Pages: 1 [2] 3  All   Go Down
  Print
Author Topic: Consolidated Q&A for Domino XL DF 700 Joiner  (Read 20155 times)
Shane Holland
Festool USA Employee
FOG Administrator
Offline Offline
WWW
« Reply #30 on: March 25, 2012, 10:29 AM »
Currently, there's no option to purchase the bins separately, nor do I know of any plans to offer them separately.
Shane Holland | Festool USA | Sales: 888-337-8600 | Service: 800-554-8741 | sho@festoolusa.com
Faster. Easier. Smarter.
Power Tools, Domino Joiners, RRP HEPA Vacs, Track SawsDrywall Sanders, Cordless Drills, Tools for Painters, LED Worklamp, Router Tables
RussellS
Offline Offline
« Reply #31 on: March 26, 2012, 10:18 AM »
the width is the same. Here are the 8 & 10 mm tenon sizes for the XL.
8 x 22 x 80 mm
8 x 22 x 100 mm
10 x 24 x 80 mm
10 x 24 x 100 mm
Here are the measurements for the DF 500.
8 x 22 x 40 mm
8 x 22 x 50 mm
10 x 24 x 50 mm
Just checking, but will the Domino XL also cut mortises to fit the DF500 tenons?  Will the XL cut mortises for 8x22x40 and 8x22x50 and 10x24x50 tenons?
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #32 on: March 26, 2012, 10:20 AM »
The depth spec' is 15-70 mm so it should work fine.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #33 on: March 26, 2012, 10:25 AM »
Russell, for the 8mm and 10mm tenons, yes.
For the 4mm, 5mm and 6mm tenons, no.
Christopher Robinson
Offline Offline
« Reply #34 on: March 26, 2012, 07:47 PM »
Does anyone have examples of what the Domino 500 can do that the Domino XL cannot?
(not just ---"it can cut smaller" ...rather what specific project types can't be done with the XL that can with the 500...)
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #35 on: March 26, 2012, 08:12 PM »
Well, I think the XL would be useless for 1/2 plywood, most trim, etc. since smallest tenon is 8mm.    You could use the XL for aligning panels, but it would be overkill.
Peter Halle
Global Moderator
Online Online
WWW
« Reply #36 on: March 26, 2012, 08:14 PM »
The 500 can be used on 1/2 inch thick material.  Drawer joints can be made for instance using the 4 mm bit.  The commonly used convention is that your tenon should be approximately 1/3 the thickness of your material.  Using that as a basis, any jointing with materials less than 3/4 thick would best be served by the 500 versus the XL.  As Brian (a Festool Trainer) showed at the show last week, it is possible to use the smallest domino size possible with the XL on 3/4 inch stock - IF you are comfortable with the remaining wood material on either side of domino that results.  If so - go for it.  The cutter length is also greater in the XL so you are inserting more of a tenon into each side of your joint.
I hope others will give more examples for you.
Offline Offline
« Reply #37 on: March 26, 2012, 08:21 PM »
Thank you.
So far, sounds like I'm going to have to get both
Good looking out Festool
jacko9
Offline Offline
« Reply #38 on: March 26, 2012, 09:11 PM »
Peter,
My Domino 500 is perfectly suited for most of my cabinet and furniture needs however, with large doors or large case work, the extra thickness of tenon and length of the tenon capability of the XL 700 is a great addition to my tooling.  Previously large m&t  work was a table saw and hand chisel operation since my previously owned slot mortising table couldn't handle the weight of the large pieces.
Jack
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #39 on: March 26, 2012, 10:13 PM »
I have some French doors that were part of a remodel just prior to my buying this house. The doors appear to have been originally made OK but the installer was an idiot and since, they have deteriorated and have always let in water. They installed everything as if the weather was coming from inside??? I did some poor remedial work but now:
I need to rebuild the whole lot so this new M&T machine should come in perfectly.
I'm ready to put it to use and hopefully, it will happen quickly.
[ Edited by Shane - typing around the word filter ]
« Last Edit: March 27, 2012, 08:06 AM by Shane Holland » Logged
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
jacko9
Offline Offline
« Reply #40 on: March 26, 2012, 10:17 PM »
I wish I had a digital camera when I built a series of Honduras Mahogany exterior doors to show the large mortise and tenon work that took "forever" to cut.  With the new Domino XL 700, this work would have taken 1/10 the time (at least).
Peter Halle
Global Moderator
Online Online
WWW
« Reply #41 on: March 26, 2012, 10:24 PM »
Jack,
You will LUV the XL.  The examples that Brian did for the show were killer.  I got a quiet moment to talk to him and gave him an example of something that I thought about being cool to do and all he could say was that " You are thinking in a parallel universe to something I saw Germany working on."  He couldn't expound on that (I didn't ask him to) and neither will I.  But if it happens it will be cool!  REALLY COOL.  REALLY, REALLY COOL!
The XL rocks and will open up a new creative avenue much like the original did with the added benefit that there is already a huge user base of the original.
I can't wait to see to see the uses and the work that is produced once it is available every where.
Kev
Online Online
« Reply #42 on: March 27, 2012, 04:58 AM »
Jack,
That's a cruel level of teasing ...
Offline Offline
« Reply #43 on: March 27, 2012, 01:30 PM »
Perhaps beating a dead horse on the Domino500 vs. Domino XL and the cross-product accessories and functionality...
Still, I'm curious, praying, kneeling, wondering if the Domino XL will/can ever have a cutter in the future than can cut thinner dominoes; all the way down to the thinnest that Domino500 is capable of perhaps?
If no plans, curious if this is a mechanical limitation or just a marketing decision?
I was hoping for one Domino to rule them all.
Someone, please make me feel better and tell me there are either plans for a cutter that can do thinner dominoes on the XL in the future...
Or that the product actually has a mechanical limitation that won't ever allow this (whether or not this was an engineering or marketing decision I don't care)...just so that my hopes of one Domino purchase can finally be crushed and I can stop daydreaming Smiley
PS Festool USA marketing and Festool HQ if your watching.  I don't have a domino yet, and if I have to buy two, I plan on buying a used 500 not a new one...marketing would make customers happy if they found a way to build functionality of both dominoes into the XL.
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #44 on: March 27, 2012, 01:41 PM »
Of course we (Festool) are watching. I started this thread after all.  Wink
I really doubt we will ever see smaller cutters for the XL. I don't know the reason because I'm not involved with those decisions. It's possible that it's to sell more tools (after all, that's how we stay in business), it's more likely that it's mechanical. I would imagine that a 70mm long, 4mm diameter cutter would be susceptible to breaking for instance. They're each designed for specific tasks, the same way we have a TS 55 and TS 75, sanders of different sizes and shapes, different size routers, etc. The OF 1010, 1400 and 2200 are made with the hopes of our customers buying all three models.
I really think each machine suits particular applications quite well with good overlap in the middle. I don't see a lot of customers needing both machines in most cases. With the Domino XL capable of mortising 3/4" material, that should do the trick for a large percentage of customers while still allowing for larger materials.
Shane Holland
Festool USA
jacko9
Offline Offline
« Reply #45 on: March 27, 2012, 05:31 PM »
I can tell you that I don't think that I would ever need a longer 4, 5 or 6mm tenon that I could plunge on the XL machine.
For the smaller 4mm through 8mm tenons, I would much rather be lifting my 500 Joiner than the XL which weighs another 4 to 5 pounds for a large series of cuts.
I'm all in favor of two separate machines for different purposes.
I have to retract that last statement.  I can see where I would use a deep plunge with a 6mm tenon for through mortise work on 20 - 25mm stock.
Jack
« Last Edit: May 02, 2013, 06:31 PM by jacko9 » Logged
Kev
Online Online
« Reply #46 on: March 27, 2012, 06:51 PM »
I would have liked to have been a bit smarter and less impulsive when I got the OF1400. Based on my needs (hobby DIYer) I got the correct advice from my dealer (particularly in hs expectation of non professional's typical spending). In retrospect I would have gone with combination of OF 1010 and OF 2200.
I say this because I think the two different Domino joiners span the joining spectrum well - one that can cover the entire joining range ... a Domino in the middle would only be ideal for the middle sized stuff, potentially cumbersome for the smaller stuff and under performing for the big stuff.
Don't get me wrong - the OF 1400 is a great router and I won't part with it ... But it'll be the one thay gets used the least when I have an OF 1010 for jigs and an OF 2200 inverted in a CMS module.
I suppose what I've just said could open a can of worms when you consider some sort of CMS module for the big Domino ... All of a sudden it needs be able to do fine stuff in the same way a big router can when it's in a table ....
... Urghhh - have I just reversed my own viewpoint ?   Embarassed
(and yes, you can put the OF 1400 in a CMS module).
RL
Online Online
« Reply #47 on: March 27, 2012, 07:08 PM »
Kev,
I understand where you're coming from, but I tend to disagree. I have the OF1400 and no other router. I use it all the way from heavy stuff in the CMS down to intricate work such as routing inlay with a 1/16" bit.
The big plus of having one router that does it all is that you only have to buy one set of accessories. I have all the different bases, edge guides etc. for the 1400. That's a big saving over having to buy them for two routers.
The only negative is that I cannot use the really big 3 1/2" panel raising bits in the CMS with the 1400 but it's a small price to pay.
Richard.
I like green.
Kev
Online Online
« Reply #48 on: March 27, 2012, 07:24 PM »
Kev,
Richard.
That's all right - I think I disagree with myself !
On pure economics for a DIYer, the OF 1400 makes perfect sense.
Was just trying to use the router range as an analogy for the Domino joiner range ... Beware the emergence of a Domino 600 Midi then  Scared Eek! Big Grin
Rembo
Offline Offline
« Reply #49 on: March 28, 2012, 01:18 AM »
I see no reason to XL had a small mill. with its size and weight, it will not feel comfortable at work, because it's DF 500.
so that the two Systainer even in this case will have to buy ..
oh, horror! they want to take our money! Scared  Smile
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #50 on: March 28, 2012, 02:03 PM »
I think this may have been mentioned or asked about, but we will have the tenon bins and dividers as spare parts. Spare parts can be ordered from your Festool dealer or directly from our service department (number below in my signature).
700715 Container bin
700716 Partition wall dividers
williaty
Offline Offline
« Reply #51 on: March 29, 2012, 01:36 AM »
What size Systainers will the two domino assortments for the XL come in?
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #52 on: March 29, 2012, 07:45 AM »
SYS 2
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #53 on: March 29, 2012, 10:32 AM »
Something else that I don't recall seeing mentioned here is that the Domino Assortment in the Systainer for the DF 500 now has removable plastic containers like the new ones will.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Rembo
Offline Offline
« Reply #54 on: March 29, 2012, 01:24 PM »
when you get your XL, do not throw out the white stopper. if it is shortened, it may be useful ..
Rembo
Offline Offline
« Reply #55 on: March 29, 2012, 03:23 PM »
and yet they are not cooked the rest! Add 5 mm to 75 mm lock.
but I still think there is an option .. to make special cutter length of 75 mm. Now it is 5 mm before the free movement of the window
Hookie
Offline Offline
Making stuff in the Midlands, UK.
« Reply #56 on: April 22, 2012, 05:53 AM »
My main question about the latest Domino is:
What is its exact market target? I raise this because surely the original Domino is suitable for making heavier M&Ts too. I believe the new model can handle longer biscuits and thicker sections of timber, but aside from the price, and the design,  what other differences are there?
Also, surely an original Domino can handle bigger section timber by using multiple domino biscuits in one joint.
One more query. Would I be best off buying an original Domino, just for home workshop use?
John  Smiley
It started with a : TS 55 REBQ-Plus-FS
Then parallel guides.... Extra tracks. Now a Domino 500! My shop is turning green and black.
Regards, Hook.
Kev
Online Online
« Reply #57 on: April 22, 2012, 06:10 AM »
John  Smiley
The new bigger domino plunges deeper and uses larger bits, so if you're making joints in bigger material, the bigger domino makes sense.
For home? What do you make at home? ... chairs, cabinetry, etc - yes the DF500 is ideal. If you like making large doors at home, you probably want the 700!
Hookie
Offline Offline
« Reply #58 on: April 22, 2012, 08:36 AM »
Thanks Kev,
The only large doors I might make would be garden gates, and the like.
I am dubious about switching from old style wedged, through M&Ts for those jobs,  so maybe the older Domino would suit me.
On the other hand, the new one should do all that the older one can, and the facility to go larger is always there.
 For about £300.00 extra I suppose I might as well go for the new model. Just means a bit more saving-up to do!  Big Grin
Thanks for the info.
Regards
John  Smiley
Regards, Hook.
Kev
Online Online
« Reply #59 on: April 22, 2012, 11:22 AM »
Thanks Kev,
Regards
John  Smiley
Don't look at the DF500 as "the old model" - its the model that cuts smaller mortises. The 700 doesn't cut the smaller holes as of today ... So be very aware of the size dominoes you wish to use before you buy - you need both domino machines to cover the full spectrum of dominoes.
Pages: 1 [2] 3  All   Go Up
  Print
Jump to:
