Pages: [1]   Go Down
  Print
Author Topic: Able to use the CT Cord Wrap with WCR1000 and CT handle  (Read 643 times)
TomGadwa1
Offline Offline
« on: June 15, 2012, 01:32 AM »
Ever since I installed my WCR1000 on my CT36 I was frustrated about losing the cord wrap that came with the CT36. As many have done I resorted to hanging my cord on one of the tool hooks which worked in a pinch. BUT drumroll please I figured out a way to use my lonely unused for too one cord wrap on my CT36! I am now much happier and can sleep at night once again! What I did was semi brutal in that I had to sand down the curved profile on the cord wrap. I sanded it such that it would lie flat upon a piece of plywood mounting plate. I sized the mounting plate so that it nestled into the side column of the WCR1000. I bolted the cord wrap to the mounting plate. Then I drilled holes in the mounting plate for high tech attachment method to the WCR1000 column. It fits in between the CT handle and WCR1000 column perfectly and works a treat! Here are some photos:
Showing CT cord wrapped in place.
The cord now unwrapped from the cord wrap.
View showing how the mounting plate nestles between the CT handle and WCR1000 column.
View showing top of cord wrap and high tech attachment method.
View showing bottom of cord wrap and high tech attachment method.
CT cord now happily stowed away on its original cord wrap! Now all is right with the world.
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
hhh
Offline Offline
« Reply #1 on: June 17, 2012, 08:17 AM »
great idea...  have the same setup, and always regretted the loss of the cord keeper -- i use the back single tool holder as the cord keeper...
Festool: Everything available in USA except: Air Sanders, Planex, CMS, MTF and Planers. Lots of Porter Cable routers. Several Milwaukee, Hilti and Hitchi industrial drills, demo hammers, etc.  Bosch drivers and drills.  Mirka air sanders.  Complete custom furniture shop with significant investment in Powermatic & Felder stationary tools...
Pages: [1]   Go Up
  Print
Jump to:
