Pages: [1]   Go Down
  Print
Author Topic: Video Review of Parallel Guide Attachment for TS75 [UPDATED]  (Read 8361 times)
lumbajac
Offline Offline
« on: February 18, 2011, 12:45 AM »
Review of parallel guide attachement for TS75 in use for ripping narrow stock.
Festool Parallel Guide Review
« Last Edit: February 26, 2011, 11:48 AM by lumbajac » Logged
Corey - U.P. of Michigan
waho6o9
Offline Offline
WWW
« Reply #1 on: February 18, 2011, 11:15 AM »
I wondered how the parallel guide worked. Thanks for sharing.  Have you used the guide in conjunction with the rails?
dsweetser
Offline Offline
Adirondack, NY USA
« Reply #2 on: February 18, 2011, 11:53 AM »
Cory, Nice review. Good to "see" you again. Like the FOGtainer in the background.
Don
Don
lumbajac
Offline Offline
« Reply #3 on: February 18, 2011, 03:27 PM »
I have not used the parallel guide in conjuction with the rails as it works so well without that I don't see the need to include the rail in the operation.
Additionally, this was only my 3rd time using the parallel guide.  I find that it works very well and could probably speed up the setup significantly with additional usage.
Lastly, one of the times I used this setup was to rip several 2" x 4" x 8's in half.  It was a quick process and I believe it was safer and the results were far better than if I had been ripping alone with a table saw... unless maybe I had a nice SawStop with outfeed tables and the whole works.
Thanks.
Dovetail65
Offline Offline
« Reply #4 on: February 18, 2011, 03:38 PM »
I forgot I had one of these, thanks for the reminder. Now I have to find it.  Smiley
jonny round boy
Online Online
« Reply #5 on: February 18, 2011, 03:47 PM »
Nick, you probably sold it already.... Tongue Out
vkumar
Offline Offline
Sunnyvale (near San Jose) California
« Reply #6 on: February 18, 2011, 04:26 PM »
Corey, very nice review.  Thanks for doing it. You have a nice presentation style easy to follow and good tips.
Vijay
Corwin
Online Online
« Reply #7 on: February 18, 2011, 04:36 PM »
You can install these parallel guide upside-down on your saw so the parallel guide will ride on top of your material to the right of the saw.  This may prove useful to stabilize the saw on the guide rail during a bevel cut.  But, I don't see where it makes any sense at all to use this parallel guide with the saw on the guide rail when installed upright, as it will be the placement of the guide rail that will dictate the path of the saw, not the parallel guide -- and used in this way the parallel guide may present a problem as your saw travels down the rail.
Shirt Size:  L
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #8 on: February 18, 2011, 04:59 PM »
Corey, couldn't you use the fast fix feature to hold the blade out?
USPcompact
Offline Offline
« Reply #9 on: February 18, 2011, 05:09 PM »
Instead of measuring from the blade out to the parallel guide, why not just measure from the green splinterguard out to the parallel guide?  As long as you're using blades with an identical kerf, shouldn't this be just as accurate and much more convenient?
That said, I don't have the parallel guide attachment and may be out in left field with this suggestion.   Blink
lumbajac
Offline Offline
« Reply #10 on: February 18, 2011, 05:13 PM »
Yes, I believe so.  Although, I am having issues with my fastfix where it is not keeping the blade out - likely human error of some sorts.  Also, I found that measuring from sawtooth to the guide vs. the blade edge to the guide does make enough of a difference that it is important to be measuring tooth to guide.  With that said, I need the blade height set just so - I guess I could find that particular height and just remember and set depth to that each time I'm making the measurement.
Thanks.
lumbajac
Offline Offline
« Reply #11 on: February 18, 2011, 05:14 PM »
Good suggestion - I will try that and report back on it.
Any more suggestions to speed things up or improve process out there; things to try?
Thanks.
lumbajac
Offline Offline
« Reply #12 on: February 18, 2011, 05:15 PM »
Vijay
Thank you Vijay.  Much appreciated.
Corey
lumbajac
Offline Offline
« Reply #13 on: February 18, 2011, 05:18 PM »
Don
Thanks Don, good to hear from you.
The FOGtainer in the background was definitely intentional.  The black & yellow, red, and dark green items were definitely unintentional  Embarassed
ScotF
Offline Offline
WWW
« Reply #14 on: February 19, 2011, 10:33 PM »
Corey,
Great review and use of this accessory.  Thanks for putting it together!
Scot
John Stevens
Offline Offline
Ardmore, PA
« Reply #15 on: February 19, 2011, 11:36 PM »
Nice job, Corey.  Besides the FOGtainer, I liked the paneled frames in the background, and your basement, with its high ceiling.
Regards,
John
What this world needs is a good retreat.
--Captain Beefheart
PaulMarcel
Online Online
WWW
« Reply #16 on: February 20, 2011, 12:55 AM »
Nice review, Corey!  Like Nick (Dovetail65), I forgot I had one, though I know I didn't sell it Smiley
Also, nice tip, Corwin.  I'm definitely going to pull out the guide to try this trick out of stabilizing the saw on a bevel cut.  I've done a few bevel cuts with it and never liked the lack of stability.
Shirt size: L Cool
Twitter: @HalfInchShy
lumbajac
Offline Offline
« Reply #17 on: February 20, 2011, 10:02 AM »
Thanks Scot, John, and Paul.
I've got some good ideas from others for easier setup of the guide and will post soon if they work out for the better.
Thanks.
ScotF
Offline Offline
WWW
« Reply #18 on: February 20, 2011, 11:36 AM »
Hi Corey,
What speed were you using when you ripped the board?  It sounded slower than 6, but maybe I did not hear it right.  Thanks.
Scot
Frank-Jan
Offline Offline
« Reply #19 on: February 20, 2011, 12:08 PM »
I have this attachment for my ts55, I really like the way it stores upright in the systainer without being in the way to get the saw, so, allthough I rarely use it, it is always at hand. (There was a thread about the one for the ts75 being too wide to easily store in the systainer)
For setting it to width, I usually lock the saw in the fastfix "bladechange-mode"
lumbajac
Offline Offline
« Reply #20 on: February 26, 2011, 11:52 AM »
I've done a short (2:38) video update of the Parallel Guide review incorporating suggestions from fellow FOG members - setting the width of cut is now (I believe) faster, easier, and smarter.  Thanks.
Festool Parallel Guide Review UPDATE
« Last Edit: February 26, 2011, 12:00 PM by lumbajac » Logged
Gary L.
Offline Offline
« Reply #21 on: April 11, 2011, 02:11 PM »
Thank you for the demo.
Does the saw try to "wiggle" much?  It looks like you only have to apply a little pressure to the guide to keep it in position against the wood.
Would it be possible to pull on the saw base instead of push on the guide to keep it in position?  Just to keep from having to lean over the saw so much.
EvilNuff
Offline Offline
« Reply #22 on: May 15, 2011, 12:31 AM »
Quick question from others who have this.  I picked up the attachment for my TS55 today and wonder if mine is defective.  There are black plastic caps on the ends and they stick out slightly, about 1mm from the edge.  What this does is as my cut progresses and trailing edge of the parallel guide is about to hit the workpiece this black plastic hits the edge and stops the saw from moving.  Is this normal or am I using it incorrectly somehow?  I can take a picture if i'm not clear.
Ken Nagrod
Restricted
Offline Offline
« Reply #23 on: May 15, 2011, 07:02 AM »
I just took a look at mine and the black plastic end caps are flush with the metal bar everywhere, so either file yours down or exchange it for a better one.
Pages: [1]   Go Up
  Print
Jump to:
