mylcs143
Offline
« on: March 14, 2012, 08:50 AM » |
Hi All, First time poster and I have never used the guide rail system. I am looking to rip some long 1 7/8" mahogany (up to 8' long). I can invasion that the single 106" long guide rail would be as straight as a laser but my question is if I connect 2 55" guide rails together with the guide rail connector is this really as straight? Will there be any play or movement at this connection point. I will be using a TS55 to cut this and I need this to be a clean and straight cut. It does not have to be a glue line type cut but fairly close to it.
Thanks in advance
John
Peter Halle
Global Moderator
Offline
« Reply #1 on: March 14, 2012, 09:02 AM » |
John,
Welcome to the forum. This is a common question and you will certainly get many different answers. I have had no straightness issues when combining rails. I leave a small gap in between the rails and use a level as a guide when I tighten them up. I have used a 1400 mm rail and a 2700 mm rail together and I think with care you can work successfully. That being said, because I don't have transportation issues with transporting a longer rail nor storage issues, I am a supporter of a long rail and short rail ownership scenario. If you go the route of multiple shorter rails, you might want to consider the 55 inch rail and the 75 inch rail. More flexible in handling different cutting needs.
bwiele
Offline
« Reply #2 on: March 14, 2012, 09:05 AM » |
Other, more experienced people will comment or confirm, but at the Festool class I went to in Indiana the recommended process is to put the connectors in the rails, don't butt the ends of the rails together (they are NOT guaranteed to be square cut), bridge the TS55 across the gap between the rails and tighten the tracking knobs. Then tighten the rail connector screws that you can access from the top, remove the saw and tighten the screws from underneath. Double check your alignment with a straight edge.
Hope that helps.
Kev
Online
« Reply #3 on: March 14, 2012, 09:31 AM » |
An accurately aligned folding rail shouldn't be beyond Festool's capability
Rick Christopherson
Retailer
Online
« Reply #4 on: March 14, 2012, 09:37 AM » |
Hope that helps.
I hope that this method is not still being taught in the classes. Back when I was developing the video below, this method was brought to my attention by Christian and Michael at Festool. Word was supposed to be passed down to the trainers that this method is not truly effective. The method of bridging the two rails with the saw is not effective because there are only 2 contact points on the saw, and it takes three points (actually 4, but the connecting bars serve this purpose) to set a straight line between the two rails. As is shown in the video below, a level, other guide rail, or some other straightedge should be used to set the rails to be parallel. I also disagree with the need for a gap between the rails, even if the ends are not square. That's because the straightedge will override any issue with the ends being out of square. Even though the ends are not guaranteed to be square, you will probably find that they actually are square. If you verify that your ends are square, then you can simply butt the ends, and be pretty confident that you have parallel rails. If I was joining rails frequently, I would actually take the time to calibrate the ends of my rails to be square. (However, for critical joints, I would still use a straightedge.)
BMH
Offline
Location: Oregon, UNITED STATES (US) Member Since: Aug 2008
« Reply #5 on: March 14, 2012, 10:40 AM » |
John, you can get a straight line cut with two 55" rails using the following technic
. You have to check your rail every couple of cuts to make sure they are aligning perfectly. I used the TS55 across the gap method and had less then stellar results and started to use a 4 foot level and had good results. That being said if I am cutting expensive wood, I check the alignment between each cut and rarely have to correct the rails if I move them carefully between cuts. I am debating buying a FS2700 for the peace of mind it brings when you are ripping long sheets. Bruce
Kev
Online
« Reply #6 on: March 14, 2012, 10:51 AM » |
I don't have the need to transport stuff, so getting a 3000 when they were at the right price was a quick decision. The Festool rail joining method isn't ideal. Festool can and should offer something better. Creative use of lasers for alignment could be cool
bwiele
Offline
« Reply #7 on: March 14, 2012, 11:03 AM » |
See, there you go. An excellent example of someone with more experience than me!
RL
Offline
« Reply #8 on: March 14, 2012, 11:09 AM » |
At 1 7/8" it doesn't matter how straight your cut is- that 8' mahogany rip is going to bow no matter what!
I like green.
greenMonster
Offline
« Reply #9 on: March 14, 2012, 11:41 AM » |
Do most people put the strait edge along the zero clearance strip or assume the back of the guide is perfectly parallel?
RL
Offline
« Reply #10 on: March 14, 2012, 11:57 AM » |
I use the back and assume it's parallel. If it isn't we're all in trouble!
I like green.
JSands
Offline
« Reply #11 on: March 14, 2012, 12:00 PM » |
Glad Rick made this point clear about the saw as an alignment tool...no way! I agree with others, many of us learn the hard way, joining rails sounds like a great idea, but its a "potential" recipe for trouble....and its too bad this information is not spelled out in the rail brochures....
Joining rails offers tremendous flexibility for transport, which of course is Festools Claim to fame.... however, it should be written on the rails with a removable sticker IMO, USE A STRAIGHT EDGE WHEN JOINING RAILS!
Where to put the straight edge? Another good question. I have found the inside of the track (hump) is the most logical place, as there is no guarantee the blade cuts right up to the rubber strip.... for many reasons, a blade change using a wider blade, then using a slightly narrower blade is just one example why you might not cut right up to the strip. I would put more confidence in the guide being straight, and since the saw rides the guide, its the most sensible place to put the straight edge.
Here is what killed me, and why I ended up buying longer single rails... you join the rail with straight edge, leave a tiny gap, cause they edges are not square.... then you think its perfect, and it might be a for a few cuts, but then, you place rail down on edge too hard, and whamo, its no longer perfectly straight. The smallest shift in the middle can really throw the ends of the cut off, as the error magnifies with distance. So, re checking with straight edge is time well spent.... I have ruined enough cuts to finally accept all these limitations of the system..... yes it offers versatility, but there is a price for this versatility.... I wish this post existed many years ago when I got started with my rails....
fritter63
Offline
« Reply #12 on: March 14, 2012, 01:41 PM » |
An accurately aligned folding rail shouldn't be beyond Festool's capability  Rail sections with perfectly square ends shouldn't be beyond Festool's capability either....
Alan m
Offline
« Reply #13 on: March 14, 2012, 03:20 PM » |
currently i use 3 55" rails. i join 2 for th elong cuts and the other for cross cuts. i hate joining them as its a pain and yes they can and do move. luckely iv never been caught out by the rail mooving but some day i will. i am planing on getting a 3m rail for shop use and leave the 3 for site use. i think joining is the only realistic way for most people on site. you would want a big truck etc to move one of them around safely.
SRSemenza
Global Moderator
Offline
« Reply #14 on: March 14, 2012, 03:27 PM » |
At 1 7/8" it doesn't matter how straight your cut is- that 8' mahogany rip is going to bow no matter what!  +1 Hi John, Welcome to the FOG!  Rip it a little overwidth so you can do it again to straight line it. Personally I prefer the long single piece rail , even thoug it is easy enough to join two and have them straight. Seth
Festool Service 800-554-8741
Jonhilgen
Offline
« Reply #15 on: March 14, 2012, 03:37 PM » |
John, you can get a straight line cut with two 55" rails using the following technic Joining The Festool Guide Rails . You have to check your rail every couple of cuts to make sure they are aligning perfectly. I used the TS55 across the gap method and had less then stellar results and started to use a 4 foot level and had good results. That being said if I am cutting expensive wood, I check the alignment between each cut and rarely have to correct the rails if I move them carefully between cuts. I am debating buying a FS2700 for the peace of mind it brings when you are ripping long sheets. Bruce Bruce kind of proved my point (me being the lone dissenter who voted no). If I have to check my joined rails every few cuts (which I did as well prior to owning a 3000 rail), I'm taking too much time and losing money. I never felt I could truly trust joined rails...tried many methods, never the bridge method and like I said, the trust (and to some extent, accuracy) was never there. Two 1400 rails are great for site work and I use them all the time for that. But when I'm in the shop (aka, the garage) I always use the 3000. Jon Jon
The more Festools I buy, the more money I earn. The more money I earn, the more Festools I buy. The more... TS 55, TS 75, Domino, CT22, OF 2000, C12, CXS, RAS, Trion, Fogtainers!
Rick Christopherson
Retailer
Online
« Reply #16 on: March 14, 2012, 03:49 PM » |
Proved? No. Expressed? Yes. When you leave a gap between the rails, you actually increase the likelihood of knocking them out of alignment with handling. That's part of the reason why I disapprove of this method of leaving a gap between the rails. When you have the rails touching, you have at least 3 points of contact: the 2 connecting bars, and the one (or more) points of contact of the aluminum. Metal is not easily compressed, so you really have to whack them to knock them out of alignment. It is a matter of leverage.
Jonhilgen
Offline
« Reply #17 on: March 14, 2012, 04:23 PM » |
Thanks for making the distinction.
Rick, I do tend to butt the rails when I do join them in the field, leaving a gap and havig them "bind" whenI tightening them together was never convincing enough of an argument for me.
I'm guess what I'm trying to say (help me out if I'm not clear enough, or not using proper diction, if any of you feel the need to), is that I don't feel comfortable enough most of time when I use the joined rails.
P.s I'm trying to insert smiley faces so my writing doesn't come off as being sarcastic. But my phone is playing hellish tricks on me and not allowing me to choose where I want the cursor darn it! Jon
BMH
Offline
« Reply #18 on: March 14, 2012, 04:29 PM » |
Rick,
I concur, I am expressing my opinion. I do butt the rails as close to possible to get a straight edge with my four foot level. I will disagree with your statement saying that the connecting bars are a point of contact. In fact the four little screws are the point of contact and they can be loosen up very easily with the vibration of the TS55 and/or manipulation of the rail. It doesn't make much of a difference for some of my projects but for others, with expensive wood I check before I cut, just like I measure twice before important cuts. This is no criticism of Festool system, is just recognizing the limitation of the system when you try to make everything easily mobile.
Bruce
Corwin
Online
« Reply #19 on: March 14, 2012, 04:41 PM » |
The guide rail splinter (zero clearance) strip is not the best place to put your straight edge against to assure that your two guide rails are aligned correctly. There are a few things that will cause your saw to cut in a little closer to the rail which leaves your splinter strip something less than perfect. These strips are consumables and need to be relocated or replaced over time. I use the back and assume it's parallel. If it isn't we're all in trouble!
The back edges are parallel with the raised hat area. However, there may be slight variations from rail to rail in the distance between the hat and that back edge. Most of my rails are within less than half a thousands of an inch of having the same distance between hat and back edge, so using a straight edge along the back sides will work just fine to align two rails. But one of my rails measures about 0.007" different than the others, and while not a lot, using a straight edge along the back side of that rail presents a problem. So, after using a straight edge to align your rails, check to see that your saw will travel smoothly across where the two rails are joined. If your rails have a variation, you may want to use feeler gauges between the straight edge and the back of the narrower rail in your alignment process -- that seems easier to me than using the straight edge along the raised hat areas.
« Last Edit: March 14, 2012, 04:42 PM by Corwin »
Shirt Size: L
Jalvis
Offline
« Reply #20 on: March 14, 2012, 04:46 PM » |
This problem is one reason I'm considering Mafell guide rails. The Mafell Rail connects entirely differently....it uses a laser-cut piece of steel that has tensioners on one side. When put in the rail the tensioner screws put pressure against one side of the rail housing ensuring a strait joint. I've talked with users in the UK and all have said theres no need to use a strait edge for alignment with this design. http://www.dm-tools.co.uk/extraimages/Mafell_Guide_Rail.jpg
« Last Edit: March 14, 2012, 05:01 PM by Jalvis »
sancho57
Offline
« Reply #21 on: March 14, 2012, 06:39 PM » |
Hope that helps.
Thats how we were instructed in LV
Shhhhhh Dont tell the wife butttttt I bought another…….
Vindingo
Offline
« Reply #22 on: March 14, 2012, 08:24 PM » |
I leave the connecting rods permanently attached to one of my rails to make the whole process quicker. I stand the 1400 rail with permanent rods up strait, then lower the other 1400 rail on to the top. The two edges are square, so when the ends butt, just tighten the set screws and you are good to go. By doing it vertically you can tighten the front and back set screws without having to flip the rails.
I have done this at least 50 times in the last 4-5 months and have had no issues.
Corwin
Online
« Reply #23 on: March 14, 2012, 08:35 PM » |
This reminds me of a solution that I had thought of some time back. If I were using joined rails and had problems with them staying in alignment I would make a spline to fix across where the two rails were joined. I would make this spline out of a piece of 3/4" ply, a piece several feet long and maybe 4" or so in width. Route a rebate along the long edge that would but up against the back edge of the guide rails -- rebate to a depth where the remaining thickness matches the height of the rear of the guide rail's T-track. Now fix a strip to the top of the rebate that hangs over the spline and, when but up to the back of the guide rail will cover the T-track area. Drill holes for mounting hardware that attaches the spline to the guide rails' T-tracks. This spline would be used in place of the guide rail connector that you would otherwise install in the guide rails' upper T-tracks. Lastly, before I installed the top strip to the spline, I would drill or cut out some inspection holes that allow you to see that the back edge of the guide rail is in full contact with the edge of the spline. Just an idea that I had not tried...
Shirt Size: L
ccarrolladams
Offline
Location: Hollywood, California USA Member Since: Apr 2010
« Reply #24 on: March 14, 2012, 09:03 PM » |
Thanks in advance
John
Hi John,  to The FOG. You ask an important question. Already many experts have provided a variety of answers. From early 2006 until I finally bought a pick-up truck with a lumber rack, I used a set of three 55" rails. I would use one as a straightedge to ensure the other two were connected appropriately. My primary Festool dealer had been a leading figure in the Los Angeles furniture crafting community for decades. He suggested I buy the three rails with my first TS55, since I had told him I did not own a truck and wanted my Festools to be easily portable. To this day, when I must be on a site with difficult access, I use my three rail method. BTW, I like having that third guide rail for the cross cuts. Never in all these years did I have a problem with my connected guide rail staying straight. Generally I clamp my guide rails and always do so with any rip over 48", with a 3000mm rail or a connected pair. Like others I have been proud to participate in many Festool End User training classes conducted by Steve Bace and Brian "The Sedge" Sedgeley. In fact I was a member of the first class opening the Henderson, NV location. That was a cabinet construction class, and rails from 42" (1080mm) to 5000mm were available for our use. During a break we had a lively discussion about ways to connect rails. The use of the TS55 saw as a fixture was demonstrated. I demonstrated my 3 rail approach, referencing the side away from the splinter guard. I explained that I did not want to be constantly changing the setting of the cams in the slot of my TS55 as needed to use the saw as a fixture, Now John, I am sure you have read the replies mentioning that the wood plank will likely twist and bow as a result of being ripped. It does not matter how you make such a rip, tension in the wood is released. That causes all kinds of results. Personally I long ago found I was better off ripping solid lumber using a larger table saw, but I also always make my rips at least a day before I will be assembling that job. Often I run the ripped edge through a jointer shortly after making the rip. Then the next day I evaluate the straightness of the edge. Perhaps it will need another rip pass, but often all it needs is another pass through the jointer. Usually the first rip releases enough tension in the wood that on the second day it is safe to rip the other edge and joint that. Still, when making a long glue-up, perhaps for a table, I schedule an extra day just in case not all the tension was released. Can we assume your lumber is 1 7/8" thick? You did not say the width of those planks. Has all your lumber been jointed on one face to render it flat and then run through a thickness planer to ensure it is uniform? I ask, because these days it is rare to have available planks that thick which are wide enough to support a Festool guide rail without using another piece of the same material. Where ripping with a track saw is not ideal is finding a way to clamp the rail to the piece being ripped. When you read discussion of the TS55 and the TS75, the consensus is that the 50mm depth of cut with a TS55 on a guide rail is marginal for ripping 1 7/8" thick lumber. For best results when ripping such material it is best to have a larger enough blade a full gullet is available beneath the work. This is a job for the TS75 in my experience. You will also want to use a blade designed for ripping. If I were attempting to do the rips you mention, I would be using a Panther blade: cat 496 305 for the TS55; cat 495 378 for the TS75. Panther blades provide about as good a cut edge ripping solid lumber as possible. Probably you noticed I use both a jointer (the way I prefer to spell the word) and a thickness planer. Both of mine are 20" wide, because I use my jointer to flatten the first face of a plank. Only when that face is flat do I bring the plank to uniform thickness. Those are hardly machines normally moved to sites. Mine have 480v 3 phase motors. Consequently they are installed in my shop, convenient to a long sliding table saw with a 550mm maximum blade. My experience is a really good way to make the clean-up rip in solid lumber is to clamp the biggest part to the sliding table. Virtually all the solid lumber I use comes to my shop as raw planks and sometimes logs. I have a 40hp Baker horizontal band re-saw with a powered conveyor belt which can conveniently reduce logs as big as 24" dia to planks of the thickness I desire. The advantage of a band re-saw is that the kerf is only 1.5mm, while a typical 550mm circular saw blade is 5+mm kerf. Festool track saws are marvelous, but as fantastic as they are, track saws are simply not appropriately efficient for jobs better done on a re-saw and sliding table saw,
Dan Rush
Offline
Trim carpenter
« Reply #25 on: March 14, 2012, 09:35 PM » |
I've been using joined guide rails daily, onsite, for at least 5-6 years now. I routinely cut 8' prefinished panels on cabinet installs. No room for error.
Very early on I realized that leaving a gap between two rails and then using a straight edge the true up the rail was labor intensive. I decided to just square cut the ends of all my rails. ( Rick was a bit more eloquent in describing it as calibrating the ends of the rails).
The end result is that now I butt the ends of two rails tightly, secure the rails, and I'm good to go. If the ends of the rails are at a true square, then the rail must be straight...
Another poster expressed concern about the rails coming out of alignment due to handling. I've never had that problem, but I do occasionally take a look at the butt joint during use to be sure I don't see any gaps.
Dan
williaty
Offline
« Reply #26 on: March 15, 2012, 03:14 AM » |
I join a set of guide rails frequently. After the first 2-3 times of doing it to figure out the process that works best for me, it now takes me about 30 to 45 seconds to put the connectors in and align the rails, and another 30 seconds to confirm that they're co-linear. Before I would trust the system, I set it up and broke it down a bunch of times. My worst measured deviation from straight so far as been 0.002" with the worst obviously being right at the join. I have not yet banged them around hard enough to knock them out of co-linear once I got them set. Then again, working with anything that thin and bendy and 3.3m long tends to make me quite cautious so I'm treating them pretty well. However, I'd treat a single 3m rail just as delicately.
ctfeet
Offline
« Reply #27 on: March 15, 2012, 01:04 PM » |
Just out of curiosity - is the 2700mm rail sufficient to rip 4x8 plywood? Or would I need to use the 3000mm? Ordering online seems like it could be dangerous because they have to ship an (almost) 9' long piece of relatively flimsy aluminum.
Rick Christopherson
Retailer
Online
« Reply #28 on: March 15, 2012, 01:16 PM » |
The 2700 rail is still 10" longer than the sheet, so yes, it can be used for ripping a 4x8 sheet. There is not a lot of leeway in the length, so you do have to carefully position the rail for proper overlap at the beginning and end. If you use the rail in this manner frequently, a simple trick to help in positioning would be to put a small bolt in the underside T-track to act as a position stop against either the leading or trailing edge of the sheet.
greenMonster
Offline
« Reply #29 on: March 15, 2012, 01:20 PM » |
I ordered a 3000mm from Bob, shipped fine.
