Author Topic: CMS & Jigsaws  (Read 1923 times)
Offline MisterFish
CMS & Jigsaws
« on: September 24, 2017, 12:35 PM »
I have a CMS and have recently bought a 420 EBQ CARVEX JIGSAW.
I have noticed that there seem to be two Jigsaw inserts around for the CMS.  There is the Festool 561262 CMS-PS 200/PS 300 Jigsaw CMS Support Module coming in at around £150 and the CMS-MOD-PS 300 EQ-PLUS at around £450.
Now I also understand that the former requires the ADT-PS 400 adapter, but aside from that are there any reasons to pay the extra £300 for the newer model?
Thanks guys.
Offline PreferrablyWood
Re: CMS & Jigsaws
« Reply #1 on: September 24, 2017, 12:45 PM »
Seems like a pretty steep price for a relatively simple insert. Are you sure on that info?
Thanks guys.
RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Re: CMS & Jigsaws
« Reply #3 on: September 24, 2017, 12:52 PM »
The old insert is compatible with the EBQ Carvex 400 and 420 with the use of the ADT-PS 400 base.
As far as I understand it there is only one version of the jigsaw insert.
My supplier is Tooltime in Germany. price for base 162 € price for adaptor 15€
Your 2nd link shows the bare CMS jigsaw insert. ADT-PS 400 base is something you also need if you want to use the guide rail or the circle cutter with the Jigsaw.
« Last Edit: September 24, 2017, 01:35 PM by PreferrablyWood »
Offline MisterFish
Re: CMS & Jigsaws
« Reply #4 on: September 25, 2017, 02:20 AM »
Okay.  Thanks.
Re: CMS & Jigsaws
« Reply #5 on: September 25, 2017, 08:55 AM »
If I remember correctly, I went through this several years ago:
The 561263 {CMS-MOD-PS 300 EQ-Plus} is for use with the PS 300 only.
https://www.festool.com/Products/Pages/Product-Detail.aspx?pid=561263&name=Jigsaw-module-CMS-PS-300-CMS-MOD-PS-300-EQ-Plus
The 561262 {CMS-PS} is for use with the PS 200/PS 300 and with the addition of adapter 497303 {ADT-PS 400} will permit the use of the PS 400/PS 420.
https://www.festool.com/Products/Accessories/Pages/Detail.aspx?pid=561262&name=Module-support-jigsaw-CMS-PS
https://www.festool.com/Products/Accessories/Pages/Detail.aspx?pid=497303&name=Guide-stops-for-jigsaws-ADT-PS-420
« Last Edit: September 25, 2017, 09:05 AM by Cheese »
Offline jobsworth
  • Festool Baby.....
Re: CMS & Jigsaws
« Reply #6 on: September 25, 2017, 09:59 AM »
I own a jig saw Module for the CMS. Its for a old style jigsaw (trition).  I like it. I use it. Its great for template making  etc.
For 450 quid ya can prolly buy a used PS 200 and the module save a few quid. I only paid $250 for the PS 200. That way you can just keep it mounted in the module.
I use mine more in the module then I do free hand.
« Last Edit: September 25, 2017, 10:03 AM by jobsworth »
Offline TinyShop
Re: CMS & Jigsaws
« Reply #7 on: January 08, 2018, 01:25 AM »
I thought I'd answer the OP's original question. The "CMS-MOD-PS 300 EQ-PLUS" consists of the module/insert (there's only one version btw) and a Festool TRION PS 300 EQ-Plus jigsaw (IOW, as shown in the associated product image(s), the jigsaw displayed hanging upside down in the module is included). As for the "Festool 561262 CMS-PS 200/PS 300 Jigsaw CMS Support Module", it's just the module sans jigsaw, hence the wide price differential.
« Last Edit: January 09, 2018, 08:13 PM by TinyShop »
ETS 150/5 EQ (DE) [PO], TS 75 EQ (DE) [PO], OF 1400 EQ-F (DE) [N], CXS (DE) [N], CMS-GE [DE], CMS TS 75 (DE) [N], LA-CS 50/CMS (DE) [PO], VB-CMS (DE) [N], MFT/3 (CZ) [N], DF 700 EQ w/Seneca Small Mortise Kit (DE) [PO], FEIN Multimaster 350 QSL (DE) [N], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [N], BOSCH 1590EVS w/dust collection (CH) [N], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [N], CT SYS (DE) [PO], Milwaukee 0302-20 (US) [N], Two (2) Porter Cable 862 (TW) [N], Porter Cable 447 (US) [N], Zyliss Vise (CH) [N], Hitachi C 8FB (JP) [H]
[PO] Pre-owned   [N] New   [H] Heirloom   (XX) country of origin
