PeterK
Online
« on: December 25, 2008, 11:48 PM » |
As I just received a new OF1010 from Uncle Bob, I am now looking for bits for it. All of mine are 1/2" shank now so needing some to fit this router. Would really like to purchase a bit set that has a selection of widely used ones hopefully in 8mm versus 1/4". I know everyone says to just buy them as needed but with no local supply stores other than HD and Lowes, I can't just pick them up on a whim. Any thoughts on a set from a quality manufacturer? Sure would be nice if Festool offered sets, I think they would sell. Pete
Notorious T.O.D.
Offline
« Reply #1 on: December 26, 2008, 01:04 AM » |
Can't help too much with the sets as the only 8mm bits I have are a leigh dovetail set I purchased many years ago. Mine are mostly 1/2" and some 1/4" but I would say check CMT and Bosch and maybe Freud and see what they have to offer here in the US... Many of the Festool bits seem to have 8mm shanks.
Best, Todd
quietguy
Offline
« Reply #2 on: December 26, 2008, 02:11 AM » |
8mm bits are a little hard to come by in the US, but they can be found. I don't use the 8mm bits much, unless I am at the dovetail jig. The vast majority of my bits are 1/2', which is the only reason I chose the OF1400 over the OF 1010.
I would also add Whiteside to Todd's list of manufacturers.
woodshopdemos
Inactive Member
Offline
« Reply #3 on: December 26, 2008, 02:58 AM » |
I have 8mm bits from Festool and Leigh...both excellent. If you have the Festool catalog, you will see several pages of their m,m bits. All carbide and all very good. Your OF 1010 also has a 1/4" collet. Dont use it of you can find 8mm bits. There is quite a difference witht eh 8mm shank.
In memory of John Lucas (1937 - 2010)
PeterK
Online
« Reply #4 on: December 26, 2008, 10:59 AM » |
Thanks all. I normally use CMT and Whiteside and have quite a few of the white CMT spinoff bits from Jesada. I realize 8mm is not common here but thought someone might sell a set. Most things I pull up on Google are European based stores - of course. I believe Festool had a bit set they sold a while back - at least they did on the other side of the pond as I found it while searching. While I like the choices in the Festool catalog, they are really pricey. Pete
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #5 on: December 26, 2008, 11:05 AM » |
Whiteside makes an 8mm shank set of bits for work with jointmaking jigs. These sets include straight and dovetail bits. For other profiles, members of FOG consistently rate them very highly.
Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
Markus K.
Offline
« Reply #6 on: December 27, 2008, 02:34 PM » |
Hello Peter, I think you need something like this: Routerbitsmaybe it's available in the states?? Markus
I'm from Grafenwoehr , Germany
extiger
Offline
« Reply #7 on: December 27, 2008, 03:07 PM » |
Another source in North America for 8mm router bits is www.chipsfly.com. Their bits are manufactured for use in the WoodRat. They offer a limited range -- only 3 straight bits, and an assortment of dovetail bits. The dovetails are really different, however, from carbide versions. They are quite slim, with profiles as narrow as 6?. So they joints look handmade, in contrast to the mostly crude appearing carbide-made joints. Gary Curtis
extiger
Offline
« Reply #8 on: December 27, 2008, 06:36 PM » |
Make that dovetails as slim as 6 degrees.
Sammy J
OfflineMember Since: Dec 2008
« Reply #9 on: January 07, 2009, 07:22 AM » |
In my decision making between the OF1010 and OF1400, I found a supplier of 8mm router bits at a somewhat reasonable price, unsure of there quality tho. Link Below: http://www.wealdentool.com/acatalog/Router_Cutters_1.htmlCheers
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #11 on: January 07, 2009, 11:31 AM » |
Sammy and Martin,
I went to the websites each of you posted and all I saw were 1/4" and 1/2" bits. Entering "8 mm" in the search box within their sites returned no products. Maybe I wasn't persistent enough in digging through their websites. How can their 8mm shank router bit offerings be found?
Dave R.
CabinetKid
Offline
« Reply #12 on: January 07, 2009, 02:58 PM » |
Dave R.
Unfortunately you have to wade through the online catalogue fro the individual router bits you may be interested in and then see if they list an 8mm one. Whealdon's are excellent toolmakers as are the Trnd's Professional Range(possibly sourced from Wealdon's)
Sammy J
« Reply #13 on: January 08, 2009, 05:51 AM » |
I just sent a wish list of bits off to Wealdon today, hoping they can post them to people outside of Europe (in my case Australia - not sure if the Commonwelath comrade ship would apply  ) Link to 8mm Shank straight cutters: http://www.wealdentool.com/acatalog/Online_Catalogue_8mm_shank_238.htmlThanks for you link Martin, checked them out today seems the US people are looked after, they are sold at WorkShop Tools... Also found another European manufacturer, seems they specialise in 8mm shanks http://www.jvl-europe.com/index.html, once again not sure about quality and delivery outside EU.... Cheers Sam
« Last Edit: January 08, 2009, 07:19 AM by Sammy J »
martingchapman
Offline
« Reply #14 on: January 08, 2009, 12:53 PM » |
Dave Ronyak CabinetKid is right, you need to go to the page for the individual cutter you want and it will then show what is available in what shank diameter.
Regards - Martin.
Sammy J
« Reply #15 on: January 09, 2009, 02:56 AM » |
Gentlemen,
Received a reply from Wealdon, quite impressed actually, they added Australia and New Zealand to there online website for delivery.... Also JVL replied and they ship to both US and Australia however you have to email them your request for a quote inclusive of postage.
Does anyone now which manufacturer has the higher quality router bits JVL or Wealdon?
Cheers
Sam
« Last Edit: January 09, 2009, 03:21 AM by Sammy J »
mark90
Offline
« Reply #16 on: January 09, 2009, 04:47 PM » |
check woodcraft they have festool bit sets
mrwilby
OfflineMember Since: Jan 2008
« Reply #17 on: January 14, 2009, 03:47 PM » |
Wealdon tools make excellent quality router bits. I've spent about 450gbp with them so far, and have been very impressed. Each bit is very well packaged and coated with protective material.
The bits are very sharp and produce an excellent quality cut. I use them with a 1400.
Recommended. Oh, and at least in Europe, they are far cheaper than the festool bits.
Dovetail65
Offline
« Reply #18 on: January 14, 2009, 03:50 PM » |
Wealdon won't sell to me in the US yet, at least I tried.
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #19 on: January 14, 2009, 07:24 PM » |
The only sets I have found available are those for use with Leigh jigs. I was hoping to locate sources of other profiles, beyond straight and dovetail bits. Dave R.
vkumar
Offline
Sunnyvale (near San Jose) California
« Reply #20 on: February 06, 2011, 07:28 PM » |
I too am in line to get a 1010, and would like some 8mm shank bits. Any further sources identified? Festool seems to be the only one with 8mm shanks readily available. Would be nice to have some alternates such as CMT, Whiteside, Amana etc. available stateside. Vijay
PeterK
Online
« Reply #21 on: February 06, 2011, 08:11 PM » |
Other than the Festool offerings, I have not found anything else in the US in 8mm. The Festool bits are really high quality, very sharp, long lasting. I have been using a wide variety of Freud 1/4" bits with great results. No chatter, no breakage, no complaints.
Craftsman
Offline
« Reply #22 on: February 06, 2011, 09:57 PM » |
I,m pretty sure that Felder still sells a set of 8mm shank router bits in the most common profiles. I had a set that I used in the shaper of a CF731. They were very reasonably priced..
joiner1970
Offline
« Reply #23 on: February 07, 2011, 06:55 AM » |
I just sent a wish list of bits off to Wealdon today, hoping they can post them to people outside of Europe (in my case Australia - not sure if the Commonwelath comrade ship would apply  ) Link to 8mm Shank straight cutters: http://www.wealdentool.com/acatalog/Online_Catalogue_8mm_shank_238.htmlThanks for you link Martin, checked them out today seems the US people are looked after, they are sold at WorkShop Tools... Also found another European manufacturer, seems they specialise in 8mm shanks http://www.jvl-europe.com/index.html, once again not sure about quality and delivery outside EU.... Cheers Sam Sammy I have used Wealdons for router bits for a while now they are very good quality bits better than any of the stuff Ive used so far. Not sure if they do deliver outside the UK but Im sure you would have found out by now. If you look on www.ukworkshop.co.uk/forums you will find everyone there uses wealdons thats how I found out about them. Chris
Tom Bellemare
Festool Dealer
Offline
« Reply #24 on: February 07, 2011, 01:57 PM » |
Though they aren't 8mm but rather 1/4", CMT sells a couple of very nice sets of router bits that work nicely in an OF 1010. There's a 12-piece set: and a 15-piece set: Both sets come in really nice, hardwood cases. I know that 8mm bits are beefier and therefore stronger than 1/4" bits but it isn't at all uncommon to see CNC routers running 1/4" bits. It's a feed and speed thing like with any router bit. Tom
« Last Edit: February 07, 2011, 02:06 PM by Tom Bellemare »
vkumar
Offline
« Reply #25 on: February 07, 2011, 02:06 PM » |
Tom since you happen to be a CMT dealer, can you not get the 8mm bits that CMT makes?
Also the issue is more than speeds and feeds. There is also the issue of side loads, which makes the 8mm bits much superior--it is the same reason why one would prefer to use the 1/2 inch bits if they would fit.
Vijay
vkumar
Offline
« Reply #26 on: February 07, 2011, 02:07 PM » |
Any links? Thanks Vijay
Tom Bellemare
Festool Dealer
Offline
« Reply #27 on: February 07, 2011, 02:20 PM » |
Vijay:
Unfortunately, CMT doesn't sell 8mm bits here. I guess they didn't detect a big enough market for it.
I agree about the side loading... I think it can be accounted for, within reason, by fine tuning the speed vs. feed. At least that's what I do using a CNC router. If it's chattering, my feed is too high for the speed. If it's burning, I'm not keeping the cutting surfaces cutting so they dwell and heat up, which means I either need to slow the speed or increase the feed.
With all that said, I totally agree that 8mm bits are stronger than 1/4" bits and that 1/2" bits are stronger than either 1/4" or 8mm. I just think that a bit with a small enough overall diameter is perfectly fine with a 1/4" shaft. To exaggerate the thought, I wouldn't want to swing a raised panel bit with a 1/4" shaft and I wouldn't want to pay for a 1/2" shaft on an 1/8" diameter straight bit.
This is all just my opinion so please ignore it if you think it's bunk.
Brice Burrell
Online
Remodeling Contractor
« Reply #28 on: February 07, 2011, 03:10 PM » |
....This is all just my opinion so please ignore it if you think it's bunk.
Tom, you don't need to post this, we're all used to ignoring you by now...  Back on topic, I know FOG member and all around nice guy, Chris Hughes has sources for Italian made 8mm shanks bits readily available in his area (Kalamazoo, MI). One could PM him for more info.
Wonderwino
Offline
Location: American Bison Country Member Since: Apr 2008
« Reply #29 on: February 07, 2011, 03:52 PM » |
We had a discussion about this with Brian & Shane at Router Class last April. I suggested that maybe if Festool would run some specials on sets as a promo sometime, it would spur more interest in them. they had a promo 8mm set several yars ago with a Sys1 with insert that I bought. I have since added more Festool 8mm bits to the mix as I really would rather use my OF1010 than my DW621. (I do have the OF2200 and OF1400 on my wish list.)
I am hoping they will do another set with decorative profiles this time or a combination of bits that can create common mouldings.
Water separates the people of the world; wine unites them.
