Pages: [1]   Go Down
  Print
Author Topic: Cutting T track with the Kapex  (Read 2204 times)
wood pulp
Offline Offline
Each another's audience...
« on: April 05, 2012, 08:51 AM »
I have some Incra T track and am thinking of using my Kapex to cut it into smaller pieces. Is this advisable using the standard blade?  Is this the best route or is there a better way?
ccmviking
Offline Offline
WWW
« Reply #1 on: April 05, 2012, 09:10 AM »
    IF you are going to cut a hundred pieces I'd buy the Festool Non-Ferrous blade, which is nice to have around of other stuff too.  If you'e just cutting a few, set the speed on 2-3 and go ahead and cut them.
Chris...
wood pulp
Offline Offline
« Reply #2 on: April 05, 2012, 11:29 AM »
Thanks for that.  I only have, maybe 10 cuts total.  I would hate to mess up this blade though!
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #3 on: April 05, 2012, 12:02 PM »
Well, there is a chance you could even with just a few cuts.  I'd use a hacksaw.
Corwin
Offline Offline
« Reply #4 on: April 05, 2012, 12:37 PM »
...  I'd use a hacksaw.
Not if you wanted a nice clean cut.    Cool
Shirt Size:  L
sancho57
Online Online
« Reply #5 on: April 05, 2012, 06:06 PM »
I have a old delta 10" miter saw that I used before my Kapex. When I got my Kapex I went to Blowes and bought a 10" metal grinding / cutting wheel. It works great. Ive used it for cutting pieces for  rack type closet organizers and cutting the clothes hanging  pole for a oak organizer I just completed.
I guess after all this I ust want to say if ya happen to have a old miter saw its a less expensive avenue with good results.
Shhhhhh Dont tell the wife butttttt I bought another…….
Alan m
Online Online
« Reply #6 on: April 05, 2012, 06:11 PM »
if you have a kapex im guessing you gave a router (good opertunity) . id cut the track with a hack saw (or jig saw ect)  and use a jig to skim the ends with a router bit . ruining a router bit will be a lot cheaper than a new blade for the kapex
now
wish list
johnnyinnb
Offline Offline
« Reply #7 on: April 05, 2012, 06:26 PM »
I suggest you support the t track with a piece of wood behind it, the opening in the fence is a little wide and the t track may vibrate causing problems
Johnny
He`s a block off the old chip
andvari
Offline Offline
« Reply #8 on: April 05, 2012, 07:13 PM »
I think you could also clean up the cut with some silicon carbide sandpaper.
Jerome
Offline Offline
WWW
« Reply #9 on: April 05, 2012, 08:35 PM »
As the track is aluminum, which is soft, and you are only making a few cuts there is no need to get a different blade. The only thing you need to do is to fix the pieces down to the saw on both sides of the cut for the best results. If you can't do that because the off cut is too short, then cut a slot in some longer scrap, put the T track into that and clamp that to the saw.
You don't need to fasten the T track to the scrap as you have clamped both ends and the short off cut won't go flying.
Jerome
TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, Trend T11, Makita LS1212, Original Mini CV06 Cyclone.
Wish list WoodRat, Workshop supplies drum sander
http://www.flickr.com/photos/nui-jerome/
TomGadwa1
Offline Offline
« Reply #10 on: April 05, 2012, 08:44 PM »
If you have a Trion or some type of Jigsaw use that with a metal cutting blade for efficient results. Then clean up the cut with some sandpaper or if a metal file is available dress the sharp edge left from the cut with that. Make certain the track is clamped to a support so the action from the jigsaw does not cause a safety issue. The idea stated above about putting the track into a channel in some scrap wood would safely hold the track as the cut is being made.
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Laminator
Offline Offline
« Reply #11 on: April 06, 2012, 07:31 AM »
Cut with a slow steady feed rate and you should be fine.  I have cut many different aluminum objects through the years and have never damaged a blade so far....
wood pulp
Offline Offline
« Reply #12 on: April 06, 2012, 10:28 AM »
Well...it has been done!  The general consensus was that it would be fine.  With quality of cut and precision to be the most important factors I used the Kapex...deep breath of courage though!  It was fine, besides the blade needs to go in for sharpening anyway.  Thanks for the replies.
Brice Burrell
Online Online
WWW
« Reply #13 on: April 06, 2012, 12:34 PM »
That was my biggest fear, dulling the blade.  Since it needed sharpening anyway, no harm done.  For anyone else contemplating using ATB blade to cut aluminum just be aware that it won't cut wood like it used to, until you get it sharpened....
curt boyer
Offline Offline
« Reply #14 on: April 06, 2012, 05:32 PM »
Small 4-1/2" grinder and a thin cut off wheel is the way to go. We use this set up for storm door installs, closet rods , any time we need to cut aluminum or steel. Plus you can easily remove burrs and round over sharp edges. I'm with Brice, save the Kapex for wood.
Curt
Pages: [1]   Go Up
  Print
Jump to:
