Pages: [1]   Go Down
  Print
Author Topic: Review of T15+3 drill with Centrotec emphasis  (Read 4412 times)
TJ Cornish
Offline Offline
« on: February 18, 2011, 12:14 AM »
Review of Festool T15+3 and Centrotec bit holders
After getting the Festool bug last summer, I bought a T15+3 drill.  The major advantages of this drill compared to the competition are the brushless electronically controlled motor, the electronic clutch, and the extra chucks.
The brushless motor has several advantages – it is more efficient than a brushed motor, and it doesn’t have brushes to wear out.  Festool claims that this extra efficiency allows the 15 volt Festool T15 to exceed the performance of most 18 volt drills.
The electronic control system both protects the drill from overheating and over torquing, and also acts as the clutch mechanism – there’s no grinding mechanical clutch on this drill.  At low torque settings the drill’s maximum speed is limited so you don’t overdrive the torque setting with the inertia of the drill and chuck.
The T15+3 kit includes several chucks – the usual Jacob’s-style 3 jaw chuck, the Centrotec bit holder chuck, the offset chuck, and the right angle chuck.  I’m not going to invest a lot of time writing about the various chucks since they have been well covered in other reviews, but I wanted to examine the Centrotec chuck and bit holders.
The Centrotec system is a little different than other similar ¼” bit holders in that the Centrotec bit actually fits inside the drive shaft of the drill.  The Centrotec chuck is nothing more than a plastic retaining system – the bit holder is driven by the drill shaft itself. The two advantages of this system are the reduced length of the drill, and low runout.  Runout is bit wobble.  This may not be a hugely important issue in a hand-held drill, but it is listed as a feature.
I have 3 Centrotec bitholders – the one that came with the drill kit (492539), the spring clip version (492648), and a second regular bit holder given to me today by Festool Dan who happened to be at a local tool show today.  He gave me the bit holder because I complained that the bit holders I had didn’t seem to run any more true than any others I have used – particularly the spring clip one.  I decided to test them.  Here is the test setup: a Bridgeport mill with a dial indicator.
This particular dial indicator is a back plunger type.
I chucked it up and let it go.  Actually, I attempted to chuck it up but found that the bit holder is actually .275” and didn’t fit in my collet without a little prying.
The results:
The spring clip holder that I observed had the most runout measured at .020”.
The regular holder included in my T15 kit measured about .008”
The bit holder from Festool Dan measured .012”
I also tested the drill shaft itself – it measured less than .0005” runout – very impressive.
The Jacobs style chuck measured .002”.
How much is too much?  If my spring clip holder had any other name on it than Festool, .020” wouldn’t be unheard of.  From Festool, especially since low runout is considered a design feature, I’m disappointed – the bit holder visibly wobbles much more than a $30 holder should.  I can say that I am very impressed by the potential of the low runout design of the T15+3, but based on at least one of my examples, Festool isn’t immune to manufacturing tolerance issues.  Kudos to Dan for giving me a spare bit holder no questions asked though.
This is a pretty minor issue in the grand scheme of a great tool.  I really enjoy the power and ergonomics of this drill, and the electronic control system is really neat.
My rogue's gallery of Centrotec bit holders
« Last Edit: February 18, 2011, 12:22 AM by TJ Cornish » Logged
AlphaG
Offline Offline
« Reply #1 on: February 27, 2012, 11:07 AM »
I have to agree completely with your assessment of the spring clip bit holder and bit wobble.  The bit wobbles too much for a tool that claims inherently limited runout by manufacturing design.  I am inclined to use just the regular magnetic bit holder with my CXS.
itsmehc
Offline Offline
« Reply #2 on: February 27, 2012, 11:54 AM »
I so agree on that the spring clip bit holder is not a good design, even sent festool a mail but no reply. My bit lasted 1 day. First the magnet inside got loose than the spring that holds the bit is not working anymore. This is actually my first festool "failure".
