Author Topic: Maxi Systainer Review - What Festool doesn’t say that could change your life!  (Read 28233 times)
Offline Steve R
I never use to buy tools because of how they were packaged, then I met Festool.
Like most, I purchased my first Festools because of their quality and what they can do. I liked that they came in case as I work on location and getting everything there and back safely is important. But they did seem a bit boxy and I wondered if they would hold up to Minnesota weather. A swing of 142 degrees Fahrenheit (– 37 to 105) at my house.
I don’t know when it happens but soon you see that the Systainers are not just a box, but a system to organize, protect and transport your tools in a very effective manner. You soon find yourself looking at your other tools and thinking…. “Why don’t my DeWalt drill cases stack and lock together…. Hmmmm what rube can I sell them too and buy Festool drills so my stacks match”.
I have purchased a few more systainer to put some other tools in but I have only purchased more of the systainer I already have as I can test other tools in them and know what will and won’t fit it them fit in them. I wanted to go larger
The Festool catalog is never far away but it doesn’t show the accessories and what they really do.  Coming from a marketing background I would call the Festool catalog more of a product list. It doesn’t how tell or show interior size with any useful reference.
I have larger tools that I have wanted to put in a systainer for a long time but. I have been stopped from doing that has for two reasons. One, my local dealer doesn’t have them in stock. Two the catalog and webs site says… “MAXI Systainers have a larger footprint and do not connect to regular Systainers, Sortainers or CT Dust Extractors.”
Well I ordered one and want to prove to you that, that statement is not fully correct.
It is correct that they are too big to fit on top of the CTs
Old style 1 – 5 Systainers will fit on top of the MAXI   Systainer and you can go as tall as you want.
You can also put at least one layer of new style systainer I need a few new style so I could test.
List of images
001 Note the classic closing latches and folding latches on top in the middle front and back.
48556-0
002 How big is a MAXI I wanted to protect a new framing gun you can an idea of depth. Note I have not padded the box yet.
48558-1
003 Looking straight down in the manual is 8.5” x 11” so you see how big it is
48560-2
004 Back view note white latches
48562-3
005 Right side
48564-4
006 Left side
48566-5
007 You carry it like a suit case not from the top. So make sure you pad and secure whatever you put in it as it is going to get tossed around when you flip it over.
48568-6
008 This images shows the latches up as they would be used to attach more boxes on top. The four corner latches are put in place after you place a systainer on top.
48570-7
009 This is how the middle latch works the Standard Systainer’s front pegs slide in.
48572-8
010 This shows the Systainer fully in place
48574-9
011 The front and back latch on the MAXI locks to the side pegs of the normal systainer
48576-10
012 The center latches are deep enough on the MAXI to hold two Systainers
48578-11
013 If you use the same size systainer on the other side this is what you get
48580-12
014 If you want another layer you need to put the normal Systainers front latches all the way up before you load the next layer
48582-13
015 The latches act as the MAXI center latches
48584-14
016 How the second layer connects
48586-15
017  Add one more
48588-16
018 I find picking up the whole stack with two handles easier than having four in one hand and the MAXI in the other.
48590-17
Cheers,
Steve
Offline leakyroof
Nice review Steve. I own 1 Maxi that holds my Shinex and all of its assorted polishing items. My local dealer pointed all of your info when I was buying the thing, which was great as you already know you own a rare bird in the Systainer world once you've bought a Maxi-Sys.
 I knew nothing about them at the time of my purchase, so thanks for taking all of these great pictures.
 I bought the honeycomb foam insert to keep my Shinex from bouncing around inside the Maxi-Sys.
Offline SRSemenza
Steve,
Nice review.
 I don't have any MAXI Sys, mostly because of the way they carry.  As individual units, the side handle means that everything gets tipped / tumbled.  How about a pic of how you carry the twin handle  stack. I always imagined it to be very awkward to do.
Offline Steve R
Steve,
Nice review.
Look at image 018 and read the caption.  [poke] it is very easy to carry.
Seth you do need to pad and pack it right or you are going to bang up tools if you use the side handle.
One other point I didn't make in the review is that with a Two wheel cart that goes down to a 4 wheel that I use to get into condos. You can place the MAXI the the wide way it and it will still go through a doorway. I have yet to measure but I think I can get 3 MAXIs on my cart that I use. If I can, that would give me room for 6 stacks of tools and if done level a very easy way and safe way to carry a Kpex and/or or the CT on top.
Cheers,
Steve
Offline DKurzweil
Steve,
I do not own a maxi, but by looking at your pictures I would say you can stack multiple t-locs.
Here are the steps I would take:
1.  make a stack of t-locs
2.  lock them together as a single unit
3.  place the stack on the maxi as if it were a single systainer.
Can anyone confirm what I just said.  As I stated I do not own a maxi but by the looks of it this method would work.
Great review and pictures.
Best,
Daniel
« Last Edit: March 06, 2012, 03:54 PM by DKurzweil »
Addiction includes TS75, OF1010, Domino 500, RO150, T-18 set, CSX, LR-32 set, CT48 and CTMidi
Offline Steve R
Steve,
Best,
Daniel
Daniel, I think you are correct and hope to from others also.
Also if you want to mix "T" locks and "Classic" you would need to put the "Classic" below any "T" locks.
Cheers,
Steve
Offline SRSemenza
Yes,  this is carry by the handles in two hands holding in front of you?
Of course, some things can take a lot of lid foam or immobilising foam  etc. to keep them in place. I just like the fact that the regular top handle design lets everything just be  in place. One of the things that I really like about the Systainer design compared to other tool cases.
That sounds like a great plan for moving everything! Could even put a MFT/Kapex on  top of the stack and the Kapex on top of that.
Offline Steve R
Yes, out in front
Cheers,
Steve
Offline BJM9818
I have 6 Maxi-Systainers.  Two are Festool and the rest are Tanos.  I like the handle and feel of the Tanos much better.  They are great for organizing a bunch of non Festool related stuff and stack easily(side handle up) on the shelves in my shop.
Offline rookie08
BJM
Thinking about getting a couple of those for a cordless set (circ saw, sawzall, impact driver etc for when I's somewhere I don't have access t power.  Do you have pics by any chance?  Do you know how tall they are inside?  Are the Tanos larger?
Thanks!
Offline Steve R
These images might help show size. Baseline is you need to try one at your dealer to know if things will fit for sure.
019 6.75 to 7.25 inches tall
48614-0
020 22 inch wide at the narrowest points
48616-1
021 13.5 inches Front to back
48618-2
022 Framing gun and full sized sawzall
48620-3
023 Framing gun, full sized sawzall and full sized hammer drill
48622-4
Cheers,
Steve
Offline BJM9818
BJM
Thanks!
They are exactly the same size as the Festool ones, I just like the handle better.  I think they have a few edges that are a little more rounded than the Festool ones???  Who knows but I think they just feel/fit much nicer.
 I use my two Festool ones to keep spare boxes of sandpaper and vac bags in as well as other misc stuff.  THe others I have Vacuum bagging accessories in one, epoxy supplies in another and so on. I'm rebuilding a boat and needed something other than the black bins with the yellow tops I had from HD/Lowes.  I was getting sick of always wanting the one that was on the bottom of the stack.
For cordless tools, If you have the same brand tools I would see if you can get the large empty case on ebay that comes with a multi tool kit.  I know DeWalt has one that holds 5+ tools I think.  Due to their size and price if you have a drill/impact/sawzall/circ saw there is no way you could fit everything in one Maxi if you are concerned with them ratteling around .  At that point I think it would be easier and a lot cheaper to buy the manufactures tool case. You also dont have to be as careful with those cases than the systainers.   I think the best you could fit into a Maxi with a foam insert would be a Impact/drill/sawzall along with an assortment of blade/bit cases.  I don't think my Makita cordless 6" saw would fit in one.
Offline rookie08
Thanks for the responses and the pics.  I think the biggest obstacle is the circular saw.  Maybe I'll have to break it into a Maxi and a regular.  And the stack grows!  [scared]
Cheers
James
Offline duburban
if there was an easy way to cleanly foam things in place i'd be in. maybe the cloth and spray foam trick would work well for this. i'd like to see my makita LXT tools in there. 2 drills, 2 impacts, saw, light, 2 chargers and 5 batteries.
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline TomGadwa1
One method for doing this is called foam in place. The way to do this is to bag the tool in a polyvinyl bag to keep the foam from attaching to and harming the tool. The tool is then placed into a slightly oversized box. Now spray some of the expanding foam into the bottom of the box. Before the foam hardens completely set the bagged tool onto the bottom layer of foam. Now spray the foam around the rest of the voids in the box. Next after the foam has cured the box can be cut into two halves such that the tool can be removed. This way even shipping companies have to work extra hard to destroy the contents packed in this manner!
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Offline leakyroof
The Planex is arriving in a larger than normal Maxi Systainer.  When I put my Maxi-Sys next to it, or on top of the Planex box, it's easy to see the larger width and height of the Planex Sys. Is this a Maxi 2 Systainer.  Note, I tried to post a picture of this taken with my iPhone4, but was unable to edit it small enough to be accepted.
Offline Steve R
Hope you can find a way to show a side by side image! That will help the rest of us know how that could fit into our tool organization plans.
Cheers,
Steve
Offline leakyroof
Cheers,
Steve
  I'll ask my local dealer, who has the tool, to post a pic if they can
Offline duburban
wow, thats a really great idea.
Offline Tom Bellemare
  • Inactive Member
    • Tool Home LLC
Cheers,
Steve
The Planex comes in a regular Maxi Systainer with a custom insert to hold the goods. Just like the one mentioned in this thread.
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline Steve R
Tom,
Thanks for the verification of it being a MAXI Systainer  Now we just need to know what Leakyroof is calling a Maxi-Sys?
Offline woodworldchicago
  • Festool Dealer
  • Chicagoland's Most Complete Festool Dealer
    • Wood World
48711-0
Planex on the left (210mm height), Leakyroof's empty Maxi on the right (157.5mm height). According to the Tanos web site the 210mm is a Maxi III & the 157.5mm is a Maxi II. Festool USA catalog lists the height of the Maxi as 210mm.
Chip
Wood World Hardwood Center
2460 W George St - Chicago, IL 60618
773.267.3800 - festool@woodworld.com
Offline Steve R
(Attachment Link)
Chip
The MAXI I have is 210 and the images I first posted show that. I now have to look at the Festool Site to check if anything has changed....   as I was under the understanding that there was only one Festool MAXI...
More as I learn it.
Cheers,
Steve
Edited for grammar
« Last Edit: March 09, 2012, 04:56 PM by Steve R »
  • Inactive Member
    • Tool Home LLC
Steve:
I just compared an empty Festool Maxi Systainer to a Maxi holding a Planex and they are the same, 210 mm.
I have no idea where the Festool Shorti Maxi pictured above came from. I'm extremely interested, however...
Is this possibly a Latchi Switcherooni?
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline leakyroof
Steve:
  Leakyroof here, owner of the Maxi 2.  Apparently I own a Maxi 2, and the Planex comes in a Maxi 3.  Maxi 3 is also available by itself through Festool. My Maxi 2 seems to no longer be offered by Festool,but is available through Tanos dealer network.  See what DUST we all kicked up with this thread  [big grin] [big grin] [big grin] [embarassed]
 My local dealer, the one I bought both my Maxi Sys and my Shinex from, doesn't know how long this "Shorty" Maxi as you're calling it was sitting on their shelf before I bought it... [blink]
 As the SYSTAINER WORLD TURNS, FOG's newest daytime soap opera..... [tongue]
  • Inactive Member
    • Tool Home LLC
I almost forgot, here's another use for a Sys Maxi...
48961-0
That's the Planex Harness kit to aid when reaching.
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline Festool Fishy
Just in case it is of any help in my old Festool catalog it lists the following for SYS MAXI (LxWxH) 590 x 390 x 210  and  SYS MAXI 2..   590 x 390 x 157.5 both still available in UK I believe
Offline Steve R
I just checked my prior USA catalog (2009) and it only has the 210mm tall Sys MAXI. SO....NAINA...
Cheers,
Steve
Offline Steve R
The MODS ripped out out a few comments that lead to a few posts about FastCap tape measures that I used to measure the inside dimensions in this post.
I'm hoping that I can some how provide you a link to that thread after it gets cleaned up as the cut messed up it context.
Try this -
FastCap – Tape Measure Review
Cheers,
Steve
« Last Edit: March 24, 2012, 06:47 PM by Steve R »
Offline SRSemenza
Try this -
Cheers,
Steve
Here is a link to Steve's new and complete review  http://festoolownersgroup.com/other-tool-reviews/fastcap-tape-measure-review/
Here is a link to the Fastcap tape measure topic that I split cleanly from the MAXI Sys topic.  http://festoolownersgroup.com/other-tools-accessories/tape-measures-fastcap/
Here is a link to another recent thread on FastCap tapes.  http://festoolownersgroup.com/hand-tools/fastcap-tape-rulers/
