rickets
Offline
« Reply #60 on: April 18, 2012, 03:30 AM » |
OK, here's my impression of the planex after using it on a high end level 5 smooth finish job. On the walls- Stock pad, using Brilliant 150 paper. Vac at max along with the ac interval at max. Motor speed was at 2 1/2- 3. Suctioning number 3-4 and inside pad extraction. Flew through the walls and made them slicky smooth. Really. Four rooms in 30 mins. Ceilings was a completely different story. The wall configuration made some deep swirls and was somewhat hard to control. So, I switched it up to this: Used the soft pad backer with the sponge insert. Used 180 Brilliant and left the vaccum as is. The settings on the planex was motor 2, suctioning was 4, and inside pad extraction. Still left some swirl marks, but was taken care of in the final touch up. Really worked the shoulders though. Almost like running a bazooka for the day. But again, flew through the ceilings, approx. 1250 sq ft in 30 mins. Just things to watch for is when bringing the planex away from the work, make sure you still have the head on the work. If you bring it off too soon, you'll just be flouring the room with the uncollected dust. Noise wasn't bad at all. Also, you have to time it where the auto clean function fires off, don't be sanding. The suctioning stops and the head slightly lifts off, putting a cant on the pad and digging in. As I use it more, I'll fine tune it to where I can start saving my shoulders.
Kapex w/ UG-Kart, Domino, Planex, T15+3, Centrotec Installers Kit, TS75, PSB300, RO150, RS2E, DTS 400, OF2200 w/Imperal set, OF1400, MFK700, HL850E, CT33, New Midi, CT36AC, MFS400+700 extensions, Parallel guide set, LR32 with 55" track, boom arm set, MFT/3, Kapex MFT, and some other accessories.
jallen03
Offline
« Reply #61 on: April 26, 2012, 09:22 PM » |
So after a week or two of flipping back and forth, I decided to go with the CT 36 AC instead of the HEPA version. I plan to use this with a combo of woodworking and some drywall, but got this b/c i was extremely interested in trying out the collector with a router table or shop cleanup and not use a bag for those activities. I was surprised to find a self cleaning bag with the vacuum as well as the advertised AC bag liner! I prefer the 36mm hose to the 27mm hose, and with the addition of the hose adapter from Bob Marino, it makes it a serious cost contender for someone that wants a 36mm hose but doesn't care about HEPA certification...even if you don't use the autoclean function. I've only had the CT 36 for a day (just bought my first Festools a month ago), and am deeply in love
MrMac
Offline
« Reply #62 on: April 30, 2012, 09:56 AM » |
this is quite exciting, as my wife and I want to remove all the popcorn off of our ceilings. There is a lot! and I've been dreading doing the water/drywall knife method that will take me all summer. I already have a CT26, so that's 1/2 the battle. Next to convince my dear wife that this is the only solution  bwahahahahahaha
serving the greater Vancouver area.
Peter Halle
Global Moderator
Offline
« Reply #63 on: May 06, 2012, 09:43 AM » |
Shane,
Has anyone tried the Planex on floors? Just thinking that with the larger pad and the variety of grits, it might be an interesting use.
Shane Holland
Festool USA Employee FOG Administrator
Online
« Reply #64 on: May 06, 2012, 10:29 AM » |
Has anyone tried it? I'm not sure. But, that's not it's intended purpose. So I would probably recommend against using it for that.
Dave Reinhold
Festool Dealer Affiliate
Offline
« Reply #65 on: May 06, 2012, 02:14 PM » |
Peter, that was my first thought too with the planex, sanding a floor. I was thinking the planex would be good for light sanding between coats, or sanding a porch floor. I might have to try it out and see.
Dave
rickets
Offline
« Reply #66 on: May 09, 2012, 12:19 AM » |
Here's a technique to save your shoulders when sanding ceilings. Instead of having the whole planex parallel to your body, try having it perpendicular to your chest. The Planex head would be over your head, but I tell you, my shoulders could take that much more than sanding across my chest. Sure your head is going to be on full tilt, but I could hold it all day and not tire out. Course, when you get into corners and edges, you'll have to do the best you can, but man that saved my shoulders a ton!
Budu
Offline
« Reply #67 on: May 26, 2012, 01:52 AM » |
Hi everyone, new to this board and owner of a ct36 ac. Just wanted some help as to using the hose that came with this vac. In order to use the sanders, will I have to purchase a 27mm hose or is there an adapter? If so, could you tell me what the part number is?
Thanks for the help.
jallen03
Offline
« Reply #68 on: May 26, 2012, 05:59 PM » |
Hey Budu,
I bought a 27mm connector hose from Bob Marino...its a 27mm AS hose (about 1.5 ft long) with a 27mm connector on each end. Works great.
Tom Bellemare
Festool Dealer
Online
« Reply #69 on: May 26, 2012, 06:19 PM » |
ericbuggeln
Guest
« Reply #70 on: June 11, 2012, 11:32 PM » |
Are you guys using Brilliant 150 for final sandings? I exclusively use Brilliant 220 with my RO150. Thanks Eric
SRSemenza
Global Moderator
Offline
« Reply #71 on: June 12, 2012, 12:43 AM » |
On wood? Drywall? Planex? Autoclean? Huh?  Seth
Festool Service 800-554-8741
Johncarlo
Offline
« Reply #72 on: June 12, 2012, 09:01 AM » |
Hey Eric, I use 150 to 180 for my rough sand and 220 for my final sand on drywall. It will give you a smooth finish. Awsome tool! Enjoy  Johncarlo
ericbuggeln
Guest
« Reply #73 on: June 12, 2012, 12:50 PM » |
Thanks John, so you always do two passes?
Seth, Auto Clean on finished drywall only, Eric
ericbuggeln
Guest
« Reply #74 on: June 12, 2012, 01:17 PM » |
I just did the math. 51 sheets of drywall. How many 150s and 220s would i go through? Festool Products takes 29 hours to ship stuff to me and I dont want any down time. Thanks Eric
Johncarlo
Offline
« Reply #75 on: June 12, 2012, 06:17 PM » |
Hey Eric, One to two of each, maybe more if the electrical boxes aren't flush. One box of each is more then enough and will last you a few jobs. Two coats of mud and then the rough sand gives me a level field to skim. It also fills in any air pockets. 220 on the skim and your left with a smooth finish  . Enjoy the lack of dust! Johncarlo
MrMac
Offline
« Reply #76 on: June 15, 2012, 09:23 AM » |
I am wondering how does one know when to stop sanding? my purpose will be to remove the popcorn from the ceiling of our home, and if that works I will add it to the services that I provide, (crown, baseboard etc) would it be easy to sand through the drywall paper? and how do you know that you've sanded enough, so that you don't have to get up on a ladder with a light to examine every square foot to see if all the popcorn etc is gone? We have heard from friends that they are getting estimates anywhere from 4 to 7k to have a crew come in to remove the popcorn ceilings. This involves the water/scraper method and it's associated mess. How big is that sanding pad? it looks like it's about 9" or so? How do you avoid damaging adjascent walls/crown when you remove the guard? I wouldn't want to have to go back and touch up paint due to damage from the sander. I've looked at the utube videos, they seem nice, but I would like to see a video by someone that is an end user, sort of "real life" conditions.
Thanks!
Shane Holland
Online
« Reply #77 on: June 15, 2012, 11:23 AM » |
Stop sanding when you see daylight.  I think it just takes some practice but there's a quick learning curve. Remember, we have a 30-day money back guarantee, so you can get it and try it out risk free. Using a higher grit will lessen the likelihood of scuffing or damaging the drywall paper. You'll quickly learn how fast you need to move across the wall or ceiling surface to achieve optimal results so that you don't have to inspect every square foot. The abrasives are 8.85", 225mm, and the pad is slightly smaller than that, 215mm. Well, the brush/guard is there to prevent damage to adjacent surfaces but even with it removed there shouldn't be contact as the pad housing acts as an offset for the paper. Here are some videos I found from end users, mostly in other countries, doing a quick Youtube search. I thought someone here on the forum had posted about using it for popcorn ceilings but I can't remember if there was a video. I'll have to search for the thread. Edit: OK, I found the thread and video. http://festoolownersgroup.com/festool-tool-reviews/planex-225-used-for-ceiling-texture-removal/
Another thread with photos of popcorn removal: http://festoolownersgroup.com/festool-tools-accessories/planex-first-try/
« Last Edit: June 16, 2012, 11:14 AM by Shane Holland »
JLB builders LLC
Offline
« Reply #78 on: July 18, 2012, 12:31 AM » |
So does the support strap harness come with the Planex? Adding another $150 for the Planex hose and CT36 AC, then the extras like the caddy that holds the planex $40 dollar pad etc. Whew. Why don't they just do a complete package Planex/CT36AC and all the extra accessories  ?
Shane Holland
Online
« Reply #79 on: July 18, 2012, 07:36 AM » |
The harness is sold separately and comes in its own Systainer Maxi, #496911. http://www.sanderfordrywall.com/accessories/
UgoSC
Offline
« Reply #80 on: September 20, 2012, 03:17 AM » |
I own the Planex and CT AutoClean and can not imagine living without either. The Planex has allowed me to take on larger drywall projects that I had been subbing out, mostly because I didn't want to do the sanding. Now I can wipe out a room in no time. After just a few jobs the tool has paid for itself and I can actually way away when finished without looking like a ghost.
Now for the question. I purchased the AutoClean to replace my older CTmini and I am pretty happy I did. The only problem I am having is switching from sanding drywall using the liner bag to using my other tools and using the self cleaning bag. When you open the top of the AutoClean the entire undercarriage is completely caked with drywall dust. I have tried many different ways to clean the inside of the vacuum but truth be told it is very difficult and time consuming. the last couple of times I just took the whole thing outside to an open area and used my compressor. I am hoping someone has a better way to clean the inside of the vacuum so that you can switch from the liner bag to the self-cleaning bag quickly.
Thanks,
Scott
Shane Holland
Online
« Reply #81 on: September 20, 2012, 09:17 AM » |
Welcome to the forum, Scott. Glad you are finding the Planex a good investment, sorry about the issues you're having with it getting caked with dust. Could you post a photo or email it to me at sho@festoolusa.com so we can see what's going on? Granted, I've never run the Planex all day long, but in my experience there was some dust clinging to the inside of the CT, but I wouldn't call it caked at all. Drywall dust can be messy stuff though.
Tom Bellemare
Festool Dealer
Online
« Reply #82 on: September 20, 2012, 11:53 AM » |
Could you just ignore it, put the other bag in, and go?
Bikeboy80
Offline
« Reply #83 on: November 03, 2012, 09:07 PM » |
Is there a limit to the number of extensions that can be used?
I am currently looking at a job that involves removing popcorn ceiling in a whole home, many of the ceilings are high 12-15' with multiple angles. Seems like the Planex may be my solution but only if I can get to the ceiling with it.
The Green Koolaid sure is sweet... Kapex w/crown stops, Domino DF 500 Set, Syslight, RTS400, RO150, OF1010 w/LR32 Kit, TS75, 75" + (2) 55" rails, RO90, ETS125, RAS, Custom abrasive systainer, CTmini, CT36AC w/blastgates, PLANEX w/harness , T15 set, MFT/3 cross cut, Universal Cleaning set, Turbo Suction Brush, 12 drawer Sortainer, Extra Systainers with job specific tool collections Drumm Associates Home Remodeling
Tom Bellemare
Festool Dealer
Online
« Reply #84 on: November 03, 2012, 09:31 PM » |
I don't see any reason you couldn't reach that ceiling. I would certainly want the harness though.
Bikeboy80
Offline
« Reply #85 on: November 03, 2012, 10:20 PM » |
Ok, so I understand it comes with one extension. With that installed will it reach an 8' ceiling?
(Then I can figure out the number of additional sections that I will need.)
Each extension is about 20" correct?
Tom Bellemare
Festool Dealer
Online
« Reply #86 on: November 03, 2012, 10:58 PM » |
I guess it depends on how tall you are but it reached mine fine and I'm slightly under 6'.
Bikeboy80
Offline
« Reply #87 on: November 04, 2012, 10:37 AM » |
Yea I'm 5'11 so that should work. I just wasn't sure, one of the photos on Festool's website shows sanding of a ceiling with two extensions on. Maybe it's a 9-10' ceiling.
So if I add 3-4 sections that should get me to about 15'.
When using the harness does it effectively lengthen or shorten the usable length over just holding the tool?
tDot
Offline
« Reply #88 on: November 09, 2012, 11:53 AM » |
Yes, it can be used for knocking down popcorn or texture on a ceiling. I would recommend 80 or 100 grit. The Planex has two dust extraction options which are selected with a switch on the head: inside the pad or outside the pad. You will want to select outside the pad for this application. Generally, you will select inside the pad for other applications, like drywall sanding. Using extraction on the outside of the pad is best suited when you're creating larger debris rather than fine dust.
That sure sounds like a job that would be better for Cristal, or atleast a paper that is heavier then Brilliant, as many of those popcorn ceilings have some form of paint on them. Since I also sand painted walls that are to be skim coated. Do you have any idea when the Cristal will come to North America? As I use the Planex for general contracting, not just drywall, I find it very limited without the Cristal paper. (I didn't find out the Cristal was available until after the expiry of the 30 day period, otherwise I would have returned it). I'm actually trying to decide if I should sell the Planex as I find it's use too limiting without a proper supply of paper.
Shane Holland
Online
« Reply #89 on: November 09, 2012, 11:58 AM » |
I've heard of no plans to introduce Cristal in NA. You do have the option of Saphir in 24 and 36 grits if you need something extremely aggressive. Cristal would only add 40 and 60 grits between what the current Brilliant and Saphir offerings provide.
« Last Edit: November 09, 2012, 12:10 PM by Shane Holland »