C12-C15-Kapex-Planex-Rotex-Of1400-CS70 EB-Set-DTS400-LEX 2 150/3-LEX 2 150/7-LEX 2 150/11-LRS 400-TS 55 EBQ-Plus-FS-RW 1000-TRION PS 300-DOMINO DF500
EWTHeckman
Offline Offline
« Reply #3 on: February 27, 2012, 01:19 PM »
The problems with the BHS 65 are disappointing. Thanks for putting the time into this.  Not Worthy
Your review also reinforces the need for native Centrotec robertson bits. IMHO it's past time for Festool to get on the ball and make it happen already.
Ed "What the" Heckman
leakyroof
Offline Offline
« Reply #4 on: February 29, 2012, 10:03 AM »
  Here Here.....  As in, I TOTALLY agree with you  Big Grin Big Grin
 But, they don't, or we'd have seen them already from Festool at some point.   Sad
GhostFist
Offline Offline
« Reply #5 on: February 29, 2012, 07:27 PM »
BHS 65 should be condensed to BS 65. Made the mistake of buying a second one after the first one was pooched. Use the straight up magnet bit now. It does the trick but still leaves me longing for more compatible bits with centrotec.
greg mann
Offline Offline
« Reply #6 on: February 29, 2012, 10:10 PM »
Do I understand correctly that the OP tested the runout of this holder by prying it into a 1/4 inch Bridgeport collet even though the diameter of the tool was .275? If so, then the test is invalid. An R8 (Bridgeport) collet is designed to hold tool shanks that vary no more than a few thousands of an inch from their nominal size. When a tool .025 larger than nominal is forced into a collet of this type it will inherently runout on it's own. The best test would have been to use the Centrotec holder with the various bit holders and measure the runout similar to his other tests and do away with the Bridgeport test altogether. The Bridgeport setup added runout rather than eliminating it.
While there may be room for criticism of these various bit holders, in my experience runout is not an issue. Maybe I have just been luckier than you guys but I just don't see the runout to which you refer.
« Last Edit: February 29, 2012, 10:12 PM by greg mann » Logged
Greg Mann
Oakland, Michigan
GhostFist
Offline Offline
« Reply #7 on: February 29, 2012, 10:13 PM »
i have to agree with that. i've no runout issues either
Alex
Online Online
« Reply #8 on: March 01, 2012, 05:47 AM »
I also don't get this runout babble here, it's not an issue with centrotec.
But I have to stand in line with other people here about the BHS 65, I don't like it. Got nothing to do with runout but with the locking ring which is too wide (outside diameter) and the darn magnet inside which is redundant and way too strong. You've got to fight to get your bit out.
GhostFist
Offline Offline
« Reply #9 on: March 01, 2012, 06:41 PM »
Well I've had two magnets just fall out, and the locking ring only seems to work for a month tops. Not happy with this bit at all as the mechanics behind wire detent locking bits have been done very well on much cheaper bits. Wont be buying another thats for sure and i advise others to avoid it as well
Ken Nagrod
Restricted
Offline Offline
« Reply #10 on: March 02, 2012, 02:13 AM »
I don't know if anyone realized this, but there are 2 versions of the BHS65 bit holder.  I bought one when they first became available here as an accessory.  The second and newer version I got included with the new Centrotec kit.
Take a look at the picture and you'll notice visual differences.  I've found that the older version has more bit movement while the newer version has none.  I've barely even used the older version, so wear is not the cause.  Also, the older version BHS65 still has less bit movement than my BH60 bit holders.
Newer version is on the left.
fldange
Offline Offline
« Reply #11 on: March 02, 2012, 09:39 AM »
I have to disagree. I have the BHS65 from the Centrotec Kit and it has allot if wobble.  A useless bit holder as far as I am concerned.  I have tried it with my CXS and T18 with the same results.   Tks.
Pages: [1]   Go Up
  Print
Jump to:
