hockey_magnet
Offline
« on: June 03, 2012, 11:31 PM » |
Got a new Syslite yesterday. I needed to use it right away so I just plugged it in and turned it on so I was charging it and using it off AC. When I picked it up after it had been on for a couple of hours the case was quite hot to touch. Normal?
Chris
Kev
Offline
« Reply #1 on: June 03, 2012, 11:45 PM » |
Chris
Charging and running will have a warming effect for sure ... not certain what you consider "hot". Too hot to touch ?
Timtool
Retailer
Offline
« Reply #2 on: June 04, 2012, 01:58 AM » |
It gets slightly warm when you load it like any battery, but i wouldn't call it hot in normal conditions. I used it a few times with the power cord connected, but can't say i noticed any heat.
hockey_magnet
Offline
« Reply #3 on: June 04, 2012, 08:48 AM » |
While not too hot to touch I thought it was more than just "warm" after 2 hours plugged while simultaneously charging and running. I'll give it another test.
zapdafish
Offline
« Reply #4 on: June 04, 2012, 09:36 AM » |
The motor needs a break in period at which time it will run hot... oh wait, nm  Mine is still on the way but one of the main reasons I want it is that it isn't a major heat source in an un air conditioned room. I imagine electronics running a bit hot doesn't contribute much to the over all temp in a room like a lit halogen light does.
Holzhacker
Offline
« Reply #5 on: June 04, 2012, 09:55 AM » |
The only time mine feels hot is when I leave it sitting too close to the BBQ for too long. Every time this happens I'm impressed none of the plastic has melted. As far as charging or using with a battery it has never felt hot.
hockey_magnet
Offline
« Reply #6 on: June 04, 2012, 01:09 PM » |
The motor needs a break in period at which time it will run hot... oh wait, nm  Mine is still on the way but one of the main reasons I want it is that it isn't a major heat source in an un air conditioned room. I imagine electronics running a bit hot doesn't contribute much to the over all temp in a room like a lit halogen light does. Oh there's no way it gets that hot, warm, whatever. It's just warmer than I would have expected, I bought it for the same reason, also kept burning my fingers on the stupid halogen.
Aaron Underdahl
Online
« Reply #7 on: June 04, 2012, 02:41 PM » |
I got a chance to use my syslite for the first time on Saturday. After 8 hr of use while plugged into the wall, my syslite was definitely warm to the touch. But not close to being uncomfortable. I assumed this is due to the internal battery charging along with the light output. I have yet to use it with battery power only to see if that makes it run any cooler.
ceddy
Offline
« Reply #8 on: June 04, 2012, 03:02 PM » |
on the same topic, anybody know what the part number for the US wall charger is? I'm seeing 498 857 or 702 250. I have the euro syslite... will be nice to stop charging it in the car!
TS75 OF1400 MFT/3 CT22 ETS125 ETS150/5 Kapex CXS DominoXL C15 RO90
Kev
Offline
« Reply #9 on: June 04, 2012, 05:46 PM » |
I haven't got it in front of me, but I thought the Syslte charger was multi voltage friendly ... just needing a plug adaptor. Check the little label for the voltage range.
hockey_magnet
Offline
« Reply #10 on: June 04, 2012, 09:07 PM » |
The voltage range is 100-240. Like Kev says. I think you just need the plug adapter. the numbers on the plug adapter are 15.2078 and 15.2894 if that's any help. the number on the charger is FW7556/12 Output is 12v 1.5A
jacko9
Online
« Reply #11 on: June 04, 2012, 09:16 PM » |
I have only used mine with the on-board battery and have not felt any heat. I use it to highlight cutting lines on my bandsaw, drill press and when cutting dovetails. So far, I love this handy little light.
fdengel
Offline
« Reply #12 on: June 05, 2012, 01:47 PM » |
Is it also 50/60Hz friendly?
ceddy
Offline
« Reply #13 on: June 05, 2012, 01:50 PM » |
thanks for the replies. At any rate I would like to order a spare wall charger, the EKAT is simply unclear as it shows two parts. I will take it up with the dealer.
