Pages: 1 2 [3] 4 5 6 7 8 9 10  All   Go Down
  Print
Author Topic: Consolidated Q&A for CMS Router Table  (Read 45943 times)
Michael Garrett
Offline Offline
« Reply #60 on: August 04, 2012, 04:54 PM »
What is the amp rating of the router table switch?
« Last Edit: August 04, 2012, 04:58 PM by Rocky » Logged
CT 26 HEPA, MFT/3, TS 75 EQ, OF 1400 EQ,  DF 500 SET, CXS SET, CENTROTEC INSTALLER SET 98-PC, TRADESMAN/INSTALLER CLEANING SET, DOMINO ASSORTMENT SYSTEM, LR 32 HOLE DRILLING SET, GUIDE RAIL ACCESSORY KIT, GUIDE RAIL FS 1400/2  (2), GUIDE RAIL FS 1900/2  (2), GUIDE RAIL FS 1400/2 LR 32  (1), Veritas MFT Clamping Kit,  Zorbo Forstner Bit Set
Alan m
Online Online
« Reply #61 on: August 04, 2012, 06:36 PM »
maybe someone (ron maybe) could make a fine adjust for it. have it  clamp (mechanism like the ug wings or crown stops) into the v groove and have a threaded rod pughing the fence. just loosen the fence and turn the screw ,then push the fence up against it and tighten.
Wouldn't something like this Kreg Micro Adjusterwork for the micro adjust
thats the kind of thing im thinking of, i think the cms fence attaches into holes in the table rather than a t track. that why i was thinking of using the v groove on the side.
now
wish list
Rick Christopherson
Retailer
Online Online
WWW
« Reply #62 on: August 04, 2012, 06:36 PM »
Here is a prime example of why I hate the German UL office. They don't fully understand the U.S. UL requirements they are allegedly enforcing. The sticker on the outside of the switch states it is rated for 13.5 amps, which is slightly over the maximum capacity of a 15 amp circuit (with a safety margin). However, the internal switch inside the switch box is actually rated at 16.5 amps, which is the maximum you can legally draw from a 20 amp circuit (also including a safety margin).
This is pure speculation on my part, and I have not, nor will not, ever confirm this with Festool for legal reasons. But I suspect that UL forced Festool to place this 13.5 amp sticker on the outside of the switch even though the internal switch has a higher ampere rating. In my personal opinion, UL lost sight of the purpose of this rating sticker. It should be providing the absolute electrical rating of the switch, but UL took it to mean a maximum rating of the whole table. My guess, and this is also pure speculation on my part, is that UL forced Festool to place this 13.5 amp limitation on the table unless they also installed NEMA 5-20 plugs on the table, like the old CT vacs used to have.
Michael Garrett
Offline Offline
« Reply #63 on: August 04, 2012, 06:48 PM »
And the OF 2200 has a 18 amp rating.   Could that be the problem.  Just changing the switch on the table.
http://www.amazon.com/MLCS-9078-20-Amp-Safety-Router/dp/B002C4L3PS/ref=pd_cp_hi_0
« Last Edit: August 04, 2012, 07:06 PM by Rocky » Logged
Eco-Options
Offline Offline
WWW
« Reply #64 on: August 04, 2012, 08:00 PM »
What are the chances of Festool selling just the table? Anytime soon?
Www.ecooptionshardwood.com
Shane Holland
Festool USA Employee
FOG Administrator
Offline Offline
WWW
« Reply #65 on: August 04, 2012, 08:01 PM »
Without the router module - nil. No plans and I don't see it happening unless other modules pass UL at some point in the future. What good would a table be with a big hole in it?
Shane Holland | Festool USA | Sales: 888-337-8600 | Service: 800-554-8741 | sho@festoolusa.com
Faster. Easier. Smarter.
Power Tools, Domino Joiners, RRP HEPA Vacs, Track SawsDrywall Sanders, Cordless Drills, Tools for Painters, LED Worklamp, Router Tables
Ken Nagrod
Restricted
Offline Offline
« Reply #66 on: August 04, 2012, 09:45 PM »
Pop-up television for the worksite or shop?  That'll stick it to DeWalt and Bosch!
Michael Garrett
Offline Offline
« Reply #67 on: August 04, 2012, 09:56 PM »
How much is the Router Module?
Ken Nagrod
Restricted
Offline Offline
« Reply #68 on: August 04, 2012, 09:57 PM »
$605 US
evanism
Offline Offline
« Reply #69 on: August 06, 2012, 06:28 PM »
Interesting that the date on this tread is recent.
I'm in Australia.  I've had my VL and router base for about 3 years.  It is OK, but there are a few things that have irritated the socks off me:
- the lack of ability to simply use a standard mitre gauge rather than the big slide doohickey from Festool
- the lack of rail guides in the table top
- the fence setup is impossible to set exactly.  This is no Incra LS type fence (in fact you can't fit one without making a component to hang onto the extruded rail....
- The fence is wound on with two long screws and offers no adjustment other than with a hammer of fist.  Line of sight stuff. Very un-festool.  It seems odd the way its mounted.  Its not stiff, accurate, repeatable or offers wide adjustment.  This one stuck me in the first second of opening the box.  I use a long bit of timber from the dogs mounted in the MFT to get it parallel and centred on the bit (my trusty Bit Of Wood Measurer)
There is one redeeming feature, in that the fence can be used as a jointer for small work due to the winding offset for the right.
If Festool were to just add some rail guides it would be perfect.
mattfc
Offline Offline
« Reply #70 on: August 07, 2012, 03:26 AM »
I agree that it would be nice to have a slot/rail guides in the table, however its quite easy to add making a supplimentary top, you shouldn't need to though. I can see why they didn't though as would have to cut a slot though the profile that surrounds the CMS.
What I don't quite understand is the fuss around aligning the fence. If you want accurate positioning for a rebate for example, use a bearing guided bit to get the right off-set. As for aligning the fence parallel with the table, it doesn't need to be, bits a round so the angle of the fence doesn't matter. The main time it would is when using the sliding table, and iy you do this its simple, you clamp a pice of wood on the sliding table, pull the sliding table to one end and clamp one side of the fence by pushing it to the wood, slide the table to other end and do the same, you then have the fence aligned perfectly parallel to the sliding table
I think you have to view the CMS as not being the last word in router tables, but rather a good onsite router table option, that excels for planing operations, and for profiling with bearing bits. For fine box making etc, you need to have a supplimentary fence such as the incra. I think for no mobile work, you can get better router plates, lift mechanisms (CMS with the OF2200 isn't great, as it lifts from one side you can get binding) and fences
DuncanK
Offline Offline
« Reply #71 on: August 15, 2012, 12:36 AM »
OMG, dealer in Vancouver sent me an email. I have been in tele-com training for past 4 months and only 2 days left.
This is a great gift.
THANK YOU Smiley I'm a little excited if you cant tell hehe
Wooden Skye
Offline Offline
« Reply #72 on: August 16, 2012, 08:56 PM »
On October 16th from 6:00 to 8:30, the Woodcraft store in Norwalk, CT, is having a demo/lecture on the CMS Router table.
Bryan
TS 55, (2) 1400 Guide Rails, MFT/3, Domino DF 500, 2 domino systainers, ETS 150/3, RO 90, CT 26, (2) OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, sys toolbox, (2) sys mini
RL
Offline Offline
« Reply #73 on: August 17, 2012, 10:34 AM »
Maybe this post should be in the sysport thread, but I thought it would be useful to post it here in advance of the release of the CMS router module. Other members may find the dimensions to be of benefit if they want to build their own storage solution in advance of getting the CMS. I have had my CMS module for almost a year, but have found the various parts extremely awkward to store. This is my sysport solution.
The sysport has the same overall dimensions as my other sysports, but the upper shelf is deep enough to accommodate the awkwardly-sized fences. Below I can fit several systainers- I will add the last couple of shelves as needed.
I always use 14" full extension drawer slides. These allow enough room to pull the shelves out and leave the systainers in the open position.
The upper shelf has 11" of room, and is 15" deep. This is about as small as you can make it if you want the large fence to fit. The lower section has 17" of room. Overall width is 38" wide and 35" high to match my other sysports. I painted them moon grey (Behr paint) which is a close match to the colour of a systainer.
You can see I use a sys 2 to store my OF1400 accessories and the CMS router module accessories. I have room for another sys 2 above it on its own shelf, or 2 x sys 1 on shelves.
P.S. You can see the INCRA shop stop fits on the CMS fence...good for stopped routing operations.
« Last Edit: August 17, 2012, 10:36 AM by Richard Leon » Logged
I like green.
RonWen
Retailer
Online Online
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #74 on: August 17, 2012, 10:50 AM »
I use the Kreg Micro adjuster on my router table -- it works fairly well too about .005" which is fine for most tasks.
I was using a 3-1/2" diameter router bit this morning & was wondering -- did I read somewhere (in this thread?) that the CMS router hole is much smaller?  Unsure
RonWen
Retailer
Online Online
WWW
« Reply #75 on: August 17, 2012, 11:24 AM »
Quote
It's slightly bigger.
Bigger than 3-1/2"?
RonWen
Retailer
Online Online
WWW
« Reply #76 on: August 17, 2012, 12:16 PM »
Slightly bigger than 3-3/4".
That is plenty big enough and I'm quite sure the 1400 router would have enough power available.
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #77 on: August 17, 2012, 12:24 PM »
The 1400 & 1010 are right at 2-3/4".
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
RonWen
Retailer
Online Online
WWW
« Reply #78 on: August 17, 2012, 07:27 PM »
OhhhhKAY...  Huh?!
jimbo51
Offline Offline
« Reply #79 on: August 23, 2012, 10:38 AM »
I just received an email about the new tools, CMS, impact driver and roller stool. After the description of the CMS, there was the following line:
"See your preferred Festool dealer for more information about the Domino XL or visit our Domino Joiner family website"
The email then went on about the impact driver etc. I think someone did a cut and paste from the last announcement and did not read the final email before sending it out.  Tongue Out
Dan Pfeiffer
Offline Offline
« Reply #80 on: August 24, 2012, 11:30 PM »
How is the miter gauge for the router table different from the MFT/3 miter gauge?  Looks like it might just have a different fence?
Dan Pfeiffer
Euclid, OH USA
Festools: M0064 apron, tape measure, Denim Shirt
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #81 on: August 25, 2012, 12:38 AM »
Dan,
It's very similar. It has a longer "arm" and a shorter fence. Otherwise, it's very similar. Edit: the "arm" I refer to is shown in the image below. It's much shorter on the the MFT/3.
I will note that the flag stop from the MFT/3, which can be ordered as a spare part, makes a good stop for use with the miter gauge and fits in the fence profile.
Shane
« Last Edit: August 25, 2012, 01:08 AM by Shane Holland » Logged
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #82 on: August 26, 2012, 11:07 PM »
Just a note... it originally said on our website that the CMS could use the table extension for infeed purposes and that was incorrect. It was corrected shortly thereafter but I wanted to make sure that everyone was aware of this information to make the best purchase decision. The table extension can only be used for outfeed. The power switch blocks use on the infeed side.
Mr. Jeff Smith
Offline Offline
« Reply #83 on: August 28, 2012, 03:38 PM »
Really happy to see Festool bring this to the U.S.  Unfortunately I have the MFK700 and OF2200, so I'll be waiting to see what it takes to get the OF2200 in there.  I noted the pricing, will there be any introductory pricing or is that price the regular MSRP?  Thanks.
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #84 on: August 28, 2012, 03:52 PM »
No intro specials, sorry.
Mr. Jeff Smith
Offline Offline
« Reply #85 on: August 30, 2012, 11:16 AM »
No worries, just asking in case I should have considered picking it up even without the router in hand.  Thanks.
Nick C
Offline Offline
« Reply #86 on: August 31, 2012, 10:15 PM »
Someone mentioned using the sliding table + miter gage for coping rails. Is this really recommended? The parts would have to be very robust.
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #87 on: August 31, 2012, 10:18 PM »
Yep, it's robust. Here's a video from Brice showing it with the miter gauge being used.
« Last Edit: August 31, 2012, 10:20 PM by Shane Holland » Logged
Martin Johnson
Offline Offline
« Reply #88 on: August 31, 2012, 10:33 PM »
No issues at all.  I built a three piece entertainment center with a number of doors...worked like a charm.
fletchtool
Offline Offline
« Reply #89 on: September 01, 2012, 12:16 AM »
Can you change router bits in an OF1400  from above the table? The Festool official video, although it is titled OF1400, only shows an OF2200 being changed from above. I have seen another video on youtube where the guy is changing the bit on a 1400 from under the table and it looks like a real pain to do. I have another question; does a regular 36mm hose fit the in-fence dust port?
Fletchtool
Pages: 1 2 [3] 4 5 6 7 8 9 10  All   Go Up
  Print
Jump to:
