JerrySats
Offline
« on: July 30, 2012, 04:32 PM » |
My next tool purchase is going to be this sander for my finish sanding work . Which would you all recommend between the two ?
Thanks Jerry
hhh
Offline
« Reply #1 on: July 30, 2012, 04:34 PM » |
I use a /5 to about 120 or so and /3 for 150 and above. I put the 'hard' pad on the /5 and the 'soft' pad on the /3.
Festool: Everything available in USA except: Air Sanders, Planex, CMS, MTF and Planers. Lots of Porter Cable routers. Several Milwaukee, Hilti and Hitchi industrial drills, demo hammers, etc. Bosch drivers and drills. Mirka air sanders. Complete custom furniture shop with significant investment in Powermatic & Felder stationary tools...
davee
Offline
« Reply #2 on: July 30, 2012, 04:41 PM » |
I think this would depend upon what others sanders you have. I have the RO150 and the ETS 150/3. I don't feel the need for the 150/5 as the RO150 covers this. If I didn't have, or plan to have the RO150, then I would probably purchase the ETS 150/5.
hhh
Offline
« Reply #3 on: July 30, 2012, 05:02 PM » |
the RO150 is not a 'fine' sander... The /3 is can leave a 'fine' surface (depending on your exact definition of fine) - there are limits to what a RoS can do.... The /5 with 120 to 150 can leave a pretty nice surface, but not 'fine' --- the scratch pattern on the /5 is really not compatible with 180 and above...
Kev
Offline
« Reply #4 on: July 30, 2012, 05:29 PM » |
You can achieve fine sanding with the ROTEX - it's just bigger and more awkward. When you look at the festool sanders, you also need to think in conjunction with their abrasives and sanding classifications. All sanders mentioned thus far in this thread can achieve "fine" sanding. There's a Festool document that explains the classifications by sander (I'm not talking about the sage decision tree) ... If I can locate it I'll post back.
windmill man
Offline
« Reply #5 on: July 30, 2012, 06:06 PM » |
150/3 will give the best results for finish sanding. Rotex and 150/5 have to big of an orbit
hhh
Offline
« Reply #6 on: July 30, 2012, 06:23 PM » |
FT Sales/Marketing literature aside, ROTEX is not for 'fine' sanding... full stop.
jmarkflesher
Offline
Scoot
« Reply #7 on: July 30, 2012, 06:31 PM » |
150/3 for fine sanding and a fine finish. Ro 150 to take off lacquer and paint. both 6 inch paper. Call Bob Marino to give you all the info 1-866-FESTOOL. MARK
DEC 21st, 2012 TIC TIC TIC WAS A DUD
ccmviking
Offline
« Reply #8 on: July 30, 2012, 09:35 PM » |
The only difference in these two sanders is the speed in which they can get the work done and the vibration they transmit to your hand. The sandpaper is what leaves the surface on your material and the sander just moves the paper. The 150/3 will not leave a better surface than the 150/5 and I know a lot of folks use the 150/5 (again for the speed at which they can get the sanding done) however, I have used both long term and my very favorite sander is the 150/3. It's just noticeably smoother in use, and does a great job sanding anything I've tried to sand with it.
Chris...
jmarkflesher
Offline
Scoot
« Reply #9 on: July 31, 2012, 04:18 PM » |
I disagree with ccmviking. The orbit of the 150\3 is smaller than the orbit of the 150\5 thus using the same grit sandpaper the 150\3 will have a finer surface finish.
hhh
Offline
« Reply #10 on: July 31, 2012, 04:54 PM » |
As stated previously, the /5 will get you a nice surface, but not a fine finish. The 5mm pattern is too large.... Full stop.
The /3 will get you far closer in the 180/220 range, but RoS taps-out around there -- it's not a FT thing, but just the nature of the technology. At some level, you can't get a really fine surface with RoS at all, but that is another post...
As an experiment, take a /5 and /3 to a lacquer table top with 320 and look at the scratch pattern... Now go over the surface with an R2E or 400 -- see the difference? Now rub-out by hand with #0000 -- see the difference? If you work with fine finishes, these differences are very noticeable to the customer... Things change when you move from wood to production/automotive/solid surface/etc - this is the realm of the DO, but that's a different animal...
« Last Edit: August 01, 2012, 12:10 AM by hhh »
ccmviking
Offline
« Reply #11 on: July 31, 2012, 05:06 PM » |
You can by all means disagree but it still won't make you right. The paper is what puts the finish on the wood, not the sander. What stroke do you use when hand sanding? Can you get a fine finish hand sanding? The sander is just moving the paper. You can get a "fine" finish with either or those sanders and I'm sure you'd be happy with either of them. Chris...
hhh
Offline
« Reply #12 on: July 31, 2012, 05:09 PM » |
==> what stroke do you use when hand sanding?
There is a good book put out by Taunton on sanding.... Your questions are all answered there... More time learning, less time typing...
JerrySats
Offline
« Reply #13 on: July 31, 2012, 05:38 PM » |
This will be my only Festool sander for a while , I have a 5" RO ridgid sander . No plans on buying a Rotex Festool sander anytime soon .
windmill man
Offline
« Reply #14 on: July 31, 2012, 07:03 PM » |
Jerry,
Take what you will, from the advice in this thread. 150/3 is the sander you need for a fine finish. Its that simple. It is a very well balance machine that will serve you well. You will be able to sand any materials from woods (finished / unfinished) to resins and plastics and get flawless swirl free results.
I think certain individuals should review there advice.
Festool make the 5 for general sanding and the 3 for fine sanding.
If you dont believe me take both sanders with the same grit paper(high grit count) and sand any solid surface product . You will imediatley see the difference the 5 will leave a smoth surface with a swirl pattern and the 3 will leave a smoth surface with no noticale swirl ( unless you get the microscope out) This is why you will find the 3 in body shops.
If you are still undecided make use of the 30day return policey
John
jmarkflesher
Offline
Scoot
« Reply #15 on: July 31, 2012, 07:07 PM » |
You can by all means disagree but it still won't make you right. The paper is what puts the finish on the wood, not the sander. What stroke do you use when hand sanding? Can you get a fine finish hand sanding? The sander is just moving the paper. You can get a "fine" finish with either or those sanders and I'm sure you'd be happy with either of them. Chris... Chris, I'd agree with you if you were right. He is not looking at an in-line sander but the 150/5 or the 150/3. MARK
Christopher Robinson
Offline
« Reply #16 on: July 31, 2012, 07:30 PM » |
My two cents on sanders in general maybe you can extrapolate something that helps you RO 150 FEQ-->Large surface workhorseThis has been my goto workhorse (use it for 80% of my job due to time savings) for large surface projects that don't require an absolutely exquisite finish. If I follow my grits from a stronger grit all the way down to the finer grits and follow with the sheepskin grit, I can make a piece of wood SHINE without even applying a finish with this sander. So no scratch patterns if you can go fine enough in grit (but sometimes you can't go that fine in grit because you can't apply finishes as effectively if you go down to fine on your grits---i.e. the need for a finer finish sander that can get less scratch pattern at a higher grit). Gets most of your sanding done on large pieces FAST (which is why it is my goto workhorse). RS 2 E-->Large FLAT surface fine sanderDoes better on large flat surfaces (I think this is due to the circular edges of sanders with a circular pad digging in ever so slightly into the worksurface...RS 2 E won't do that.). It also has very fine sanding stroke so will not leave any scratch patterns---not as fast even with higher grit, but it is a finisher for sure. RO 90 DX-->Smaller surface workhorseFor surfaces that don't have a wide surface, this sander is easier to hold and still gets the job done FAST like the RO150---can also get into corners, angle it around things, with a little creativity and soft pads and applicators, you can even do some profiles. ETS 150/3Great finisihing sander, use this where RO leaves off for those exquisite finish requirement projects. Easier to control for fine finish (RO150 is not as easy to keep from "getting itself into the work surface" as it is shaped/balanced more for removal efforts in my opinion as opposed to fine finish---it can be done, but its easier to mess up with the RO150.) Hand scrapers shouldn't be overlooked: Good Hand ScrapersGood Gooseneck Hand ScrapersSaves on paper. It also has the ability to save you time as you don't have to cycle through the grits---it does take some practice and it does take some elbow grease...some would argue, you get a better surface with scrapers too. For fine sanding, some people don't use machines at all O_o. Yep good old hand sanding is what I use on my 'last pass' sometimes (and only outside upwind weather permitting). Other sanders have benefits too, these are just the ones I think you might be looking at right now...and you always have that 30 days to test em' (careful you will probably keep everything you 'test' as you will see how each product will help you! )
« Last Edit: July 31, 2012, 07:34 PM by Christopher Robinson »
Scott B.
Magazine/Blog Author
Offline
Paint contractor and freelance writer.
« Reply #17 on: July 31, 2012, 07:59 PM » |
In my world, the /5 is by far the more useful tool.
Scott B.
Offline
« Reply #18 on: July 31, 2012, 08:06 PM » |
And by the way, if anyone perceives the RO sanders as being defined by their brutish material removal tendencies, you really need to see one polish out to about 10k grit. Its a mind F.
ccarrolladams
Online
Location: Hollywood, California USA Member Since: Apr 2010
« Reply #19 on: July 31, 2012, 11:11 PM » |
Back in January 2006, when I started to buy Festools, I already owned more than enough other brands of electric tools to efficiently build custom cabinets.
The precision and efficiency of the TS55 and OF1010 router were immediately apparent to me. I admit I was slower to embrace the Festool sanders. I must have tried the RO150 6 or more times at my dealer before I bought one. As I experimented with adjusting the suction volume to change the performance of the RO150, as I gained experience and confidence I felt "at one" with that sander, in finish mode.
After using my RO150 for several months, I bought the ETS150/3. My thinking was that the RO150 already had a 5mm stroke. I must say the ETS150/3 with a hard pad is my go-to finish sander then the surface is large enough. Sometime in 2007 I bought a Deltex DX93 for corners where the 150mm pads could not reach. I bought all the other non-air sanders along the way, finding uses for each. I really like the RO 90 DX with a hard pad for sanding face frames and edge banding. Early this year I did buy an ETS150/5. It turns out I like it more today than I did in 2007, especially with Granat.
Kev
Offline
« Reply #20 on: August 01, 2012, 01:17 AM » |
Depends on your definition of "fine". When you're talking Festool it makes sense to talk about it in the same relative terms as ther literature and also in conjunction with the use of their abrasives. I say it can "achieve" fine sanding - you say not. We disagree. I would only agree that is is not the ideal sander for the purpose. If you carefully read the Festool documentation, you will understand the ROTEX range of applicability. You will also see their ratings from coarse, rough, fine and extra-fine. Further, I believe Festools technical manuals are quite poor, but the sales and product material - particularly the latest 2012/2013 are excellent.
SRSemenza
Global Moderator
Offline
« Reply #21 on: August 01, 2012, 01:34 AM » |
The ETS150/5 will serve better as an all purpose sander than the /3. It is also capable of delivering and excellent finish. For about two years it was my only sander. I used it for everything. It is still my only finish sander. I use between coats, on bare wood, and used to use it for material removal and stripping. If you get it.... also get the super soft and hard pads. Along with a broad range of abrasives. Get the right type of abrasive (Rubin, Cristal, Granat , etc ) for the task too. I have yet to find one type that truly does it all. Seth
Festool Service 800-554-8741
hhh
Offline
« Reply #22 on: August 01, 2012, 01:38 AM » |
==> Depends on your definition of "fine". When you're talking Festool it makes sense to talk about it in the same relative terms as ther literature and also in conjunction with the use of their abrasives.
We disagree.
It's not 'me' saying... it's every modern text on finishing... Seriously, take a RO150 to a lacquer finish and see what happens... not pretty...no matter what abrasive (or FT document) you use... A 5mm RoS pattern is not 'fine'... ever. Not slagging FT, it's just the nature of the pattern. Just take a deep breath and spend a few minutes trying it for yourself.... There is a reason that FT makes 5mm, 3mm and 2.5mm pattern sanders... it's not like the engineers wake up one day and go, "Hay, we need one more sander... to go with the 15 we already have"... Every sander has it's place in the workflow. I've got every sander they make (3 of some and 2 of many)... The RO is not in the 'finish' part of the workflow...
« Last Edit: August 01, 2012, 01:42 AM by hhh »
SRSemenza
Global Moderator
Offline
« Reply #23 on: August 01, 2012, 02:41 AM » |
A note on the RO150 vs. ETS150/5. I have them both. Using the same abrasive and same pad I have found that the ETS150/5 produces a better finish than the RO150 (in ROS fine mode) even though they have the same 5mm stroke.
Kev
Offline
« Reply #24 on: August 01, 2012, 03:49 AM » |
Again I'll point out that Festool differentiate "fine" and "extra-fine". It's all relative, but when I'm working in the Festool system with Festool machines and consumables, I'm going to use their terms of reference.
"Every modern text ..." - LoL ... Relax - nobody is going to get chained to a finishing station with a ROTEX over this.
hhh
Offline
« Reply #25 on: August 01, 2012, 08:02 AM » |
==> A note on the RO150 vs. ETS150/5. I have them both. Using the same abrasive and same pad I have found that the ETS150/5 produces a better finish than the RO150 (in ROS fine mode) even though they have the same 5mm stroke.
I was going to bring that up, but it would really put some folks over the edge...
Dovetail65
Offline
« Reply #26 on: August 01, 2012, 10:45 AM » |
The 150/3 simply gives a better finish.
I find the RO150 with the 150/3 is a great combination. If I did not have an R0150 I probably would get the 150/5 as an all around sander.
But if you are out strictly for the best finish get the 150/3.
I must say unlike Seth I found that I could get my R0150 to give me an imperceptible difference between it and the 150/5, the reason I sold it and got an 150/3. There is a very noticeable difference between the 150/3 and the R0150, not so much between the Rotex 150 and the 150/5. At least for me, not enough difference to warrant having a 150/5 and R0150.
Kev
Offline
« Reply #27 on: August 01, 2012, 11:31 AM » |
Agree - I started with a ETS150/5 and got the RO150 and ETS150/3 later ... still like having the ETS150/5 though.
Woodenfish
Offline
G2
« Reply #28 on: August 01, 2012, 12:15 PM » |
I felt the RO 150 was just too powerful for everyday sander need, the ETS 150/3 was sweet but a tad too slow while the ETS 150/5 seemed to cut just right for me. I added a RO 90 DX to bring something different to the workbench. Having these two options have proven their versatility. One day might I pick up a RS 2 E, but I'm in no hurry.
JerrySats
Offline
« Reply #29 on: August 24, 2012, 09:48 PM » |
I just wanted to update this post , I bought the 150/3 about two weeks ago and have used it quite a bit in that time . I'm very happy with my decision to buy this model . It's been able to do rough and finish work for me . By rough I mean 80 grit and I've been finishing with 220 all in garnet , which I really like too , it's been holding up great . The 3 mm stroke leaves a super smooth finish behind .
Thanks Jerry
