Author Topic: Crosscut on MFT/3  (Read 2782 times)
Offline Weens1
Crosscut on MFT/3
« on: February 28, 2013, 02:47 PM »
Thinking of buying an MFT/3 before a new cabinet project. But looking at it's repeatable crosscut capacity, it looks like it's only 27 inches. I have read that you can turn the fence 90 degrees and increase this. Is this true? Anyone done this and had good results? This seems like a shortcoming in the MFT when used with a saw that is so helpful for sheet goods. I appreciate any input, especially from people who have done this
Offline Sean Ackerman
  • Festool Dealer
  • Festool Dealer near NYC - 10,000 sq feet!
    • Festoolproducts.com
Re: Crosscut on MFT/3
« Reply #1 on: February 28, 2013, 02:57 PM »
You can certainly orient the fence 90 degrees for longer cuts.  You can also connect multiple tables and use any combination of rails to get as long of a cut as possible.
Offline erock
« Reply #2 on: February 28, 2013, 04:05 PM »
I never tried moving the fence and rail on the MFT/3.
Seems like a lot of time.  I can easily cross cut 609mm wide piece of ply.  Which is plenty for the depth of a base cabinet.
I use the MFT/3  and Parallel guides  for anything wider then 609mm all the time.  I find that both work wonders for
cutting sheets of plywood.
Yes you can put the rail on either side of the MFT/3.  But it may be old after a while if you're switching the rail around alot.
A couple options would be to buy 2  MFT/3's.   Or get a MFT/3 and P-guides.
To me the MFT table is more then just a table for cutting.  It can be used in so many different applications then just cross
cuts.  If you where to add it to your Festool line of goodies, I'm sure you wouldn't be disappointed.
Hope this helps.
Eric
Offline Weens1
« Reply #3 on: February 28, 2013, 08:44 PM »
Eric,
Thanks for the reply. Just to clarify, I wasn't worried about the length of the crosscut, but how much board could be on the table from left to right. I want to make repeated cuts so that the cabinet height is around 32-36 inches. If I could just slide the lard down after each cut, it would make for quick work.
As usual, I appreciate the advice on the forum, thanks
Offline stahlee
« Reply #4 on: February 28, 2013, 10:08 PM »
Quaz Dogs and Quaz Rail Dogs could make this very quick.
Offline jobsworth
  • Burger Babe Says: I Even Buy Green Bananas
« Reply #5 on: February 28, 2013, 11:49 PM »
The MFT is the center of the festool system IMO.
It brings it all together.
highly recommend one or two or even three (yea Im thinking of a third)
Loving the Calif sun....
