Pages: 1 2 [3]  All   Go Down
  Print
Author Topic: The MFK 700 EQ, edge trimming router.  (Read 20184 times)
polarsea1
Offline Offline
« Reply #60 on: July 15, 2008, 01:41 PM »
Thanks Brice, I'm a little concerned because of Louis' (lat) post. Maybe there's a learning curve.
CharlesWilson
Offline Offline
« Reply #61 on: July 16, 2008, 12:10 PM »
I'm just musing here, but what if you had a bottom plate (the melamine thing at the base of the router) that was tapered at 1.5 degrees in the other direction? Wouldn't that make an easy switch to a 0 degree base?
You could use the existing bottom plate as a template guide for cutting its profile, and then put a 1.5 degree angle on it.
The only drawback, now that I look at the tool in my hands, is that the bottom surface of the 1.5 degree base is not screwed on, but bonded to the base plate. Some other mounting arrangement would need to be devised.
« Last Edit: July 16, 2008, 05:39 PM by CharlesWilson » Logged
Charles Wilson
Pages: 1 2 [3]  All   Go Up
  Print
Jump to:
