to the extraction point on the other side. Photo 8 says it all.
Interestingly enough, the Carvex leaves the most amount of dust on the cutting surface while the Trion leaves the most dust on the floor. Also, the area of dust on the floor is similar between the Carvex & Trion.
« Last Edit: June 04, 2019, 12:48 PM by Cheese »
Offline ScotF
« Reply #35 on: June 03, 2019, 11:55 AM »
Yep. DC is good on the P1CC. You can feel it just running the saw with no extractor hooked up. I think this could work with a dust bag if one had the desire to hook it up.
The Mafell is great all around. But, Mafell has some duds too...I broke my first P1CC as the needle bearing broke. It was an easy fix by Timberwolf and now my old saw is/was there demo saw as mine was covered in warranty and they just got me a new machine. It is a jigsaw...a great one in my opinion, but my first one did break...so not impervious.
Offline Svar
« Reply #36 on: June 03, 2019, 02:20 PM »
So, the amount of dust on the floor is about the same (+/- 20%) for all saws. Makes no difference for cleanup. What am I missing?
« Reply #37 on: June 03, 2019, 07:37 PM »
This thread first appeared at the same time as another thread that was questioning how efficient the DC was on a jig saw. In particular, the OP wanted to compare the Carvex, Trion & Mafell. I tried to locate that thread but no luck.
Also of interest to several individuals, was is it better for the saw to have a small blower to clear the cut line or was it better to try to vacuum up the dust.
Well, the Mafell has both and it’s quite obvious that the cut line is kept scrupulously clean with that arrangement.
Photo #8 is just pretty darn impressive. I think I counted 10 pieces of dust.
So Svar...what am I missing?
« Last Edit: June 04, 2019, 12:51 PM by Cheese »
Offline TXFIVEO
« Reply #38 on: June 12, 2019, 02:31 PM »
I used a cheap Black and Decker jigsaw for quite some time with stellar results.  The Carvex has done everything I’ve needed it to do and then some.  Over reliance on a tool isn’t a reason to not like a tool.  It’s the hands operating the tool more often than not.
