Pages: 1 2 3 [All]   Go Down
  Print
Author Topic: The MFK 700 EQ, edge trimming router.  (Read 20153 times)
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« on: May 12, 2008, 04:05 PM »
  I've started my review of the MFK700. I don't have much done at this point, but I wanted to start the thread/discussion now, that way I can have input from you guys as to what you'd like to see in the review. So feel free to ask questions and/or make suggestions, after all, I'm doing this for all of you.
  Before we get started I'd like to talk a little about what is review isn't going to covered in detail, that's the cost of the tool and its "perceived value". I may talk about what makes this tool valuable to me, I'm not going to make an attempt to "sell" anyone this tool or try convince you this tool is "Easier, Faster, Smarter" than the competition's offerings. I will try to focus on the tool's unique features and capabilities, then let you decide if the MFK will be of value to your work. One last thing I'd like to say before we go any farther, as most of you already know I am a huge Festool fan. This review will not be completely unbiased, I've bought into the Festool "system", in that regard, I tend to favor tools that fit into that "system". If you feel I'm too biased in this review, call me on it, we will discuss it.
From those of you considering the MFK, I hope you feel this review is helpful. Enjoy.
 The Festool MFK 700 EQ, edge trimming just got a whole lot easier, by Brice Burrell
The MFK's horizontal and vertical bases make this a versatile tool, and not just for edge trimming. With the edge guide and a couple of shop made attachments this tool really becomes versatile. From dovetail joints to mortises, this little router is going to be a workhorse in my shop.....
I like to start off by showing "what's in the box" or in Festool's case, in the Systainer. Here it is, all packed in neatly.
 The card attached to the lid of the Systainer is something we are familiar with, I for never paid much attention to it. But take a closer look at the lower right corner........
If you have ever struggled to get the tool, its parts, cord and of the accessories back in, good news. Festool has finally decided to add a picture of all the "stuff" properly placed in the Systainer, thank you Festool.
Before we leave the subject of the Systainer, there is one more thing to point out. The clever engineers at Festool designed the insert to fit the horizontal base or the vertical base, so it doesn?t matter what base you have on the motor it will fit into the Systainer. In this picture the horizontal base is fitted to the motor(also in the Systainer is the edge guide). In the first picture on the page the vertical base is installed.
You've seen it in the Systainer, so here's a shot of it out. The US version of the MFK 700 EQ includes: motor, vertical base, chip deflector for the vertical base, 1.5 degree horizontal base, vacuum attachment for the horizontal base, sensor bearing, allen key for the sensor bearing, 1/4" collet, 8 mm collet, collet wrench, Plug-It cord, instruction manual all packed into a Systainer #2.
Text and pictures, copyright 2008, Brice Burrell
« Last Edit: August 29, 2008, 11:10 PM by Brice Burrell » Logged
tvgordon
Offline Offline
Springfield, Ohio
« Reply #1 on: May 12, 2008, 04:55 PM »
OK Brice, I have a question about the MFK 700.
Can the router be used to trim off through dowels or Dominos flush to the surface?  I'm guessing one would use the horizontal base and maybe a spiral bit?  Right now I either cut the Domino off close with a handsaw then sand it flush or I use a Ryobi trim router with a homemade base.  The router takes a while to change the base and sometimes chips a little off the Domino or I'll accidentally tip it and have to sand out the gouge.    Angry
If this router would work, what is the maximum distance the dowel could be in from the edge?
Thanks Brice,
Tom.
Brice Burrell
Offline Offline
WWW
« Reply #2 on: May 12, 2008, 05:04 PM »
Thanks Brice,
Tom.
Tom, good question. I'd say if you had the 0 degree horizontal base and the domino/dowel were close to the edge of the work piece, then yes. I can't say for certain, because I don't have the 0 degree base. BTW, the 0 degree base isn't part of the set, its an accessory, sold separately. I'll look into this and get some shots to provide a better explanation when time allows.
« Last Edit: May 12, 2008, 05:05 PM by Brice Burrell » Logged
Michael Kellough
Offline Offline
Southern New York
« Reply #3 on: May 12, 2008, 05:49 PM »
Thanks Brice,
Tom.
Nice start Brice, keep it up when you have the time.
On the dowel trimming question, could you use the regular vertical base by tipping the router over so the stub is"inside" with the bit?
Brice Burrell
Offline Offline
WWW
« Reply #4 on: May 12, 2008, 06:55 PM »
Michael, probably not, I don't think there would be enough room, the opening in the base is kind of small for that. I like this domino/dowel trimming idea, I'll look into it and include it in the review.
BTW, this is exactly what I had in mind when I asked for the members input, thanks guys.
Steve-CO
Offline Offline
« Reply #5 on: May 12, 2008, 07:18 PM »
How this would work for doing inlay work? I assume it would work well for this, any tips/technique suggestions would be great.
Any uses you can think of in combination with the MFS.
Thanks in advance for the time you put in for this and other reviews.
Forrest Anderson
Offline Offline
« Reply #6 on: May 12, 2008, 07:48 PM »
When using the Ryobi, are you using a home-made horseshoe sub-base so that you use the router like any other router, but the C-shape of the supplementary base allows you to simply slide the router over the protruding dowel? The depth of the router bit is set so that almost touches the surface, and will shear off the top of the dowel.
Brice - although one could design a horseshoe sub-base for any router, can one be easily fitted to the MFK700?
The Trend T2 Laminate Router uses the same sort of operation, but in this case the base is designed to be horseshoe-shaped from the beginning:
For rather more money, there's the Lamello Plano 45...
...shown in operation at the 4min 48sec point in this video
Forrest
Compiler of the Consolidated List of Festool Links - the place to go for Festool reviews, manuals, brochures and videos!
Brice Burrell
Offline Offline
WWW
« Reply #7 on: May 12, 2008, 08:04 PM »
I think I've come up with something, 1.5 degree horizontal base can fit onto the motor in the vertical position, this leaves the bit exposed to cut the domino/dowel. I think you'd need a bit with a short cutting length, like the Forrest has pictures in the Trend router. I haven't try it yet but it looks promising. I'll add this info to the review, thanks again guys for inspiring me to find the answer to this.
« Last Edit: May 12, 2008, 08:07 PM by Brice Burrell » Logged
Jay Evans
Offline Offline
« Reply #8 on: May 12, 2008, 08:35 PM »
Guys,
You could easily make a horse-shoe base for the MFK 700 and attach it with one 8mm flat head screw, from the bottom, (countersink the head into the sub base from the bottom) through the hole which is already in the base under the handle (on the Vertical base).  Notice the top side of the hole is made to accept (trap) an 8 mm nut, so attaching sub bases to this router would be very easy.  Jerry Work uses this hole for mounting to a MFT, but I'll bet the original design for this hole was for mounting and securing sub bases
Jay
Forrest Anderson
Offline Offline
« Reply #9 on: May 12, 2008, 09:02 PM »
That looks real neat! The gap between the ends of the horseshoe appears to be about 30mm, so it's plenty big enough for trimming dowels or tenons. Also there's a nice large base to help keep the router stable. My only reservation is the 1.5 degree tilt of that base. When the router body is mounted like you've got it, would that mean that the bottom of the router bit wasn't running parallel to the surface of the wood? The optional 0 degree base might be better for this, if it has the same mounting system.
Another question - when trimming edge lipping, what is the maximum "vertical overhang" that can be trimmed, when the MFK700 is used horizontally? In other words, what is the maximum height the edge lipping can stand up above the surface of the table?
Forrest
Daviddubya
Offline Offline
Arizona, USA
« Reply #10 on: May 12, 2008, 09:46 PM »
...Can the router be used to trim off through dowels or Dominos flush to the surface?...Tom.
Here's an alternate solution for vertical trimming:
http://www.patwarner.com/vertical_trim_subbase.html
I have a jig similar to Pat Warner's that I use with a PC trim router.  The only drawback to this approach is that it takes a while to get the bit set to the correct cutting depth, so I dedicated an old trim router to the task.
I am very interested to follow this thread, as I am thinking about selling several old routers and buying the MFK700 with the proceeds.
David W. Falkenstein
in Cave Creek, AZ, USA
Brice Burrell
Offline Offline
WWW
« Reply #11 on: May 12, 2008, 09:57 PM »
Jay, is right, you could make a large horse shoe shaped (auxiliary) base, the reason to use the 1.5 degree horizontal isn't necessarily because its better, but that you'll always have in the Systainer ready to use.
 Forrest, I think the 0 degree base would be a little better, but the fact that the bit isn't a perfect right to the work piece isn't going to effect the end result. The bit at angle will still flush cut the tenon/dowel all the same. I haven't have a chance to find the maximums the minimums of it cutting capabilities.
Steve, I think this router will be great for inlay work, its precision depth adjustment is incredible. I'll be using it with my MFS that's for sure, stay tuned.
Michael Kellough
Offline Offline
Southern New York
« Reply #12 on: May 13, 2008, 12:59 AM »
What kind of height adjustment is there in this configuration?
Eiji Fuller
Retailer
Offline Offline
« Reply #13 on: May 13, 2008, 01:13 AM »
the 0 deg base in this configuration will work best and the height adjustment is within the base itself so it should work swell.
You should get the same adjustment range of I think 15 or 16mm.
« Last Edit: May 13, 2008, 01:15 AM by Eiji Fuller » Logged
Michael Kellough
Offline Offline
Southern New York
« Reply #14 on: May 13, 2008, 11:59 AM »
Forrest
The Betterley router at the top of the page would trim dowels too and the clamps in the rest of the article are interesting.
Solid surface stufff
« Last Edit: May 13, 2008, 04:19 PM by Michael Kellough » Logged
greg mann
Offline Offline
« Reply #15 on: May 13, 2008, 12:48 PM »
Judging from what I see of the set up Brice has made for trimming dowels I would extrapolate that the zero degree base, used vertically, would be great for inlay work because it would give you a window through which you can see!
Greg Mann
Oakland, Michigan
tvgordon
Offline Offline
Springfield, Ohio
« Reply #16 on: May 13, 2008, 04:54 PM »
Forrest,
That is exactly what I'm using - a horseshoe shaped base on the trim router.  If I would make another base, I would cut a "C" out of a piece of rectangular plastic as to have more stability when cutting.  It seems I never fail to tip the router a little on one of the cuts.
But, the way Brice has it set up in the photo, it looks like the Festool router could be used in the same manner.  The horizontal base would help keep the router steady during a cut.  Thanks Brice.
Tom.
Brice Burrell
Offline Offline
WWW
« Reply #17 on: May 13, 2008, 04:58 PM »
OK, guys, I wasn't thinking straight last night. The 1.5 degree horizontal base used in the vertical position won't hold the at 1.5 degrees off. The horizontal base in the vertical position mounts differently in that position, in a different set of mounting holes in the base. I believe it would at a right angle to the work piece in the vertical position.
Eiji is right, you'll have the same 15 mm of adjustment.
Greg, thats a good idea, I'll try it out.
joraft
Offline Offline
« Reply #18 on: May 13, 2008, 05:25 PM »
I didn't order the 0 deg. base with my MFK 700 because I wasn't sure it would be worth the price. It will be interesting to see what uses for it are discovered as this router gets into more hands.
John
John
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #19 on: May 13, 2008, 05:28 PM »
Come on guys.... I promised myself that I wasn't gonna buy this router.  Then there's Jerry showing how to mount it to an MFT or a guide rail, and now Brice is coming up with all kinds of ideas.  I feel a burning sensation near my checkbook. Shocked Shocked
BTW, when the Bosch Colt first came out, the standard demo involved the salesrep using it to trim the print off his business card without tearing up the paper.  Routers are definitely the way to trim plugs.
At school we use bamboo skewers as plugs to keep veneer positioned precisely while its being pressed.  The "right" way to do it (e.g. the schools way) is to drill the hole, apply glue and veneer, stick in the plug and trim the plug with a flush cut saw.  Wasting precious 'open time' on a flush cut handsaw always drove me crazy, so at home, I trim the pegs with a small router.  Wayyyy faster.
greg mann
Offline Offline
« Reply #20 on: May 13, 2008, 05:36 PM »
Brice,
I checked it out. The vertical orientation in the 1.5 deg base is 1.5 off vertical. It still could get you very close as a dowel trimmer.
Greg Mann
Oakland, Michigan
Remodelboy
Offline Offline
« Reply #21 on: May 13, 2008, 05:48 PM »
Brice,
Nice write up - keep going!
I have a PC router with an adapter from Bettersly that I use to trim edgebanding.  It does a nice job, but you can only use a "V" type of bit and the bit seems to get gummed up with the adhesive from the edgebanding.  I'm considering upgrading if only for the superior dust collection.
Do you need to use a special (expensive) Festool bit to trim edgebanding and is there any reason to believe that the adhesive on the edgebanding will not gum up the bit in the same way that the "V" shaped bit gets gummed up?
Thanks,
Roland
Brice Burrell
Offline Offline
WWW
« Reply #22 on: May 14, 2008, 08:53 PM »
Brice,
Thanks,
Roland
Roland, pretty much any edge trimming bit will work in the MFK, so no, you don't have to use a "special" Festool bit. Unfortunately, when trimming edge banding the adhesive "gum up" is always an issue.
Brice Burrell
Offline Offline
WWW
« Reply #23 on: May 14, 2008, 08:57 PM »
The vertical base and the 1.5 degree horizontal base can be changed without tools, one thumb screw mounts the bases to the motor. This design makes swapping bases fast and easy, two things all woodworker can appreciate.
The motor unit, 720 watts (6 amps) with MMC electronics, this gives the MFK features that include, soft start, variable speed, thermal overload protection and constant speed under load. For those of you with the Trion barrel grip jigsaw the MFK's motor unit will look and feel familiar, its the same motor and housing. The power switch and spindle lock are also seen in this picture. I was surprised at the power the MFK has for a 6 amp motor, it cuts grooves and the female portion of sliding dovetails joints with relative ease.
The back end of the MFK, Plug-It cord and variable speed control.
The motor unit has two studs for attaching the bases. One stud has a notch in it, this stud goes in the hole with the thumb screw on the base.
The motor unit's two mounting studs insert into the holes in the base (vertical base show here).
Tighten the thumb screw and the base is attached, very simple.
More to come......
« Last Edit: August 29, 2008, 11:11 PM by Brice Burrell » Logged
tvgordon
Offline Offline
Springfield, Ohio
« Reply #24 on: May 18, 2008, 12:28 PM »
Brice,
I had a chance to see the MFK 700 this weekend.  I placed the motor in the horizontal base, and unless you have a really short bit, I don't see how it would work for trimming dowels flush.
Tom.
Brice Burrell
Offline Offline
WWW
« Reply #25 on: May 18, 2008, 12:40 PM »
Brice,
Tom.
Tom, you're right, you need a short bit. There are plenty of bits that will work, its just matter of owning them and I do. I'll include pictures of my setup in the review. I'll be adding more today.
Michael Kellough
Offline Offline
Southern New York
« Reply #26 on: May 18, 2008, 01:21 PM »
Brice,
I must not have been paying attention when this was discussed but,
1. what is the purpose of the 1.5 degree tilt
2. what kind of bit do you use?
3. are there any US designed router that do this, if so which?
4. or, do we just use special bits in a different way in NA?
Roger Savatteri
Offline Offline
WWW
« Reply #27 on: May 18, 2008, 01:55 PM »
The answer to the reason for the tilt is a clever solution when applying a hardwood trim piece to a veneered ply and then going back to mill the edge next
to the veneer without gouging the veneer surface. 2. I don't have one yet, and 3. I'm personally not aware of a US manufacture that does this, I'm not even sure
if  VIRUTEX Tools does this. (a French company that focuses on trimming tools for the professional)  4. personally getting to the final passes in the past I would have used
hand plane.
« Last Edit: May 18, 2008, 02:03 PM by monte » Logged
Los Angeles, California
Brice Burrell
Offline Offline
WWW
« Reply #28 on: May 18, 2008, 02:00 PM »
Michael, the 1.5 degree horizontal base tilts the base 15. off the centerline of the bit, this produces a very slight chamfer. The purpose this to prevent cutting into the horizontal surface when edge trimming. Here's a model, veneer plywood with edge banding, the bit is held at 1.5 degree (exaggerated angle in the model) to prevent cutting the face veneer.
No special bit needed and I don't know of any other router that does this.
Roger Savatteri
Offline Offline
WWW
« Reply #29 on: May 18, 2008, 02:18 PM »
just checked,
The French (Virutex) does make a 1.5 degree cant on its trim router (& adjustable up)........http://www.virutex.com/Tiltable_Trimmer.html
monte
ps. hmmm, a sense a comparitive Festool MFK 700 / Virutex FR292R review in the future.  Cheesy Cheesy Cheesy
« Last Edit: May 18, 2008, 02:57 PM by monte » Logged
Woodenfish
Offline Offline
G2
« Reply #30 on: May 18, 2008, 03:25 PM »
The Virutex looks like a nice trimmer but it lacks dust collection. I've been doing a lot of laminate work with
my Bosch Colt lately and can attest how much better life would be if I could capture the dust at the tool.
I just purchased the new MFT/3 plus a bunch of other accessories leaving me somewhat cash poor. The MFK 700 EQ
is on the horizon as the next addition for me. Luckily, this is a hobby and not an occupation.
Michael Kellough
Offline Offline
Southern New York
« Reply #31 on: May 18, 2008, 03:40 PM »
Thanks for the cool illustration Brice. But, if "The vertical orientation in the 1.5 deg base is 1.5 off vertical" isn't the bit in the illustration 90 degrees off axis?
Or, are there two ways to install the motor in that base?
If so, why?
I'm afraid I'm asking basic questions now and haven't done my homework.
If you can put motor in the 1.5 d base in a vertical orientation then it might be better to use a bit like the one in Forrest's post and run the router so the edge band is sheared in the direction of the broad surface. This might reduce tear-out and chipping.
Michael Kellough
Offline Offline
Southern New York
« Reply #32 on: May 18, 2008, 03:41 PM »
just checked,
monte
Tilt-ability is very cool!
Woodenfish
Offline Offline
G2
« Reply #33 on: May 18, 2008, 03:52 PM »
Brice,
Thanks,
Roland
Have you tried using the trimmer bits with the Euro square bearing? I really like those.
Them or the regular solid carbide single flute cutters work well on gummy plastic laminates
when used with a spray can of Lami-Lube.
Will any of these bits matter with the way the cutter is held?
Will use of lubricants for plastic laminates be necessary?
Michael Kellough
Offline Offline
Southern New York
« Reply #34 on: May 18, 2008, 04:09 PM »
just checked,
monte
This model seems to have dust collection covered.
See also this reasonably priced work piece holder stand.
« Last Edit: May 18, 2008, 04:13 PM by Michael Kellough » Logged
Woodenfish
Offline Offline
G2
« Reply #35 on: May 18, 2008, 06:05 PM »
Did you notice that model you referenced has a 5/16" collet only?
The MFK 700 has a 1/4" plus an 8mm collet included which seems like a more useful tool.
Brice Burrell
Offline Offline
WWW
« Reply #36 on: May 18, 2008, 07:08 PM »
The vertical base can fit up to a 1" diameter bit. On he US version, the base is threaded (tapped) for standard Porter Cable style guide bushings (now if I could only find metric sized PC bushings). Phenolic base to prevent scratching the of work surface.
With guide bushing you can use the MFK with dovetail jigs, templates and of course, the MFS template system.
The vertical base has a chip deflector with a vac port, one thumb screw attaches the assembly. Vac port fits both the D36 and D27 hoses.
A view from the top of the vertical base, you can see one of the two attachment points for the edge guide (arrow far left), the vac port built into the base, fits the D27 hose (arrow upper center) and one of the four bit centerlines (arrow lower right).
« Last Edit: August 29, 2008, 11:12 PM by Brice Burrell » Logged
Michael Kellough
Offline Offline
Southern New York
« Reply #37 on: May 18, 2008, 08:59 PM »
No I didn't notice. That's too bad.
Eiji Fuller
Retailer
Offline Offline
« Reply #38 on: May 21, 2008, 08:42 AM »
Brice,
I am interested in the 0 deg. horizontal base. Will you be reviewing that as well? Is there room in the systainer for it? it looks a lil tight.
The 0 deg base is needed if you apply your veneer after edge banding. It would also be useful in trimming edge banding around an outside corner since with the 1.5 deg base the bit height would be too high to cut the banding flush as you go around the corner.
Eiji
Brice Burrell
Offline Offline
WWW
« Reply #39 on: May 21, 2008, 05:46 PM »
Brice,
Eiji
Eiji, I don't have the 0 degree horizontal base so I can't comment on it. I'd say you're right, no room in the Systainer for the 0 degree base.
Eiji Fuller
Retailer
Offline Offline
« Reply #40 on: May 26, 2008, 10:11 PM »
Brice,
I'm anxiously waiting for more. Grin
One more question. How is the DC when using the guide bushing? It seem like there is nowhere for the chips to go when the bit is in the bushing hole. I was wanting this router for hinge prep.
thanks Eiji
Brice Burrell
Offline Offline
WWW
« Reply #41 on: May 26, 2008, 10:47 PM »
Eiji, sorry, I've been wasting time, it won't happen again.  Wink I'll get more of the review up tomorrow evening. Let me take a closer look at hinge mortises with the MFK before I comment on it here. First thing after work tomorrow I'll check a few different bit/bushing combination and report back.
Brice Burrell
Offline Offline
WWW
« Reply #42 on: May 27, 2008, 10:16 PM »
Brice,
thanks Eiji
  As promised, here the results while routing a shallow mortise like for a hinge. I used the MFS and MFK with a 1/2" bit/3/4" bushing, with the MFS template overhanging the edge of the stock, where the barrel (where the hinge pin goes) part of the hinge over hangs the door. the dust collection is only fair to poor. With the template closed with a backer block (like Eiji's did in his door project, bottom pic on reply #102) the DC is excellent, very, very close to 100%.
  If this doesn't make sense to anyone don't worry I'll be including pictures in the review that will it what I said clear.
« Last Edit: May 27, 2008, 10:19 PM by Brice Burrell » Logged
Eiji Fuller
Retailer
Offline Offline
« Reply #43 on: May 28, 2008, 03:17 AM »
Brice,
when using templaco templates the hinge plate holes in the templates are only 1/8" over size so the bit has to fill nearly the entire ID of the bushing. have you tested with that config.?
Thanks,
Eiji
greg mann
Offline Offline
« Reply #44 on: May 28, 2008, 09:19 AM »
Eiji,
If you use an up-spiral bit that has flutes going up through the bushing I think you will get good DC. The flutes help to channel the chip upward in concert with the vacuum. I suspect you will get better DC than just about any other router out there. Not many 'trim routers' have DC built in.
Greg Mann
Oakland, Michigan
Eiji Fuller
Retailer
Offline Offline
« Reply #45 on: May 28, 2008, 01:52 PM »
Good idea Greg, thanks.
Brice Burrell
Offline Offline
WWW
« Reply #46 on: May 28, 2008, 03:14 PM »
Brice,
Thanks,
Eiji
No, not yet. Let me know what size you use and I'll try that combo just for you (since it looks like you may be getting a MFK very soon).
Steven in Iowa
Offline Offline
« Reply #47 on: May 28, 2008, 07:04 PM »
Brice,
Thanks,
Eiji
Brice,
  With the way you do your reviews, it makes it very difficult not to buy one of everything.  You come up with more undocumented ways of using Festools, that I imagine even the Engineers at Festool hold their breath for the next installment.
Rookie to be sure!
Brice Burrell
Offline Offline
WWW
« Reply #48 on: May 28, 2008, 08:44 PM »
I tried a 1/2" bit with a 5/8" bushing. As you might has suspected the DC isn't as good, but only when the router is not completely covering opening in the template, as in the picture below.
However with the MFK's base coving the template like the picture above, the DC is nearly 100%.
Here's a pic to show what I meant about the template being open, this allows dust to escape from the opening and the DC is fair to poor.
Anytime the template is enclosed on all sides the DC is excellent like it is in this pic or with Eiji's backer block idea.
  There is good news and bad news about this review. First the bad news, I'm going to be delayed  even more in getting this review done. Now the good news, you are going to like why its being delayed.............
« Last Edit: May 30, 2008, 04:06 PM by Brice Burrell » Logged
Eiji Fuller
Retailer
Offline Offline
« Reply #49 on: May 31, 2008, 11:40 PM »
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
You must mean we are going to be jealous. Cheesy
Tinker
Offline Offline
« Reply #50 on: June 02, 2008, 05:16 AM »
Brice, The good news for me has been that I am slowly getting caught up with some of my outside work, and have had a little more time for lurking on the FOG.  This morning, I have had enough time to read thru this entire thread and was really getting interested in your report.  Also some very interesting points brought up by others.  I was really getting excited.
The bad news:  That box does NOT look like something to go with the MFK 700.  Now, I suspect it contains something I have been ?persuading? myself I do not need.  Come on, my friend, give me a break.  How can I ignore when you keep coming up with these great reviews.  And I am sure that box contains your next review source.
I will just find it necessary to go back to searching for more info for my landscaping projects.  It is much safer for me.
Tinker
Wayne H. Tinker
Brice Burrell
Offline Offline
WWW
« Reply #51 on: June 02, 2008, 05:39 PM »
Tinker
Tinker you are right on all three accounts....Sorry, get your Festool Visa ready.
Cannuck
Offline Offline
« Reply #52 on: June 04, 2008, 08:15 PM »
Brice... nice review.  At this rate, I'll have to trade my Green Visa in for a Black American Express.
Hindsight is like foresight, but with no future.
Mark Carlson
Offline Offline
Los Angles, CA
« Reply #53 on: June 05, 2008, 02:26 PM »
FYI,
I sent microfence and email asking if they had any plans for an adapter for the MFK-700.
The response was they should have one within the next couple of weeks.
Brice, I'm enjoying your review and might just have to get yet another router.  Thanks.
~mark
joraft
Offline Offline
« Reply #54 on: June 05, 2008, 03:17 PM »
That's good news! Thanks, Mark.
John
John
woodgeek
Offline Offline
WWW
« Reply #55 on: July 11, 2008, 03:31 PM »
I have an upcoming project involving a number of veneered panels.  After my stint at the Inside Passage school, I (like Eiji) like the idea of veneering the panels *after* I put the edgebanding on.  So if I buy the MFK 700, I would get the 0 degree horizontal base.  Has anyone used this yet , especially a similar technique to what I intend?
Carl
no matter where you go, there you are...
lat
Offline Offline
« Reply #56 on: July 13, 2008, 05:17 PM »
I make a frequent use of veneered maple and oak plywood (very thin veneer!) to which I apply 1/4" hardwood edging. For years I have used a Lamello Cantex lipping planer which does a perfect job of planing the edging flush to the veneer without digging into it. I recently bought an MFK700 for other purposes (round-overs and various edge treatments) and I love it. However, I experimented planing hardwood edging using the 1.5deg base and so far I have been disappointed with the results. First I find the adjustment very critical (with thin veneer). Too much in, and I dig into the veneer / too much out and I leave a small residue to be sanded or scraped away. Also any variation in the thickness of the edging material causes the bit to gouges into the veneer as it it registers against the thickness of the edging (the Lamello Cantex registers against the veneer and is extremely ease to adjust reliably). I don't know if I am missing something or if my technique leaves something to be desired but I am interested in the findings developping on this thread. My assessment so far is that the Cantex is way superior at lip-planing but is a single purpose tool. The MFK700 is a very versatile tool and the best lightweight router I have ever used. I am curious to learn about uses for the 1.5deg base,
Louis
Lou
polarsea1
Offline Offline
« Reply #57 on: July 14, 2008, 02:36 AM »
Has anyone else tried trimming solid wood edging with this machine? Results?
When I saw the MFK 700 I thought it would be perfect for that application.
polarsea1
Offline Offline
« Reply #58 on: July 15, 2008, 02:26 AM »
Nada???
Brice Burrell
Offline Offline
WWW
« Reply #59 on: July 15, 2008, 09:02 AM »
The MFK is made for this application. With the 1.5 degree base trimming solid edging is easy.
polarsea1
Offline Offline
« Reply #60 on: July 15, 2008, 01:41 PM »
Thanks Brice, I'm a little concerned because of Louis' (lat) post. Maybe there's a learning curve.
CharlesWilson
Offline Offline
« Reply #61 on: July 16, 2008, 12:10 PM »
I'm just musing here, but what if you had a bottom plate (the melamine thing at the base of the router) that was tapered at 1.5 degrees in the other direction? Wouldn't that make an easy switch to a 0 degree base?
You could use the existing bottom plate as a template guide for cutting its profile, and then put a 1.5 degree angle on it.
The only drawback, now that I look at the tool in my hands, is that the bottom surface of the 1.5 degree base is not screwed on, but bonded to the base plate. Some other mounting arrangement would need to be devised.
« Last Edit: July 16, 2008, 05:39 PM by CharlesWilson » Logged
Charles Wilson
Pages: 1 2 3 [All]   Go Up
  Print
Jump to:
