Pages: [1]   Go Down
  Print
Author Topic: If you could only buy two Festool routers...  (Read 4561 times)
marrt
Offline Offline
« on: September 16, 2011, 09:58 AM »
For tax purposes, I "need" to buy some tools by year end.   Smiley  So, I was thinking about picking up a couple Festool routers.
If you could only have two Festool routers, what would you buy?  I realize this is totally dependent on use.  However, think "general woodworking use."
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #1 on: September 16, 2011, 10:09 AM »
Not sure how useful our replies will be since this is totally dependent on what you do.
I build furniture and use the router for joinery and edge treatments.  95 percent of my work is on the OF1400.  I occasionally use the OF1010 when I need to get into a smaller place or when I need two routers with different setups for a process.
If I were looking to spend $$ I would get the 1400 and lots of accessories (MFS, different bases, copy rings, bits, etc).
I have the 2200, but frankly it hardly ever comes out of the systainer.  I sold my MFK700.
If you do solid surface or lots of countertops, those two might be just what you need...
waho6o9
Offline Offline
WWW
« Reply #2 on: September 16, 2011, 10:12 AM »
The MFK700 and the OF1400 would cover the general woodworking issues.  Have fun with your new routers!
Dovetail65
Offline Offline
« Reply #3 on: September 16, 2011, 10:40 AM »
Depends on what you do.
For Festool either the OF 1400 and the OF 1010 or the OF 1400 and the OF 2200.
I just do not like the mfk at all and other brands routers of that size work for me.
Peter Halle
Global Moderator
Online Online
WWW
« Reply #4 on: September 16, 2011, 10:47 AM »
If it were me, I would go for the 1400 and the 2200.  The 1400 can handle tasks that smaller routers can with some adjustments.  The 2200 can handle the bigger items.  If you do edgebanding more than larger tasks, then consider the MFK700 instead.
marrt
Offline Offline
« Reply #5 on: September 16, 2011, 11:20 AM »
I don't do enough edge banding at this time to justify the MFT700.
I was originally thinking the 1100 and 2200.  Although I don't do solid surface work, the 2200 appears to be a very nice platform...if you can get used to it's size.  I don't really want to buy a shaper, so I thought the 2200 would be a nice compromise to handle those projects where you'd normally want a shaper (or router table).
Steve Rowe
Offline Offline
« Reply #6 on: September 16, 2011, 12:07 PM »
I have 2- OF1400 and the MFK.  Don't use the MFK much but the OF1400 gets most of the use.  I have a PC 7538 and was using it last week with sawdust flying everywhere.  I really would enjoy the dust collection of the OF2200 and am thinking about it somewhat.
Hindsight is 20/20 and if I were to choose today, it would be the OF1400 and the OF2200.  This is highly dependent on what you intend to do with them however.
Steve
speed
Offline Offline
« Reply #7 on: September 16, 2011, 12:30 PM »
i have the 1010 and the 2200
i use the 1010 for roundover bits etc and the 2200 for big cutters/worktops
has made the change. now 100%  T-loc Smiley
ScotF
Offline Offline
WWW
« Reply #8 on: September 16, 2011, 02:44 PM »
The 1010 and the 2200 to me is the ultimate router combo.  The 1010 is small, nimble and versatile and can handle most routing tasks.  It was designed to be used with the LR32 and with the edging plate and accessories, you can make it into a very good trim router.  When you need more power, then the 2200 can handle those needs with ease - this thing is the most feature rich, well balanced tools on the market and is one of my favorites.   This would be my choice for the best combo.
Scot
festooltim
Offline Offline
« Reply #9 on: September 16, 2011, 07:59 PM »
Dido on the 1010 and 2200.  I have the 1010 and really like how easy it is to use because most jobs just require a small bit. The 2200 is just a work of art, its what all other routers aspire to be, the biggest baddest and can take on whatever you want to throw at it.
Quantity is no substitute for Quality
2-mft3's ,  ct22,  ts55,  rotex125,  c12, kapex,  ras115,  65planer,  of1010,  LR32system, trion psb 300 eq,  parrallel guides,    sortainer,  routerbitsystainer,  guide rail acc. kit,  toolie,  t-shirt,  hat,  pen,  saftey glasses.
James Watriss
Offline Offline
« Reply #10 on: September 21, 2011, 09:40 AM »
I Bought the 1010 and 1400. I also bought the guide stops, edge guide, LR-32, the MFS, and the edge trimming stuff.
The guide blocks with the edge guide makes for a good offset base, and the 1400 is beefy enough to do edge profiling.
The LR-32 works with either router, but it's a game-changer.
The 1010 with the edge trimming accessories and a spiral (down) flush bit is hands-down the best and slickest set-up I've ever used, and it's good enough that I don't think I'll ever need the MFK.
The 1400 is a solid, all-around beast. I've used the 1010 for a long and lusty list of detail work from inlay to profiles, flush trimming, etc, and I find it to be ergonomically intuitive and light enough to feel downright sporty. Good enough to justify the effort of finding 8mm bits, or paying for Festool bits.
But the joy of Fes routers for me is in the accessories. There's nothing to compare them to. 'Better than,' is a phrase that requires something to compare to. There are no equivalent offerings in the states to any of the stuff I mentioned, except the edge guide. This one is very solid, and very adjustable.
RonWen
Retailer
Online Online
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #11 on: September 21, 2011, 10:23 AM »
As far as I am aware the IRS hasn't specified a limit of two (2) routers (yet... Scared) -- go for three (3).  Wink
SRSemenza
Global Moderator
Offline Offline
« Reply #12 on: September 21, 2011, 10:29 AM »
If it is for "tax purposes" won't the cost of the routers matter as much as the use itself?
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
ScooterX
Offline Offline
WWW
« Reply #13 on: September 21, 2011, 02:23 PM »
I own a sign company. I use the 1010. I like it because it is nimble, lightweight, and powerful to do what I need. I use it for roundovers on MDO, and for carving out letters from cedar. My second router is a Milwaukee that is used in the router table. If I were to buy two Festool routers, I'd buy two 1010s. Then I wouldn't have to change out the bits as often when I move from job to job.
So, yes, it all depends on what you want to use a router for...
Intelligent Workshop
Festool Dealer
Offline Offline
Tom Sustins
WWW
« Reply #14 on: September 21, 2011, 07:04 PM »
2200 & MFK700 Would be my desert island router combo.
http://www.intelligentworkshop.co.uk
Festool Power Tools - Walko Workbenches - iGaging Measuring Devices - Veritas Hand Tools - Kreg Pocket Hole Jig
FastCap - Bessey Clamps - TiteBond Glues - Oneida Dust Deputy - Trend Diamond Sharpening
Only The Best
Dan Clark
Offline Offline
WWW
« Reply #15 on: September 21, 2011, 10:49 PM »
I have an OF1400 for general, handheld use, a Bosch Colt as a small trim router, and a Triton as a router table router. If I were to do it over again, I'd get an OF1010 as a trim router and for light duty use, and an OF2200 for heavyweight stuff.
Regards,
Dan.
MadViking
Offline Offline
« Reply #16 on: September 27, 2011, 08:14 AM »
I have the OF 1010 and 2200. I don't own nor have I ever used the 1400. My combo works very nice, at least for the work I do. If you ever intend on using the router in a table (i.e. if the CMS is ever available in the USA), the 2200 is the best option. For smaller stuff like working with the LR32 the 1010 is great. I've never missed the 1400, at least not so far.
CXS, Rotex RO 90 DX, Rotex RO 150, ETS 150/3, RTS 400, EHL 65, Carvex PS 400, Kapex KS 120 UG-Set, Precisio CS 70 EB-Set, Domino DF 500, OF 1010, OF 2200, CMS, CMS-OF, CMS-PS, CMS-MOD-BS 120, MFT/3, TS 55, FS-PA, FS 1400/2-LR32 x2, LR 32-SYS, FS-SYS/2, Cleantex CTL 26 with boom arm - feel free to PM me if you have questions about any of these
Tim Malyszko
Offline Offline
Webster Groves, MO
WWW
« Reply #17 on: September 27, 2011, 10:29 AM »
I have the OF1400, the OF2200 and the MFK700.  Of the 3 , the 1400 gets the most use and the OF2200 the least.  I have a router table with a Porter Cable 7518 mounted in it with a lift so I don't have a lot of use for the OF2200.  Looking back, I would have not purchased the OF2200, but I'm sure there will be times down the line that I will be glad I have it.  The MFK is a great little router to have but again not really needed.  I would purchase the OF1400 as it is a great compromise between size, flexibility and power and then the 2nd one really depends on what you will be doing.
Tinker
Offline Offline
« Reply #18 on: September 27, 2011, 03:46 PM »
I do mostly small projects.  My GoTo is my trusty old OF1000.  I have the OF 1400 if I need larger bits.  Those are my two most used.
Also have a couple of mid sized PC's which I don't like and an ancient Milwaukee 5625 (I think) that is single speed and no DC.  I like the feel of it and the Switch is locate perfectly for thumb operation.  The Festools and the Milwaukee hold bits where I set them.  The PC's. uless i really rare on the lock nuts love to change depths on me.  Lots of redesigned projects as a result. Mostly, they just gather dust for me.  I suppose if I were smart, I would keep them close when using the Milwaukee to catch all of tat dust it likes to toss around. Cool
Tinker
Wayne H. Tinker
Jesse Cloud
Offline Offline
« Reply #19 on: April 24, 2012, 05:52 PM »
Well, I have semi-dissed the 2200 a few times around here and said that it doesn't get used in my shop enough to justify the space it takes up.  I've been thinking about selling it to partially fund a Domino XL.
Well, today I tried it on one of the big challenges in chair making.  Back legs of chairs usually have a S-curve to provide proper lumbar support and to look cool.  But they also have joinery areas that need to be dead square and in exactly the right place.  This usually means using a pattern to mark out the shape and then a rough trim on the bandsaw followed by lots of handtool work to get it exactly right.  The ideal would be to attach the pattern to the trimmed workpiece and run a flush trim bit to duplicate the pattern on the workpiece.
That's not easy.  My chair legs are 2 inches thick in some places and 2 inches is a wide router cut.  I tried it with my 1400 and there was major chatter.  You can get past some of the chatter by working off different sides of the workpiece so that the bit direction will match the wood grain, but there's lots of potential for error there.
I remembered that shapers generally were smooth enough to handle it in one direction and then I remembered I had a "handheld shaper" in the OF2200.  I had to jury rig an offcut to keep the OF2200 stable and square and there were a few places where I couldn't use the 'below the deck' dust shroud, so it was a little messy.  But the bottom line is that I did in about 20 minutes what I used to spend on couple of days on.
OK, the OF2200 is staying - now I gotta figure out how to afford the big Domino. Eek!
Peter Halle
Global Moderator
Online Online
WWW
« Reply #20 on: April 24, 2012, 06:26 PM »
Jesse,
 Big Grin Big Grin Thumbs Up
hhh
Offline Offline
« Reply #21 on: April 24, 2012, 06:42 PM »
I have all of FT's and PC's routers - most are 2 of each.  IF I had to get just two FT routers:
2200 and 1400 - general purpose
2200 and 700 -- if you do a lot of trim
Festool: Everything available in USA except: Air Sanders, Planex, CMS, MTF and Planers. Lots of Porter Cable routers. Several Milwaukee, Hilti and Hitchi industrial drills, demo hammers, etc.  Bosch drivers and drills.  Mirka air sanders.  Complete custom furniture shop with significant investment in Powermatic & Felder stationary tools...
lambeater
Offline Offline
« Reply #22 on: April 25, 2012, 10:31 AM »
I could and I did, got both the 1400 and 700 work as a perfect combo.
thx
Lambeater
Tim Raleigh
Offline Offline
WWW
« Reply #23 on: April 25, 2012, 10:59 AM »
Jesse:
How long was the router bit you used to cut those 2" legs or did you mill one side and then flip it and mill the other side?
Tim
GPowers
Offline Offline
Metric convert
WWW
« Reply #24 on: April 25, 2012, 07:50 PM »
thx
Lambeater
Dito and I have the PC 7518 in a router table.
Greg Powers
Jesse Cloud
Offline Offline
« Reply #25 on: April 25, 2012, 11:30 PM »
Jesse:
Tim
The bit is a Freud pattern bit with 2 inches cutting height.  I cut it in one pass.  Somehow, when I flip it, I always have some cleanup to do.  My goal (not completely met this time) is one pass shaping with no cleanup.
I do flip when I have tricky grain on the edge and I want to reverse the direction to avoid tearout.  With the power and the stability of the 2200 I didn't have any tearout at all.
Michael1960
Offline Offline
« Reply #26 on: April 26, 2012, 04:26 AM »
Hi Jesse
Could you explain what you mean by setting up a 'jury rig'.
Michael
Alan m
Offline Offline
« Reply #27 on: April 26, 2012, 05:24 AM »
Hi Jesse
Michael
im not sure of the historic meaning of jury rig but usually people use that phrase when they had to improvise or bodge a set up to make it wonk like the way you would knock up a few supports if you had to hold up something while fitting it. anythi9ng at all will do as long aas its safe and strong
now
wish list
Jesse Cloud
Offline Offline
« Reply #28 on: April 26, 2012, 10:22 AM »
What's a "jury rig"?
Alan explained it quite well - a bodge or a wonk! Wink  Here in New Mexico USA, we might call it a chapuza.
The Wikipedia article says its an old nautical term for a temporary repair using whatever materials and tools are available, perhaps from the French "jour" implying that the repair is only meant to last for a day.  That sounds about like what I did.
The issue was keeping the OF2200 from tilting so that the cut would be square to the leg face.  I simply saved the off-cut from bandsawing out the leg, cut a piece of ply the same thickness as my pattern in the shape of the offcut and pinned it onto the offcut.  That allowed me to place the offcut close to the leg so that the OF2200 could straddle over the two and stay stable and square.  Not pretty, I'll probably toss it today.  I would make something more robust if I were making a large order of chairs.
« Last Edit: April 26, 2012, 10:28 AM by Jesse Cloud » Logged
Michael1960
Offline Offline
« Reply #29 on: April 26, 2012, 01:56 PM »
Thanks Jesse and Alan for your explanations.  Sounds like clever improvising...
Regards, Michael
Pages: [1]   Go Up
  Print
Jump to:
