Shane Holland
Festool USA Employee FOG Administrator
Offline
« Reply #30 on: March 01, 2012, 06:18 PM » |
Quick follow up... I'm not in the office today but a colleague just confirmed that we received some of the blast gates and had a look at them. As long as you don't close it, there's no drop in CFM as I suspected.
Glad to help.
Brian.ca
OfflineMember Since: May 2009
« Reply #31 on: March 15, 2012, 04:13 PM » |
Hi Shane, I had a few questions from the perspective of someone looking to try the planex under the 30 day guarantee
1) What comes with the tool package? In particular, b/c I heard it improves usability greatly, does an interface pad come with it? How about any sample abrasives? 2) B/c I'm mostly looking to just try it at the moment I'd probably just use it with my CT33 + dust deputy. Could you edit in the part # and price (USD/CAD) of the planex hose into the original post since that seems like a required item (at least in my case). 3) What abrasives would you recommend as a good starting point? 4) How do consumables work under the 30 day guarantee? I would assume you can't return an opened & incomplete box of sandpaper but if the tool comes with a sample pack I would figure using those shouldn't be an issue?
Shane Holland
Offline
« Reply #32 on: March 15, 2012, 07:36 PM » |
Brian, sorry for the delay getting back to you on this. See my responses below, let me know if you still have any questions. Thanks. 1) What comes with the tool package? In particular, b/c I heard it improves usability greatly, does an interface pad come with it? How about any sample abrasives?
It does not include the interface pad (#496140, $40 USD/$46.20 CDN), which is optional and sold separately. I also don't believe that it comes with any sample abrasives, but I'd have to check to confirm or maybe one of our dealers on the forum can check for us. 2) B/c I'm mostly looking to just try it at the moment I'd probably just use it with my CT33 + dust deputy. Could you edit in the part # and price (USD/CAD) of the planex hose into the original post since that seems like a required item (at least in my case).
To clarify, you can use a standard hose but it will not have a positive locking mechanism with the Planex and could pull loose with a lot of movement. The Planex-specific hose is #496972, $150 USD/$173.30 CDN. 3) What abrasives would you recommend as a good starting point?
For general drywall sanding, I would say that 150 grit would be a good start. The Planex can remove drywall compound pretty rapidly, so go with a grit that's a step or two higher that would you might think you'd use. If you have stuff that's pretty rough, also add 100 grit. 4) How do consumables work under the 30 day guarantee? I would assume you can't return an opened & incomplete box of sandpaper but if the tool comes with a sample pack I would figure using those shouldn't be an issue?
Only the tool is covered by the 30 day guarantee. Accessories, like the interface pad, and consumables would not be covered and are not returnable unless your dealer offers a return policy beyond Festool's 30 day guarantee.
woodworldchicago
Festool Dealer
Offline
Chicagoland's Most Complete Festool Dealer
« Reply #33 on: March 15, 2012, 09:05 PM » |
Sample abrasive with the Planex: the ones I have in stock came with a sheet of 150 grit Brilliant.
Chip
Tom Bellemare
Festool Dealer
Offline
« Reply #34 on: March 15, 2012, 09:29 PM » |
'Same here, Chip.
Dogwood
Offline
« Reply #35 on: March 18, 2012, 02:33 AM » |
Hi there, Longtime lurker here and fairly new festool owner. First of all thanks for all the great info guys! Guess I'm getting a bit of extractor overload, I have a few questions for anybody wiling: 1. Does the CT AC simply blast air back through the filter to clear it? 2. What does the blast gate do then, or why would you want it other than containing dust when removing the hose? 3. If the filter is kept relatively clean why does it not still use a hepa filter? I realize it is not intended for RPP etc. but why go down in filter quality? 4. If a plastic bag can be used how does it keep from being sucked up into the filter? Thanks for any help, I am asking with concrete dust collection in mind. I will be doing a bunch of floor grinding and had originally planned on using my Midi and buying a Dust Deputy to collect the bulk of it but then the CT AC came out and I was curious if it was better instead (and also good for using on the job site with tools that create lots of bulk dust such as a table saw and router without the bulk of the Dust Deputy) I've seen that Makita has a new vac aimed at concrete which appears to be a rebranded Nilfisk, Hilti has one, and Pulsebac is another brand that specializes in them (BTW they have a cool video with a plexi sided vac and you see the "pulsing" of the filters, pretty cool!) anyways do they all use the same technology of blowing air back through the filters? in which case should I get the CT AC for the jobs mentioned? Thanks again and sorry for the length-my minds reeling I have to pull the trigger on something!
Shane Holland
Offline
« Reply #36 on: March 18, 2012, 09:36 AM » |
Hello and welcome to the forum. Here are the answers to your questions. 1. Does the CT AC simply blast air back through the filter to clear it?
No. A valve opens and closes to quickly create differential pressure. There is no "blast of air" or something blowing air through the filter. 2. What does the blast gate do then, or why would you want it other than containing dust when removing the hose?
Closing the blast gate while the AutoClean cycles will give the filter a more robust cleaning. You can actually see the sides of the tub get bow under the pressure it's so strong. Also, like you stated, it prevents spilling during transport. 3. If the filter is kept relatively clean why does it not still use a hepa filter? I realize it is not intended for RPP etc. but why go down in filter quality?
In the first post in this thread you can see a HEPA filter and the High-Performance filter than comes standard on the CT AC side by side. The HEPA filter is very rigid and has far more pleats which would trap the fine drywall dust. The High-Performence filter is still 1 micron, versus 0.3 micron on the HEPA filter. So, we're not talking about a dramatic difference in filtration levels. 4. If a plastic bag can be used how does it keep from being sucked up into the filter?
I'm no engineer and don't have a degree in fluid dynamics, so I can't give a technical explanation. I suspect it has something to do with a vortex that's created. The flow of air is from the inlet where the hose attaches straight up into the filter. So, the majority of the tub is unaffected by that suction. What particles do hit the filter are released during the AutoClean cycle. Thanks for any help, I am asking with concrete dust collection in mind.
Festool does not recommend using our CT dust extractors for hazardous materials, including concrete dust as stated in the manual. You should always use proper safety equipment including a respirator when working with such materials. There is a risk of particles not trapped by the filter being reintroduced into the environment.
Charimon
Offline
Tool and Tile Junkie
« Reply #37 on: March 18, 2012, 04:38 PM » |
Ok back when I was doing drywall, Columbia auto tools rock  - I had the PC. I kept it even after i sold off the rest of the professional tools. I have alot of experience with the PC - even to the point of putting 36 grit floor pads on it to deal with painted textured ceilings that owners wanted lvl 5 flat. So i feel the need to address several "advantages" of the planax that aren't. - A robust, sealed 2-speed gear box instead of their cable drive which is more likely to fail over time. The PC's cable can and occasionally does go out but it is a $27.00 replacement part that can be repaired in the field in under 15 min. I am willing to bet the price of a Planex that its gear box will not out last the life of 2 PC's let alone the advantage of 2 PC's if your crew has never went auto before- Switches and dials that are large and all within reach while operating the machine, right at your fingertips. The PC switch and speed control are also right at your finger tips - MUCH, MUCH less expensive abrasives lowering total cost of ownership While it is true that PC paper is expensive-- i dont know of anyone who actually uses the paper- I am sure there are some weekend warriors who might but--- This is from All Wall equipment-- Level 360 Sanding Discs 360 & PC7800 (25 Pack)Price 1 – 3 $21.99 This brings the Actual price In line with Planex or just below it. - A removable brush around the pad that can let you get right against adjacent surfaces. This is not a feature this is BAD as it will get lost and then the vac efficiency will go down until you buy a replacement - A rubber handle, theirs is plastic and gets quite slippery when you have dust on your hands This one is sort of funny as after a couple months of production use it will look like the rubber portion of my RO 150 or it will be gouged, hardened or completely coated with drywall mud and wont make much of a difference anyway The above comments are directed to those who looking at the Planex as a Production tool -- not as a Festoy to take out of the systainer once a year to freshen a wall before it gets repainted or as part of a contractors "dog and pony show" "The Dog and Pony show" element is a Huge Positive Feature for the small high end contractor who is aware that his customer is buying an "experience" as much as a finished product. having a demonstrable edge like a dustless drywall sander that you can bring to the presentation in its special box may Get you the Job at your bid price  this alone should make the tool pay for it self in a year. Now I really like the ability to shorten/lengthen it. That is a Huge feature and worth a couple $100 over the life of the unit. Over all, I may have talked my self into taking a long hard look at it. I know some online auto body shop venders are letting you buy large ticket items and have the payments taken out of your card over several months-----hmmmmm if it works for SATA.
« Last Edit: March 18, 2012, 04:42 PM by Charimon »
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
Shane Holland
Offline
« Reply #38 on: March 18, 2012, 05:26 PM » |
I'm not trying to debate these points, but I've personally used both units and have extensive feedback from professional crews who have used both. Those abrasives costs are slightly misrepresented in my opinion because it doesn't include the Radius 360 Power Pad @ $12/ea which are required in addition to the abrasives discs and have to be replaced regularly. The Planex doesn't require a backing pad like that. Plus, consider the longevity of the abrasives, which are not all created equally, especially with a brand I've never heard of. I have read and heard from PC users that the units break down regularly because of that drive cable failing. The fact that you know about the part(s) needed to replace it tells me that you've experienced at least one failure. From what I've been told, it costs more than that but probably included labor. If you don't have the replacement part in the field and know how to replace it, you're down for however long it takes to repair it. Time is money. I don't have any scientific data to share, but I can't imagine what it would take to break the metal gears in the Planex's gearbox. The speed dial was out of reach in my opinion and was on the underside of the handle where it was impossible to see without flipping the sander over. I found the dial to be rather small and stiff to turn. Just my perspective. Should you lose the brush section, which will safe in your Planex Systainer  , it should not significantly affect dust extraction since, unlike the PC, dust is extracted from the center rather than the outside of the pad in most applications. I don't doubt there are guys that have used the PC unit who found it to be satisfactory but they had no point of reference with which they could compare it. I think most everyone here should realize what Festool represents and the type of products we produce.
Charimon
Offline
« Reply #39 on: March 18, 2012, 05:59 PM » |
Should you lose the brush section, which will safe in your Planex Systainer  , it should not significantly affect dust extraction since, unlike the PC, dust is extracted from the center rather than the outside of the pad in most applications.That is something worth pointing out more directly!! as it is a feature that differentiates it self from the PC in a way that is important.. ...The PC sucks from the RIM and can leave sanding groves about 1" from the corner unless you are very careful and you cannot use it for inside corner sanding. I don't doubt there are guys that have used the PC unit who found it to be satisfactory but they had no point of reference with which they could compare it. I think most everyone here should realize what Festool represents and the type of products we produce. Cables do fail but many forget how long they have been running the tool (kinda like how a driver breaks on a roofing gun or framer) and lets face it it is almost a 20 yr old tool that Stanley is unlikely to update unless they get competition from some sector
Shane Holland
Offline
« Reply #40 on: March 18, 2012, 06:30 PM » |
I suspect those groves near corners have a lot to do with that doughnut shaped pad. In my experience, it causes the outside of the abrasive disc to make contact a lot more contact than the center of the disc due to cupping. Anyway, thanks for sharing your insight and keeping the conversation balanced.
Christopher Robinson
Offline
« Reply #41 on: March 19, 2012, 01:35 AM » |
Few questions: - What is the CFM on the CE 36 autoclean; doesn't appear to be listed anywhere? i.e. will it have the same (or better?) dust extraction power as the standard CE 36?
- If we also drop a HEPA filter in the CE autoclean and turn the autoclean off for woodwork, should we expect the unit to perform just as well on woodworking tools such as the 2200 router or is this unit designed in such a way as the performance would be degraded in any way?
- If we chose to drop a HEPA filter into the CE autoclean, would we use the same HEPA filter part number that is used in the standard CE36? Are they the filters the same size?
- If we drop a HEPA filter into the CE 36 autoclean unit and turn off autoclean, would we still get clean air? I understand that it isn't certified, but would it be possible to apply for and get HEPA certification down the line or will this unit just absolutely never get cert and never be RRP ready? Is it really a bad idea, is the standard 36E that was HEPA certified going to give you air that much cleaner?
- Can I use my multi-use bag from my standard CE36 on the CE36 autoclean for woodwork and expect the same results in performance and cleanliness inside the tub?
- With the multi-use bag on the CE36 autoclean, will the bag continue to 'self clean' itself even with autoclean turned off? Any change in functionality one might expect there?
- Would the boom part number for the CE 36 fit on the CE 36 autoclean? If not, is there a separate boom part number?
- Would the handle part number for the CE 36 fit on the CE 36 autoclean? (I think I saw a different handle offered for this unit, still I want to see if the original handle would also fit?
Thanks in advance, about to purchase.
Shane Holland
Offline
« Reply #42 on: March 19, 2012, 11:08 AM » |
It's the same motor in all of our dust extractors now, so 137 CFM. If we also drop a HEPA filter in the CE autoclean and turn the autoclean off for woodwork, should we expect the unit to perform just as well on woodworking tools such as the 2200 router or is this unit designed in such a way as the performance would be degraded in any way?
The AutoClean is essentially the same as the CT 36, except it has the high-performance filter (1 micron filtration) and the AutoClean functionality. Putting a HEPA filter in it, it would work just like a CT 36 (Non-AutoClean) model. If we chose to drop a HEPA filter into the CE autoclean, would we use the same HEPA filter part number that is used in the standard CE36? Are they the filters the same size?
The CT AutoClean and CT 26/36 all share the same accessories. The HEPA filter for the CT 36 will fit in the CT AutoClean. If we drop a HEPA filter into the CE 36 autoclean unit and turn off autoclean, would we still get clean air? I understand that it isn't certified, but would it be possible to apply for and get HEPA certification down the line or will this unit just absolutely never get cert and never be RRP ready? Is it really a bad idea, is the standard 36E that was HEPA certified going to give you air that much cleaner?
I would recommend not using the AutoClean functionality with a HEPA filter. There's no reason the filter wouldn't perform to specifications, so yes "clean air". There are no intentions to ever certify the CT AutoClean for RRP. "Clean air" is a product of the filter. If you put a HEPA filter in the CT AutoClean, it would be the same as having a CT 36 essentially, but without a certificate for RRP. Can I use my multi-use bag from my standard CE36 on the CE36 autoclean for woodwork and expect the same results in performance and cleanliness inside the tub?
Again, all accessories are shared between the CT AutoClean and CT 36. The results would be the same. With the multi-use bag on the CE36 autoclean, will the bag continue to 'self clean' itself even with autoclean turned off? Any change in functionality one might expect there?
You cannot use the AutoClean functionality with a bag installed, it won't work. A plastic liner is used in AutoClean mode. A bag can be used when AutoClean is not enabled. The long life bag does not have self-cleaning properties like the self-cleaning bag. Would the boom part number for the CE 36 fit on the CE 36 autoclean? If not, is there a separate boom part number?
Yes, all accessories are shared between the CT AC and CT 26/36. Same part number. Would the handle part number for the CE 36 fit on the CE 36 autoclean? (I think I saw a different handle offered for this unit, still I want to see if the original handle would also fit?
Same part numbers, same accessories. Let me know if you have more questions.
Offline
« Reply #43 on: March 19, 2012, 02:28 PM » |
Shane -
Thank you for the prompt reply and your thorough coverage of my questions (if your superior is watching: give Shane a raise!, this fella goes ABOVE AND BEYOND to help Festool customers).
Festool really did a good job in thinking ahead and making sure this unit was backwards compatible.
I'm putting my order in today from my local dealer for the auto-clean unit and look forward to having a product that can help me with woodworking in addition to helping me sand drywall on our house remodels.
Good lookin' out!
Christopher San Diego
dfwHomeRepair
Offline
« Reply #44 on: March 19, 2012, 09:48 PM » |
OK, I just received my new Planex and 36AC. It mentions being able to strip wall paper and paint. Are there special accessories for these processes or just a different abrasive?
Shane Holland
Offline
« Reply #45 on: March 19, 2012, 09:57 PM » |
You can use the Saphir 24 or 36 grit abrasives. Select the option for extraction on the outside of the pad for large debris. Welcome to the forum.
Offline
« Reply #46 on: March 27, 2012, 03:46 PM » |
Put in my order for the CT AutoClean (without the planex I'll have to expand to that later). My sales rep didn't seem to know.Does the extractor by itself come with a hose like the ther CT's? If so, what is the length and diameter/connections?
These things will start shipping from Festool April 15th as far as anyone knows right? (unless you were one of those lucky few that already have the unit)
I am new to Festool products, just geared up with several things, waiting on the CT AC before I start working, don't want to mess with anything on a shop vac.
Thanks in advance- Christopher San Diego
Shane Holland
Offline
« Reply #47 on: March 27, 2012, 03:50 PM » |
Christopher,
The CT AC comes with an 11.5' hose that's 36mm in diameter. All other CTs come with a 27mm hose. If you plan to use it with sanders or the Domino you've mentioned buying, for instance, you'll need a 27mm hose. These are already shipping and have been shipping to dealers for weeks now.
Shane
Offline
« Reply #48 on: March 27, 2012, 04:25 PM » |
Christopher,
Shane
Thanks Shane for the good news in that they are already shipping, will check with my dealer again see if there was an update on ETA. I ordered it last week and dealer and I were under impression that it wasn't available by Festool in US till April 15th...will double check with them (it could be specific to the dealer) for an update on ETA. A day or two earlier arrival might make the difference between getting to use it before my St. Martin trip or not (Yes, I will be thinking of my Festool on my beach trip...that is the kind of awesome impression these tools leave on a person---don't tell the wife!) The 11' ish long 36mm hose shipping with the CT AC is definitely a benefit for me over the 27mm and in another thread I can see that I can mod that setup to work so I can easily switch between the 36 and 27...not sure if the 11 will be to long for things like hooking up kapex where I understand a shorter hose might work better...I will sort that out by trial and error and you guys have those Y connectors I can always branch a shorter line from source away from boom for that, thanks for the good news. Is this hose with the CE AC an anti-static type with standard fittings (or is this a planex specific hose) ? i.e. is this the hose that is specific to the planex (or does the Planex also ship with its own hose specific to its functionality---I was under impression it has a different connector though for most every tool it will connect fine)? PS. Festool is the Ferrari of tools (as many already know). Both on product performance and service. Shane, you as always contribute to that service performance...hands down, nobody else provides this thorough, fast response in the industry. Kind thoughts- Christopher
Shane Holland
Offline
« Reply #49 on: March 27, 2012, 04:30 PM » |
The hose is somewhat specific to the Planex in that it has a flange on the connector and it's lightweight compared to the standard 36mm hose. This allows you to positively lock it onto the Planex. The only tool that accepts a 36mm hose that it won't work with that I can think of is the HL 850 planer. It will work fine with the Kapex, TS saws, and other tools. It is antistatic. And, I'm just doing my job, trying to help you guys out. I like that I can try to give each of you the same level of service that I wish I received from the companies I do business with. That's my goal.
« Last Edit: March 27, 2012, 04:38 PM by Shane Holland »
avcustominteriors
Offline
« Reply #50 on: April 03, 2012, 03:49 PM » |
Hi Shane,
In the videos posted and some pictures I see 4 green dials on the vacuum. In a few other pictures I have seen 3 dials. What is the 4th dial? The 3rd dial I'm assuming is auto clean but what is the 4th and will it be on the vacuum? I don't want to buy something and assume it has it, I have done that too many times because of specifications that were incorrectly listed or incorrect pictures posted. It only causes problems and I just want to clear that up.
Since the auto clean vacuum does not have a HEPA filter, does it exhaust more air than say the regular CT 36? I don't have experience with a CT 36, but my MIDI doesn't blow much air at all really. Im concerned about blowing dust around. I'm asking because I own the porter cable vacuum & drywall sander an the PC vacuum exhausts a lot air so it tends to blow around dust that hasn't been sucked up.
Also, will there be a CT 48 AC auto clean in the near future?
Thank you for your time.
TJ
Shane Holland
Offline
« Reply #51 on: April 03, 2012, 03:56 PM » |
TJ, welcome to the forum.
There's an additional dial on units in Europe that's not applicable to the US version. There will just be a blank over the spot where that dial would appear on European models. So all US models have three dials.
All CT models should blow roughly the same volume of air, which should be relative to the CFM of 137. I would characterize the exhaust as not being very strong at all. I'm sure members with other CT models can offer their opinions of the exhaust.
Edit: and no current plans for any other sizes of AutoClean models.
avcustominteriors
Offline
« Reply #52 on: April 03, 2012, 04:37 PM » |
Excellent. Thank you for the fast reply. Maybe someone could chime in on the exhaust. Anyone have any experience with it yet? No 4th button, no big deal. I do wish Festool provided more European products here in the US. I feel the US seems to get short changed on some products, but I may be wrong. I tried ordering the package from a few dealers but was told it was backordered. I will try some more dealers and see if I get the same response. Thank you again.
rickets
Offline
« Reply #53 on: April 03, 2012, 05:56 PM » |
I haven't had any real problems with dust getting blown around. This was cleaning up after sanding drywall at a friends house. I was also using a Midi- but from the specs, it sucks roughly the same amount of air as it's larger counterparts ~137cfms. There is some dispersal, but only when I rolled it directly through the pile of dust. Only other way of curing this problem is to have the exhaust pointed up, which wouldn't make sence to me.
Kapex w/ UG-Kart, Domino, Planex, T15+3, Centrotec Installers Kit, TS75, PSB300, RO150, RS2E, DTS 400, OF2200 w/Imperal set, OF1400, MFK700, HL850E, CT33, New Midi, CT36AC, MFS400+700 extensions, Parallel guide set, LR32 with 55" track, boom arm set, MFT/3, Kapex MFT, and some other accessories.
Offline
« Reply #54 on: April 09, 2012, 06:58 PM » |
Christopher,
Shane
San Diego dealer says 36AC is on hold and back ordered with Festool. I ordered weeks ago...they say Festool doesnt have any. Is tbis possibly correct?
Tom Bellemare
Festool Dealer
Offline
« Reply #55 on: April 09, 2012, 06:59 PM » |
I have some...
Shane Holland
Offline
« Reply #56 on: April 09, 2012, 07:05 PM » |
As of right now, yes, I believe there is a back order situation on the CT AutoClean due to higher than expected demand. I know there are multiple shipments inbound from Germany, including one that should have been here at the end of last week or beginning of this week.
Offline
« Reply #57 on: April 09, 2012, 07:36 PM » |
Thanks Shane.
Yah apologies for the random (is it in yet!?) questions; I'm sure you have better things to do.
I'm sitting on a set of new Festools with no dust extractor to put them on because I decided to go with the AC as opposed to the non AC.
My Festools 'tell me' they are NOT going to let me connect them to an old shop vac---snobs
If you are in the same office, and stop by the shipping manager---please do drop him my name (San Diego) and have him ship ahead of all others.
Checks in the mail?!
On a serious note, I'm glad the stories are jiving now, I like my dealer, just inpatient and wanted to make sure it wasn't that they weren't on point getting orders in.
Christopher
Offline
« Reply #58 on: April 13, 2012, 07:06 PM » |
Shane/Festool/Tom -
Thanks, got my 36 AC delivered today. I'm having a blast. (With my blast gates)
Shane Holland
Offline
« Reply #59 on: April 13, 2012, 07:59 PM » |
Awesome. Glad you were able to find one in stock and Tom was able to help you out.
