Author Topic: RE cooltools domino  (Read 5902 times)
Offline Per Swenson
  • So far deep in rural nj, there are no Neighbors
    • Swenson&Swenson
RE cooltools domino
« on: April 08, 2008, 07:37 AM »
Hello Everybody,
Last year or maybe earlier I wrote a review of the domino for Kevin Kellys Cool tools.
And if it weren't for our very own Eli. I would never have known it was published.
I guess it came out this week.  Way to stay current Kev!
Next week drywall screw guns.
No, I am not complaining but the piece is heavily edited and kinda lacks the
the Swenson form of no crap we strive for.
Here it is, as published.
Per
Assembly-line style woodworking
Festool Domino Joiner
Never before has a woodworker been able to make loose tenon joinery simply, quickly, accurately and anywhere. Loose tenon work is a process that has long been done by hand and/or large expensive stationary machines. With the Domino, you can now bring the tool to the wood. Anywhere. No back and forth to the shop, which can take hours. The Domino has locator pins in the face for precise alignment, meaning you can actually build something and test fit it together with no glue; the tolerances are that tight and perfect. The Domino really has the ability to turn a neophyte weekend bookcase maker into a pro -- I am a professional trim carpenter and in my line of work that's scary! Here?s why it work's so well: the cutter is an oscillating carbide plunge bit similar to a router bit and it?s interchangeable. It takes 5 seconds to set up for plunge and 2 seconds to do the deed. The time savings can be counted in days if not weeks on a big project. I used to scoff at overpriced stuff like this. Silly me. It?s well made and, in the short and long run, it really increases productivity, which both saves and makes me money.
It's expensive, but I'd still recommend getting the set, as opposed to just the Domino itself. The set comes with two attachments that are a must for two different applications. One is for end joining, as you do with a face frame (the front of cabinets, which are made out of 1x2 or slightly larger stock). This attachment allows the machine to fit the narrow piece of wood perfectly on the end and it prevents wobbling (without it, the mortise would not be straight and at 90 degrees). The attachment also adjusts to take a 2 ? inch wide board, meaning you can mortise anything from an inch wide up to 2 ? inch. If you are making face frames you have a lot to do, but with this attachment, once you set to your size lumber, there is no more thinking. The other attachment allows you to align dominos that are farther apart than the factory pins. The factory pins allow mortise's spaced about a 1 ?? apart. With this attachment, you can space them anywhere from 4 1/8? to 8 3/8? and the pins hook into the last hole/mortise made, so all your holes are evenly spaced and line up exactly. No marks or measuring.
-- Per Swenson
$750
Available from and manufactured by Festool
http://www.festoolusa.com/ProductDetails.aspx?id=15&prodid=574258
Party like its 1929. It's the American way.
There outta be a law banning sesquipedalianism on
internet forums.
www.swensonz.com
Offline PaulW
  • Michigan USA
Re: RE cooltools domino
« Reply #1 on: April 09, 2008, 08:29 PM »
Nice review Per.
Exellent tool, hope to own one someday  :P
Paul
Offline Loren Hedahl
« Reply #2 on: April 10, 2008, 01:17 PM »
A blatant forgery!
Per, you didn't write that!
Location (generally):  Thirty five miles west of Seattle by the way the crow flies.
You can tell a Norwegian, but you can't tell him much!
Offline Bill Wyko
« Reply #3 on: June 11, 2008, 01:41 AM »
Great write up Per. That pretty much sums it up. There is a whole other side to it's uses too, the artistic side. It was never designed for artistic use but I guess that is just a bonus you get in the same systainer. ;D Nice job my friend.
The bitterness of poor quality, lingers long after the cheap price is forgotten.
