Pages: [1]   Go Down
  Print
Author Topic: RO 90 for stair risers, The best (or only) machine for the job  (Read 3102 times)
ward
Offline Offline
WWW
« on: April 26, 2012, 07:35 PM »
Having hand scraped risers for over 25 years, I've grown quite tired of refinishing staircases particularly risers but even stair treads are time consuming and labor intensive. In the past and as an apprentice I spent days hand scraping and sanding risers prior to finishing (dark stain being the most difficult of course). I have been lusting after the RO 90 for months waited for a paying project to justly the expense. I must say I'm very impressed and happy with my purchase and the performance of both the sander and the new (to me) Garnet paper which did a great job of stripping 80 year old finish off softwood risers and a rectangular scotia molding I've never seen on a stair case. The RO 90 is so compact that it fit under the stair nosing and in this case even the square scotia.
The sander works great and reduces the area of finish to be hand scraped to less than 2 sq. inches. While everyone on the crew wanted to play (i mean work) with the new toy, i mean tool, I was particularly impressed when my lead mechanic swore to buy one. While he likes the Rotex 150 and the ETS 150 he's never before committed to buying his own Festool and the fact that he is so excited speaks volumes to me. What is also so appealing to me is the size is so perfect for most stairs allowing me to do a pass at the top of the riser and one at the bottom in this case the exposed riser was less than 6" high after the scotia molding took up an inch and half. So i did not have to worry about doing a pass in the middle of the riser with the risk of altering the plane of the riser. I may consider buying a 5" sander just to flatten out risers as this narrow of a rise is somewhat unusual and with the RO 90 I can actually make money refinishing stairs without burning out my crew. And as is usually true with any new festool purchase I want to use it myself for a while before turning it over to the crew.
Like all sanders, especially on vertical surfaces, this is a two handed tool for serious operation. I had to emphasize this to my newest helper ( I recently learned that most people have to be told new information 7-10 times before actually integrating it) this was a watershed meme for me, I used to think the number was 3. It’s not, now I know most people do require new information being repeated 7-10 times before altering their behavior. Nothing like changing my expectations to improve my mood. . . . And once I trained my crew to keep it flat and use a little pressure (not allot, just enough to get the abrasive to cut the finish) maybe 5 pounds, it works amazingly well and fast. Of course I seem to be able to run any tool faster than my crew, but so it goes. . .
I'm very satisfied with my purchase even more so than my regular pride and satisfaction I expect to feel with any Festool purchase. I also managed to pick up a set of the hand sanding blocks with the mini systainer and again was impressed with the quality and ergonomics of both the RO 90 and the hand sander blocks, I was thinking i was indulging myself with a hard to justify, somewhat expensive set of hand sanding blocks but with the case it's a good deal and i really like all of them even having to buy paper for the rectangular block. I like being able to fully utilize my used 150 mm paper on the hand sanding blocks and get the most out of what i consider the finest abrasives I’ve used in 30 years. I swore by 3M Regalite but find the Festool line of abrasives much better and of course a little finer grit due to the European grading system being different.
I'm now far more willing to bid on jobs with lot's of stairs and risers and even look forward to doing the work, this tool has revolutionized the task of refinishing risers, the most labor intensive and tedious part of floor work in my experience. I can’t wait to see how it works on a maple staircase I’m doing next month. Actually I don’t expect any major changes, it anything it should be easier, sanding fir or other very soft wood is the most difficult of all common floor materials.
In addition it's worth using to knock out the floor corners after i edge them with a 7" edger, the 90 mm takes off another 50% of the area of the corner making scraping corners faster and easier especially if a apprentice technician "digs" the sander into the corner. The Ro 90 gets in there and makes for a much smoother transition to the corner.
Finally the sander came with a sample of nylon mesh abrasives that worked amazingly well for inter-coat abrasion taking off almost zero sealer while knocking off almost all dust or contaminants (tiny splinters of wood) leaving a substantially greater film of finish and yet a wonderfully smooth, debris free base for my second coat. I was so impressed I used the 7" knock out from my maroon buffer pads on my ETS 150 for abrading the treads and it worked great and saved allot of time and fully utilized the entire pad that is often underutilized. I had no problem jut putting onto the hook face of the sander and the projecting edge was really no problem as it did not slip or deform at low speeds nor damage the adjacent finish`. I may start using this exclusively rather than abrasive paper for inter coat abrasion on my edges even though i may cut them down to avoid buffing the base board, although that may not be a bad idea as it will get any loose paint chips off the base board before vacuuming rather than falling into the finish when i cut in the edges before my final coat, a pet peeve of poorly prepped base boards usually found in once rented units, painted with latex over old oil base without proper preparation by decades of low bid painters or renters. I always prepare my clients for base board touch up [excepting new cabinet kicks] it's almost inevitable to have some marks left by hand scraping the edges or mechanics actually running the edger against the base unless one is really careful and goes slowly, which is difficult with pressure to bid low and go fast.
Actually there is no excuse for marking baseboards when refinishing floors but it's a time and care issue that is challenging to instill in someone running an edger for more than a few hours a day, absolutely the most back and knee destroying work in floor refinishing. And when someone is running an edger 6 or more hours a day under pressure to make two passes in a 1500+ sq. ft. house in a day, it's going to happen and for me the key is to prepare the client for it and to keep it to a minimum so there is as little "touch up" later as possible. Ideally of course the base is painted after the floor is refinished so it's less of an issue.
Scott B.
Magazine/Blog Author
Offline Offline
Paint contractor and freelance writer.
WWW
« Reply #1 on: April 26, 2012, 07:40 PM »
Ward
Without a doubt, from the perspective of a high end paint contractor, the most useful sander on stair treads, risers, scotia and stringers is the LS130. And it has attachments for sanding handrails as well.  It has had a profound impact on our stair finishing program, which is historically a time suck.
Alex
Online Online
« Reply #2 on: April 26, 2012, 08:39 PM »
I always do stairs with my RO 150 (or a RO 125 if the 150 doesn't fit) and then finish the corners with the DTS400 or in rare cases, the DX93. I don't see how the RO 90 or LS 130 can do it quicker.
Scott B.
Offline Offline
WWW
« Reply #3 on: April 26, 2012, 08:45 PM »
Might be semantics, I am talking prep to finish on entire stair systems. From filling nail holes/edge easing to primer and paint on risers, scotia and stringers as well as several coats of oil on treads. The LS130 is the only one in the group that requires a finisher to do absolutely no hand sanding, which is where time is lost. Especially on the scotia.
Refinishing or repaints might be another story. For my work on stairs, RO150 would not be a good choice.
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #4 on: April 26, 2012, 09:15 PM »
Hey Ward!
Glad to see you posting Buddy!  It has been a long time!
Scott B.
Offline Offline
WWW
« Reply #5 on: April 26, 2012, 09:31 PM »
By the way, Ward, meant to mention it earlier in the thread but was multi-tasking as always...but, great report on the RO90. With your background in hand scraping, the 90 must feel like you just got yourself a brand new hand. There have been many, many days where I have felt like if I only could have one sander for everything I do, it may well be the 90. Pound for pound, the thing is a little beast, and a good choice. Thanks for sharing your experience.
Charimon
Offline Offline
Tool and Tile Junkie
« Reply #6 on: April 26, 2012, 09:52 PM »
It has been said, " The BEST measure of someones intelligence is if they independently come to the same conclusion you did".   I think the 90 is the most Versatile sander on the market today.   Now if they would make  RTS/DTS 400 lock on pads to use in the orbital mode Wink
« Last Edit: April 27, 2012, 03:17 AM by Charimon » Logged
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
Scott B.
Offline Offline
WWW
« Reply #7 on: April 26, 2012, 09:58 PM »
It has been said, " The BEST measure of someones intelligence is if they independently come to the same conclusion you did".   I think the 90 is the most Versatile sander on the market today.   Now if they would make  RTS/ETS 400 lock on pads to use in the orbital mode Wink
Actually, I was just telling someone the other day that if the DTS could mount up to a RO125, that might be Nirvana. And, it would finally mean that there was another rig for the DTS to share abrasives with.
Alan m
Offline Offline
« Reply #8 on: April 27, 2012, 03:31 AM »
i have a ro90 . it is a great tool for small flat areas and corners. ro150 for biggger areas. wish i bought it earlier
but i agree that the ls130 (dont have one yet ) would remove most of the hand sanding ,and all those moulings ard the slowest part
now
wish list
Steve R
Offline Offline
« Reply #9 on: April 27, 2012, 09:59 PM »
Glad it works for you....  I love my RO90...as the 90mm and delta (93 DX paper size) head get into places others can't.
Cheers,
Steve
TurnagainD
Online Online
« Reply #10 on: April 28, 2012, 03:06 AM »
I would like to see how the dts 400 compares to the RO 90 in Delta mode.  I wind up using the RO 90 more than I thought.  I eyeballed the hand sanding pads but just couldn't bring myself to forking over $75.  I went to the lumber yard and bought a couple for $3 each.  Maybe someday.
RvB
Online Online
« Reply #11 on: April 28, 2012, 03:27 AM »
I think paul marcel already did a video on that.. check out his blog.. http://www.halfinchshy.com/
here it is.. <object style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/K08MTV7JhAA?version=3&feature=player_embedded"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/K08MTV7JhAA?version=3&feature=player_embedded" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360"></object>
« Last Edit: April 28, 2012, 03:32 AM by RvB » Logged
ALLREADY GOT:Domino XL DF 700 - CS70 precisio - Kapex 120 EB - TS 55 EBQ Saw - EHL 65E - PS 300 EQ - OF 1010 EBQ - OFK 500 R3 - CTL 26 E - CTL Midi - BS 75 e-set - DTS 400 EQ - ROTEX 90 -  FS SYS/2 - FS 1400/2 x2 - FS 800/2 - FS Bag
D 36 HW RS craftsman cleaning kit - D27/D36 portable cleaning kit - RO90 & DTS 400 abrasive sys - Festool & Protool tool-box - carpenter sys - Fein supercut sys - homemade drills&drivers sys - nailguns sys5 -SYS-CART RB-SYS
WORKIN' REALLY HARD FOR: UG-KA-SET - OF 1400 - ETS 125 - ROTEX 125 - Boom Arm - FS/2 3000
Pages: [1]   Go Up
  Print
Jump to:
