Pages: [1]   Go Down
  Print
Author Topic: MFT Perforated Top  (Read 652 times)
Waka
Offline Offline
« on: February 29, 2012, 02:34 AM »
Having a lot of machinery in my workshop I unfortunately don't have the space for the MFT/3. The majority of my work (being a hobbyist) is done in the workshop, where I have previously utilized a perforated top for the out feed table from my table saw, very useful addition and also acts as a work table, very handy for using festool clamps etc.
My main workbench is a Sjoberg and I've been thinking of covering the top of the bench with a MFT perforated top, has anyone done this in the past?
Waka
Kapex 120, TS55, Domino 500, MFS 400, Centrotec Set, CDD 12 FX, BPS 15.6, BPS 12, Domino Sys, Trion PS 300OG Router OF 1400, EST 150/5, RTS 400 Q-Plus, Parrallel Guides, CT Mini x 2,  LR 32, and lots of  little extras. Slowly building up on "T" Locks.
TomGadwa1
Offline Offline
« Reply #1 on: February 29, 2012, 03:02 AM »
If you mount the MFT style top to your workbench bear in mind that access from the bottom of the MFT top is needed to allow using the versatility of the quick clamps and the screw type clamps. This allows clamping of the rails and low profile clamping of workpieces onto the top. If you can achieve this then you will have full benefit of the MFT tops design.
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Waka
Offline Offline
« Reply #2 on: February 29, 2012, 04:42 AM »
I won't have access to enable the use of screw or quick clamps but I'll be able to use my MFT SP clamps, these happen to be my first go to clamps anyway. If the other types are needed I can move the work piece to the perforated out feed table.
Waka
Pages: [1]   Go Up
  Print
Jump to:
