Pages: [1]   Go Down
  Print
Author Topic: Review - SYS-Toolbox  (Read 8482 times)
jonny round boy
Offline Offline
« on: September 17, 2011, 01:45 PM »
Warren posted a few weeks ago about a small UK-only contest to identify a new Protool accessory. It turned out that the accessory in question was the SYS-Toolbox, but more importantly - I won! Big Grin
My prize arrived yesterday:
so I thought I'd do a quick review.
Firstly, it's very well made, with thick section plastic (ABS I think) that's rigid & tough. The corners, as the most vulnerable areas, have sturdy columns to protect it, as you can see from the underside:
The toolbox is split into two compartments by a central divide, each side measuring approximately 360mm long, 120mm wide, and 140mm deep. There's a small (3mm dia) hole in the inside corners of each section, presumably to allow drainage of the compartment should the toolbox be inadvertently left out in the rain. Eek!
Whilst looking it over, I noticed that the handle moulding was simply clipped in from the top:
My first thought was that this might be a weak point, but my worries were unfounded. The handle is rock solid & the joint is very strong. In the above pic you can also see two of the 4 drain holes mentioned earlier.
The SYS-Toolbox is designed to work with both the 'Classic' and 'T-Loc' systainers. For connecting to the newer T-Locs, there's a pin on the front to connect with the locking handle, and the back two feet are angled to hook under the top of the systainer underneath:
I don't have any T-Locs to connect it to, so I can't show that. I do however have plenty of classic systainers, and the SYS-Toolbox will (probably) be put to use on top of my 'main' toolbox:
Additionally, the toolboxes are designed to clip to each other, with the handle of the lower systainer fitting into the central divide of the upper one. There are 2 of the old-style latches, one at either side, to clip them together in this configuration:
The toolbox tips the scales at a little under 1.3kg, so it's very light, and the height (excluding handle) matches the Sys-2 at around 150mm including the feet. The handle rises to around 65mm higher, making it 215mm high overall. The handle itself is nicely rounded, and very comfortable to hold (like the Tanos systainers, more so that the Festool systainer handle). It also has small slots in either end to take the carrying strap if you so wish. When attached to the top of my stack above, it's far more comfortable to lift the entire stack with this than by the 'classic' systainer handle.
BTW, the panel on the front with the Protool logo is clearly a removable/replacable section within the mould (evidenced by the very slight flash line around it) so I don't see any reason why there couldn't be a Festool-branded version at some point, but that's no indication that there will be!
In summary, it's a nice addition to the systainer family. At £29.75 +VAT it isn't cheap, but it's very well made & the quality is top-notch. Is it worth it? Well, I didn't pay for mine, but if I saw this in a store, picked it up, felt the quality etc., I'd have a hard time walking out without one, even if I didn't really need one...
To clarify, this was provided to me by Warren (username: toolfest.co.uk) of Bunnys Bolts in Woking as a contest prize.
skinee
Offline Offline
« Reply #1 on: September 17, 2011, 01:55 PM »
thanks for an excellent review,seems to be well worth the money.
jmbfestool
Online Online
« Reply #2 on: September 17, 2011, 02:18 PM »
Good Detailed Review!
I was suppose to call Warren the other day to buy 2 of them but forgot so gotta wait till Monday  but this review has helped for the dimensions so I know what to work with! thank you!
Festoolfootstool
Offline Offline
The trouble with Bob is its all about Bob
« Reply #3 on: September 17, 2011, 02:23 PM »
they look like a good usefull item.
all its missing is a lid..... Doh! Thumbs Up
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #4 on: September 17, 2011, 07:26 PM »
Nice review Jonny. Thumbs Up
That's what I was thinking. Tongue Out
Brice Burrell
Offline Offline
WWW
« Reply #5 on: September 17, 2011, 07:29 PM »
One question, what is on the side in the first picture?  It looks like there might be a tag or something taped on the side.
ossietim
Offline Offline
« Reply #6 on: September 17, 2011, 07:36 PM »
Thanks for the insight
Another question: can you remove the handle?
It is "Know-how" which distinguishes the USEFUL Person from the "USELESS"
Books and Men can give you "Know-how and  Practice gives you skill.
harry_
Offline Offline
« Reply #7 on: September 17, 2011, 07:43 PM »
I had been thinking how cool it would be (for me) if they made one just like that with a handle that folds over and fits inside a sys. I think it would be an awesome accessory to go with a say a drill. Bump the systainer up to the next size and drop in the tool tray. Sorry, I just dont like the idea of loose (hand) tools in the back of my truck.
 2 Cents
jonny round boy
Offline Offline
« Reply #8 on: September 18, 2011, 04:17 AM »
That's just the product sticker, with the product name & barcode on.
jonny round boy
Offline Offline
« Reply #9 on: September 18, 2011, 04:19 AM »
Not really. I guess you could if you could get some long-nosed pliers in there to un-clip the clips, but it wouldn't be easy & I suspect it would weaken the joint after a while.
ossietim
Offline Offline
« Reply #10 on: September 18, 2011, 05:03 AM »
Jonny  ,i was thinking of just removing the handle to get one posted to me.(the package would be more of a standard shape)
andy5405
Offline Offline
« Reply #11 on: September 18, 2011, 06:10 AM »
Jonny, it's looks like a good idea but would you actually buy one?
Brice Burrell
Offline Offline
WWW
« Reply #12 on: September 18, 2011, 09:50 AM »
I think Jonny, more or less, already answered that question.
...In summary, it's a nice addition to the systainer family. At £29.75 +VAT it isn't cheap, but it's very well made & the quality is top-notch. Is it worth it? Well, I didn't pay for mine, but if I saw this in a store, picked it up, felt the quality etc., I'd have a hard time walking out without one, even if I didn't really need one...
woodguy7
Offline Offline
« Reply #13 on: September 18, 2011, 10:57 AM »
Nice review Jonny, something I may give some thought to even though when I first seen One I thought it unnecessary.
Nice to see another country winning a prize in a competition for once  Bite your tongueGrin
Shirt size medium
koop
Offline Offline
« Reply #14 on: October 26, 2011, 03:44 PM »
I really like 'em, i have bought three of these last week, one each for different 'jobs' , general woodwork \ wrenches-pliers-screwdrivers \ plumbing-metalwork
easy acces, same footprint as the systainers and all my other 30x40cm boxes for materials and parts etc
neeleman
Online Online
« Reply #15 on: January 15, 2012, 05:32 PM »
Here are the Tanos Tool Box versions in Anthrazit and Lichtgrau.
Find them on ebay Germany.
It would not take so long before there will be a Festool version too!
« Last Edit: January 15, 2012, 05:38 PM by neeleman » Logged
Precisio CS50 EB-Set, Kapex KS120-UG Set, TS55 R EBQ, Carvex PS420 EQ, BS75 E, RAS115.04 E, Rotex RO90 DX, Rotex RO150 FEQ, DTS400 EQ, RS400 EQ, RTS400 EQ, RS300 EQ, Duplex LS130 EQ, Deltex DX93 E, ETS150/5 EQ, Domino DF500 Q, OF1010 EBQ, OF1400 EBQ, OFK500 Q, MFK700 EQ, C12-Li, T15+3, TI15 Impact, T18+3, CTL26 E, CTL22 E SG, CTL Midi, EHL65 E, D27-AS Plug-it, D36 UNI-RS, FS800, FS1400/2, Gecko Dosh, Toolie, CE-SYS-2010, RB-SYS CART, Syslite KAL, LEV1400, Protool PDC 18-4, Protool FLC UNI.
fuzzy logic
Offline Offline
« Reply #16 on: January 15, 2012, 08:25 PM »
Just read this thread.
Looks good - no lid - hmm   Unsure
Love the way it can clip to systainers; can see that being really quite handy.
Decent people do the right thing - always.
Pages: [1]   Go Up
  Print
Jump to:
