Author Topic: TS 55 Blades and Aftermarket Alternatives, Sharpening, Etc.  (Read 5392 times)
Offline w802h
Hi Folks, I was hoping to start an updated thread on the subject of TS 55 blades.  I really like performance of the Festool 48 tooth blade, and use it primarily for veneered sheet goods, but blades have come back from my local sharpener in an unacceptable condition.  I've been thinking about trying the Forrest blades which would standardize all my shop blades.  Does anyone have experience with these blades?
I've also used the Oshlun 28 tooth blade for site work tasks like cutting sheathing or making straight cuts in flooring for new wall plates.  It's nice having a more disposably-priced blade where I might encounter nails, etc.  It seems that when I move away from the Festool line of blades I don't quite get the same kerf line on my rails or maybe it was just time to replace the splinterguard anyway?  Do others have this issue?
Are there other blades like Freud, etc. that people like?  I'm curious about other's experiences and knowledge.  Thanks!
Offline w802h
Re: TS 55 Blades and Aftermarket Alternatives, Sharpening, Etc.
« Reply #1 on: January 24, 2016, 09:27 AM »
A similar thread was revived while I was typing.  I still hope that some of these questions unique to this thread can be discussed.
Offline rst
« Reply #2 on: January 24, 2016, 10:49 AM »
I use the AGE blades which I buy from Toolstoday.  I work primarily with plastic and aluminum and those are the blades I keep in all my saws...55, 75, 12" Makita slider, 10" Makita chop, Powermatic 66 and an old 10" Delta tilting table that I converted to to tilting arbor.  I never change out blades, even when cutting oak.
Offline Staniam
  • Enjoy what you do. Build something.
« Reply #3 on: January 24, 2016, 12:25 PM »
Do you have a recommendation for a blade to cut laminate by any chance?
LA Lakers - Oakland Athletics
The Arsenal: Festool - PDC, CXS, RO 125, TS55 REQ, OF 1010 EQ, CT MIDI;  Bosch - JS572EBL, JS120, 1294VSK, PS22
« Reply #4 on: January 24, 2016, 12:38 PM »
I'm a firm believer in Forrest blades and used them exclusively when I had Milwaukee chop & slider saws. I still use a thin kerf Forrest in my table saw and like it a lot.
When I purchased the TS 55 & Kapex however, I just stayed with the stock Festool blades because they work well and I had no reason to change something that works.
If you like the performance of the Festool blade, why not just send it in to Leitz and have them resharpen it? They have several service centers in the US & Canada.
http://www.leitztooling.com/sharpening-services.htm
Offline Dangermouse
« Reply #5 on: January 24, 2016, 02:25 PM »
in the UK, I use the trend craft range blades for my ts55, available in 28t and 48t versions, reasonably cheap too
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #7 on: January 24, 2016, 07:26 PM »
I would look for a new sharpener.  There's nothing magic about Festool blades.  Mine always come back in great shape.
Offline ProtradeUK
« Reply #8 on: September 28, 2017, 08:57 AM »
Afternoon chaps, thought I'd revive this old thread. We are a UK based Festool dealer and have recently conducted market research and tests with our own brand plunge saw blade which have proved to be very positive to say the least.
If you'd like more information or based in the UK and interested in purchasing here's a link to the current offers we have running.
http://www.protrade.co.uk/credible-alternative-to-the-festool-ts55-plunge-saw-blade.aspx
Cheers
Protrade
Offline 1toolshort
    • Big Bob's Carpentry
« Reply #9 on: October 04, 2017, 02:29 PM »
my buddy swears by Tenyuru (sp???) on his.  1/2 the price, he says and better cut.  I doubt the better cut, but I looked it up and they are about 1/2 the price.  160mm I think is the answer....
ts-55 track saw; Rotex 125; mini vac; multi function table 3; cordless drill; domino,orbital sander 400; DWC-18
Offline 1toolshort
« Reply #10 on: October 04, 2017, 02:44 PM »
From another post in tis forum.....
The Tenyru Finish blade (miter pro plus I believe it's called) for the Kapex makes it a better saw IMO. Been running it for a few years and love it. only swap into the factory  blade when I frame or do a deck. But mostly keep that blade on there. Forrest is awesome as well, last I checked though they didn't make a finish blade for the Kapex, maybe they do now. But the Tenyru is about as good as it gets and it's angle tooth which I prefer, not as grabby as the Festool blade.
Same story with the TS 55
Offline Bob D.
« Reply #11 on: October 04, 2017, 04:22 PM »
Having just read the jig saw thread that talked about warranty issues could arise from using non-Festool blades I think I will stay away from third-party blades with my TSC55.
Does this apply to all their sanders too? I can only use Festool sandpaper if I want my warranty to be honored?
Guess I can only use Festool bits in my router and drill/driver too.
Offline Holmz
« Reply #12 on: October 04, 2017, 04:52 PM »
[eek] ^ I have an MT55  [cool]... I have probably saved the difference in machine price already  [big grin]
I was looking for some indication that your post was sarcastic (since we find faults in others that we have in ourselves  [wink] ), but I believe you are serious?
Thanks for the earlier recommendation on the Forrest brand for veneer.
Offline Cochese
    • The 144 Workshop
« Reply #13 on: October 04, 2017, 04:55 PM »
People are taking the warranty thing to absurd levels.
Offline antss
« Reply #14 on: October 04, 2017, 05:08 PM »
I like the Freud lineup for a "budget" blade.
Sharpening FT blades should be done through Leitz.   I've had good luck with BURNS, but I think factory is better.
Forrest is hit or miss this century, especially sharpening other folks' stuff.  They certainly aren't budget blades looking for a nail.  And no one that I know of has said a Forrest blades are BETTER than an OEM blade.  Which begs the question : why chance it ?
Personally , I think metric blades should be bought from companies who think in metric.  And that isn't Forrest.  No scientific evidence to substantiate that though.
Offline SRSemenza
« Reply #15 on: October 04, 2017, 07:25 PM »
Yes, I agree.  Especially in regards to attempting to make every relate-able topic on the forum into a topic on the warranty.  If you want to discuss the warranty denial conditions please do so in the topic on that subject.
Link to bit and blade warranty discussion  Warranty Discussion
« Last Edit: October 05, 2017, 12:30 AM by SRSemenza »
