Pages: [1]   Go Down
  Print
Author Topic: Review of Festool: Guide Rail FS/2 Product No.: 491 501  (Read 9035 times)
GPowers
Offline Offline
Metric convert
WWW
« on: June 14, 2010, 02:01 PM »
Festool Guide Rail Review:
In the beginning 1000 years BF (before Festool) to break down sheet goods man used the circular saw and a chalk line.  The chalk line provided a straight cut line, but the accuracy of the final cut depended on the skill of the steady hand holding the saw. Man was looking for a better method.
600 years BF, man started using a straight piece of wood to help guide the saw. This helped create a straighter final cut. But is was easy to cut in to the wood guide. The accuracy of the cut depended on how straight the piece of wood was. Plus it was difficult to cut on the cut line as there was an offset between the guide wood and the cutline. One last problem was is was difficult to keep the wood guide form moving while making the cut.
300 years BF, Man found the metal straight edge and combined it with the wood guide to solve some of the problems. First by combining the two it was easier to cut a straight cut as the metal straight edge was more accurate then the guide wood of early years. The offset between the edge of the metal and the edge of the wood took the guess work out of cutting exactly on the cut line.  Man also add C clamps to help hold the device in place when making the cut.
But problems still remain,  it was still easy to wander of the cut line and slice into the wood guide. The clamps stuck up and sometime got in the way of the saw. A straight accurate cut was still difficult to get as the metal straight edge was not that solid and flexed a lot. Man need a better way.
Then came Festool and the simple Festool Guide Rail. An accurate straight cut was now faster, easier and smarter.
First Festool combined the saw and the Guide Rail into a single system. The bottom plate of the saw mates into a track that is integrated into the guide rail.  This means the saw will stay true to the guide rail and NOT wander off course. To make the saw slide easily over the surface of the guide rail, without binding,  Festool added  anti-friction strips (the green strips)  along top surface of the guide rail.
The combination of the saw and the guide rail also positions the edge of the guide rail and the saw blade right on the cut line. This make for a easy, faster and smarter way of setting up the cut. Just place the edge of the guide rail on your mark and you are ready to cut your line.
Also part of the Festool Guide rail is a built in splinter guard to protect against splinters when cutting brittle plywood. If you look closely, in the photo above, you can see the clear splinter guard running along the edge of the guide rail.
Festool did two things to help hold the Festool Guide Rail in position when making the cut. First, on the bottom of the Guide Rail they place strips of foam rubber too keep it from slipping around your work piece, see photo below.
If you need more holding power, there is an integrated slot that runs the length of the bottom of the Guide Rail.  Festool has screw clamps that fit into this slot that can be used to hold the guide rail in position. With the slot and the clamps on the bottom they are out of the way and do not interfere with the saw.
Festool does not just leave the Guide Rail as part of a track Saw. Festool creates a whole system around the Guide Rail. The Guide Rail works, not only with the TS line circular of saws, but also integrates with all the routers and the jig saws. There are accessories that can be used to attach most of the routers and jig saws to the Guide Rail to make accurate repetitive cuts. The Guide Rail is part of the Multi-functional Table and  part of the LR 32 hole drill system. There are also all kinds of accessories. The newest member, of the Guide Rail system, is the Parallel Guide set. Besides the normal screw clamps there are the Quick clamps and the FS Rapid clamps.
This is just a partial list of what the Guide Rails works with and the accessories. But it demonstrates that the Guide Rail is part of the whole Festool system.  I think the Guide Rail gets over look most of the time due too it's simplicity. To me the Guide Rail is one of the key components to the Festool system.
« Last Edit: June 16, 2010, 05:45 PM by GPowers » Logged
Greg Powers
Redfox
Offline Offline
« Reply #1 on: June 14, 2010, 07:03 PM »
Hi Greg,
 Grin for a funny article.
Cheers,
Jacques.
Chris Meggersee
Offline Offline
I'm addicted to Festools.
« Reply #2 on: June 15, 2010, 02:31 AM »
This is awesome. Well written and it's nice and creative.
I just have to ask though about the bottom picture you have posted, how does the domino work with the rail?
Anyway great work.
Chris
PS300EQ Jigsaw - OF1010EBQ Router - DF500 Domino - RO125FEQ Sander - C12CE Drill - TS55EBQ Saw - CT22E Dust extractor - DTS400 Sander
Wish List: Anything not listed above in the catalogue.
AdamM
Offline Offline
« Reply #3 on: June 15, 2010, 07:57 AM »
I was wondering that as well...
Kapex, Domino, TS55, CT22, MFK700, MFT 1080
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #4 on: June 15, 2010, 08:38 AM »
Simple, like this:
I use the backside of the rail on my MFT to index the my Domino mortises in a straight line and at a right angle to an edge.
ossietim
Offline Offline
« Reply #5 on: June 15, 2010, 08:58 AM »
I like this very much.i don't have saws just sanders(floor sander).but i do sometimes lay borders and have only used the 600 Years BF. Big Grin Smile
It explains the whole concept well.So much so that i'm going to invest in a saw and rail!
Well done Greg.
It is "Know-how" which distinguishes the USEFUL Person from the "USELESS"
Books and Men can give you "Know-how and  Practice gives you skill.
GPowers
Offline Offline
Metric convert
WWW
« Reply #6 on: June 15, 2010, 11:31 AM »
Anyway great work.
Chris
Brice's example of using the Guide Rail as a fence, with the Domino is the exact example. I remember reading a tutorial that he did about the Domino and was surprised to see the Guide Rail and the Domino used together. Again, it demonstrates how versatile the Guide Rail is.
« Last Edit: June 15, 2010, 02:19 PM by GPowers » Logged
Greg Powers
Chris Meggersee
Offline Offline
« Reply #7 on: June 15, 2010, 02:04 PM »
Anyway great work.
Chris
Brice's example of using the Guide Rail as a fence, with the Domino is the exact example. I remember reading a tutorial that he did about the Domino and was surprised to see the Guide Rail. Again, it demonstrates how versatile the Guide Rail is.
Agreed. To me this is what made Festool popular and they have built a very very strong foundation for it. It's funny to think that it took 1000 years for something that simple and versatile to come out.
Frank Pellow
Offline Offline
Toronto, Ontario, CANADA
« Reply #8 on: June 15, 2010, 02:17 PM »
That's a great review Greg and, in particular, I like the historical background.
Cheers,
               Frank (Festool connoisseur)
GPowers
Offline Offline
Metric convert
WWW
« Reply #9 on: June 15, 2010, 02:23 PM »
Thanks, Just trying to make the review a little more fun to read.
Greg Powers
Frank Pellow
Offline Offline
« Reply #10 on: June 15, 2010, 02:30 PM »
And, it was fun to read.  Thumbs Up
Cheers,
GPowers
Offline Offline
Metric convert
WWW
« Reply #11 on: June 15, 2010, 02:52 PM »
Even funner is I still have the Chalk line and old saw from 1000 BF  Embarassed.
Greg Powers
Corwin
Online Online
« Reply #12 on: June 15, 2010, 02:58 PM »
What's that?  You say you have a chalk line around an old saw from 1000 BF?
Great writeup!   Thumbs Up
Shirt Size:  L
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #13 on: June 15, 2010, 05:12 PM »
The BF power tools I have work with the Festool guide rails also... If I turn the guide rail around.
For some reason, I don't seem to use them much. It has to be a pretty cruddy situation to reach for a BF tool any more.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
GPowers
Offline Offline
Metric convert
WWW
« Reply #14 on: June 15, 2010, 06:05 PM »
Turning around the Festool Guide Rail and using with a non-Festool saw would require you to figure out the offset between the cut line and the Guide rail. Not a lot of fun and not the most accurate.
Best not to mix the stone age tools with modern high tech stuff.  Laughing
Greg Powers
Redfox
Offline Offline
« Reply #15 on: June 16, 2010, 06:53 PM »
I think keeping ones BF tools is a smart move. For example I can lend them out to a friend. That won't happen with my F-tools.
Just my two-pence.
Cheers,
Jacques.
GPowers
Offline Offline
Metric convert
WWW
« Reply #16 on: June 16, 2010, 07:04 PM »
Just my two-pence.
Cheers,
Jacques.
I agree, I also use my BF tools for nasty tasks like cutting cinder block.
Greg Powers
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #17 on: June 17, 2010, 01:53 AM »
Gary:
I sell some CMT Diamond Fiber Cement Blades that I don't mind using with my Ryobi saw but would be very hesitant to use with any of my Festool saws. I occasionally cut up a bunch of Hardie products, which is why I hang on to the old, still working stuff - for those occasional, really abusive situations.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Pages: [1]   Go Up
  Print
Jump to:
