Author Topic: Circle cut on CMS VL  (Read 1091 times)
Offline HowardH
« on: September 09, 2017, 02:57 PM »
Is there a way to cut a circle with the CMS router set up?  I'm building a series of pasta sink drain boards and need a way to cut circles to fit a colander.  If so, do I need the set or the basic system?  I like the set but from what I can see, if you don't do coping work, it really isn't needed beyond getting the hose Y separately.
Howard H
mft1080, Trion, MFT/3, T15, OF 1400, RO150FEQ, TS55, RTS400, CT22, CT36E, 800, 1080, 1400, 1900 rails, CSX, C18, Vecturo, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE with router and jig saw plates.  Sawstop contractor.
Offline neilc
Re: Circle cut on CMS VL
« Reply #1 on: September 09, 2017, 03:12 PM »
With the sliding table you could rig up a pin on a board clamped to the sliding table and then adjust the radius and tighten the table so it is not sliding.
What size circle are you trying to cut?
If it's a smaller circle you could also just attach a secondary base to the router, measure to the outside edge of the circle and put a pin in it the radius you want the circle to be.  No router table needed in that case.
Offline HowardH
« Reply #2 on: September 09, 2017, 04:16 PM »
 I'm going to have to cut about a 12 inch circle.    I can always use a trammell but I thought it might be easier using the router table.
Howard H
Offline bkharman
« Reply #3 on: September 09, 2017, 05:12 PM »
Howard,
You could pin the board to the MFT. I haven't made a circle with mine before, I just used the router freehand on a trammel (my MFS) and it worked a peach.
I am sure there is a slick way to do it with the table, but seems to elude me right now.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
