Pages: [1]   Go Down
  Print
Author Topic: 36mm AS hose on CT-Midi?  (Read 1343 times)
BobKovacs
Offline Offline
« on: January 15, 2011, 10:19 AM »
Getting a Kapex this week, and read that the dust collection is much better with the 36mm hose than the 27mm. Also saw it being used with a Midi, I thought in the same review. The specs for the 36mm hose don't list it as being applicable for the Midi and Mini, so I figured I'd ask here if it's possible to use the 36mm hose with the Midi.
Roger Savatteri
Offline Offline
WWW
« Reply #1 on: January 15, 2011, 10:41 AM »
The hose on the Midi is attached to the unit through an angled connector.
Simply wiggle it back and forth while applying an upward pull, it will come out.
(get a grip of the connector - not the green hose)
It might not seem as if it will at first, but it will.
Then simply wiggle in the wider end of the 36 hose.
Whenever I'm using the Midi with an SCMS, a 2200 router or the TS75 I'm using the 36 hose.
cheers.
« Last Edit: January 15, 2011, 11:24 AM by Roger Savatteri » Logged
Los Angeles, California
tbwessel
Offline Offline
« Reply #2 on: May 15, 2012, 06:11 PM »
Hey there.
Just got my new Kapex today, and at the same time I stumbled upon this great site and this thread.
Just to make sure, that I understand correctly - the angled connector is NOT to be removed, right? It's just the hose?
Ken Nagrod
Restricted
Offline Offline
« Reply #3 on: May 15, 2012, 06:23 PM »
Yes, the right angle connector comes out.   Welcome! to the FOG!
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #4 on: May 15, 2012, 10:52 PM »
Hey there.
I'm not sure Ken's response to your question was clear.  The angled connector (with hose attached) comes out.  It can be a little difficult to pull the angled piece free from the extractor but it will come out.
Pages: [1]   Go Up
  Print
Jump to:
