Author Topic: OF1400 Offset  (Read 3455 times)
Offline birchwoodwerks
OF1400 Offset
« on: July 12, 2015, 01:13 PM »
Ive been looking on the site and cant find the answer. Ive measured and it looks to be about 57mm. But what is the exact measurement from the side of the OF1400 to the "center of bit". Thanks in advance
TS75,FS1080/2,FS1900/2,FS2424/2 LR32,CT36,
RO125,ETS125,DF500,Domino,RS2,TI-15 set,850HL,Installer set, systainer,OF1400,Carvex 420 D handle,new CXS set, compact cleaning set,  12 drawer Sortainer.
Offline Peter Halle
Re: OF1400 Offset
« Reply #1 on: July 12, 2015, 02:18 PM »
You can measure it.  Place a ruler along the flat side and then there is a mark on all four sides on the side of the base which is the centerline.
Re: OF1400 Offset
« Reply #2 on: July 12, 2015, 02:21 PM »
I did it says 57mm but it was a little off I wasn't sure if there was a more accurate number from festool. Thanks for the help
Offline Peter Halle
Re: OF1400 Offset
« Reply #3 on: July 12, 2015, 06:53 PM »
Sorry.  I know that some people don't know about the centerline marks on the router bases and thought that you might have been measuring to the center of the collet.
Re: OF1400 Offset
« Reply #4 on: July 14, 2015, 05:36 PM »
No worries I appreciate the response
