LIL...I am in no way trying to be contentious here...but have an honest question.
Getting ready to finally invest in Festool and am straddling the fence on the Kapex....I have used the Makita in a production shop and really liked it, does anyone have any input on this?
I caould save alot of cash going the Makita route, but since I am investing in a Festool driven shop I am torn between sticking with the Kapex for my mitre needs..
Mike
(again sorry for any hi-jacking
Full disclosure here: I'm not a pro, not even a particularly good amateur.
I had the Makita LS1013FL and my wife suggested I get the Kapex. who was I to argue? The Makita is a really nice saw, beautiful cut quality and very accurate. I think the cut quality is equal to the kapex with the stock blades.
Advantages of teh Kapex over the Makita:
- Easier to read miter settings since they aren't obscured by the work piece on the table
- Much easier to set and read bevel
- vernier scale makes 1/2 degree miter setting simple, even 1/4 degree if you're careful
- variable speed for special situations
- the dust collection is truly amazing with the large hose. the makita isn't bad (although it can't hold a candle to the kapex), but the rubber dust boot closes up with any reasonable degree of vacuum which causes the dust to just spew out the back of the saw, vac or no vac.
- the hold down clamp on the Kapex is so easy to use it's silly. the makita is pretty cumbersome to use
- You can't really adjust the laser on the makita to hit the cut line exactly (at least I coudn't). and you basically have to set it to left or right of the blade and leave it there.
- Kapex is lighter, although the Makita is pretty easy to move around.
-Kapex has nice tall fences on both sides
- Depth of cut setting on Kapex is easy to use, not so on the Makita.
- I think the Kapex is quieter, but I always use hearing protection so that's not such a big issue
The Makita has a few wins in its column:
- included supports let you put down slightly wider material and still ahve support than the kapex
- bigger table
- Light (although it's of limited use, frankly
- $800 cheaper
- Now that the new 4-rail Makita 10" is in stores the older saws might be had for a real steep discount
- think the slide lock on the makita is easier to use than the Kapex, since it's on the front handle
- Makita has built in bevel detents at 0 and both 45s, compared to the kapex that you have to set the knob to get the detents on the bevel.
- Makita tilts to full bevel without having to move the fence
I'm probably missing some stuff--maybe someone else will chime in if I did. Hope this helps.
