Pages: [1]   Go Down
  Print
Author Topic: CXS plus which T drill?  (Read 1243 times)
wood pulp
Offline Offline
Each another's audience...
« on: March 21, 2012, 07:40 PM »
I am buying a CXS kit tomorrow. It seems as if the CXS has become the most used drill for most cabinetry and woodworking projects. I hear a lot say it complements a T15 very well, what about a T12? I have a large basement remodel coming up and am contemplating picking up a T12 with it (last years at a reduced price), or should I hold off and get a T15 (new features, new price)?  I had a T15 some time ago but sold it cause I used my c12 for everything. Well, the batteries died and I sold the body on the C12.  So, will the T12 handle a basement makeover (while I can also save some $) with the CXS or should I get the T 15?  Is the 15 that much more powerful than the 12?
« Last Edit: March 21, 2012, 07:44 PM by wood pulp » Logged
GhostFist
Offline Offline
« Reply #1 on: March 21, 2012, 07:51 PM »
What's keeping you from getting a T15?
Ken Nagrod
Restricted
Offline Offline
« Reply #2 on: March 21, 2012, 08:04 PM »
If your choice is between adding either a T12 or T15, my vote is for the T15.  They're both 10.8 volt drills only differences are the amp/hr rating which will be a difference in run time and the T12 will give you around twice as much torque from the T12's bigger motor, but the T15 is even more powerful for a negligible weight gain over the T12.
« Last Edit: March 21, 2012, 10:12 PM by Ken Nagrod » Logged
davee
Offline Offline
« Reply #3 on: March 21, 2012, 08:39 PM »
I have the T15 and the CSX and they work very well together without much overlap.  I find the CSX to be my go to drill for 90% of my work.  The 15 gets used for heavier drilling, etc.  A very nice combo.
builderbob
Online Online
WWW
« Reply #4 on: March 21, 2012, 08:43 PM »
I'm am in complete agreement with Davee with the exception that I have the C15 instead of the T!
Bob
Kapex, TS55, Domino, MFK 700, OF 1400, OF 1010, RAS 115, RTS 400, ETS 150/3, ETS 125, CT 22 (2), C 12 (2), T-15+3, T-12+3, PSB 300 & more MFT's than i can count!
wood pulp
Offline Offline
« Reply #5 on: March 21, 2012, 09:03 PM »
GhostFist - It is purely to save some money.  You can still find the older T12's at a reduced price.  Although, I have held both the 12 and 15 and I think the 12 fits my hand better.  They are actually different bodies and the 12 seems to be a bit slimmer.
Builderbob - It looks as if you may have a T12 in your arsenal, is the 15 that much more powerful in real life scenarios than the 12?
Ken - Thanks for the input, still working on the Gretsch question!
jtwood
Offline Offline
« Reply #6 on: March 21, 2012, 09:24 PM »
I, too, have the T15 and the CSX and use them for building furniture and cabinets.  I find they compliment each other very well.  I use the CSX the most because of the size and weight, but the T15 comes in very handy for heavier uses and when I want to use two drills to drill holes and then drive screws.
Kev
Offline Offline
« Reply #7 on: March 21, 2012, 09:38 PM »
What about the T18? More power and hardly any bigger.
I went down this path ...
+ CXS
+ T18 (2.6Am, no light)
-- T18 (2.6Am, no light) (swapped back)
+ Ti15
+ C15
... was waiting on the latest update to the T18 - 3.0Ah ... but instead it's going to be ...
+ Protool PDC 18-4
... just waiting on fresh stock through my dealer.
My thinking is the CXS gives the 90% covered - you want big grunt available for the other 10% if you need it.
neeleman
Offline Offline
« Reply #8 on: March 22, 2012, 03:54 AM »
Hi Kev,
You know that there is a new PDC 18 coming this spring?
Some changes:
- a light
- a battery load indicator
- 3,0 Ah batteries
- a few cosmetic changes
By the way it's a fantastic machine.
Precisio CS50 EB-Set, Kapex KS120-UG Set, TS55 R EBQ, Carvex PS420 EQ, BS75 E, RAS115.04 E, Rotex RO90 DX, Rotex RO150 FEQ, DTS400 EQ, RS400 EQ, RTS400 EQ, RS300 EQ, Duplex LS130 EQ, Deltex DX93 E, ETS150/5 EQ, Domino DF500 Q, OF1010 EBQ, OF1400 EBQ, OFK500 Q, MFK700 EQ, C12-Li, T15+3, TI15 Impact, T18+3, CTL26 E, CTL22 E SG, CTL Midi, EHL65 E, D27-AS Plug-it, D36 UNI-RS, FS800, FS1400/2, Gecko Dosh, Toolie, CE-SYS-2010, RB-SYS CART, Syslite KAL, LEV1400, Protool PDC 18-4, Protool FLC UNI.
RvB
Online Online
« Reply #9 on: March 22, 2012, 05:14 AM »
@Neeleman,
Is this the only drill in the protool programme that's improved? or did they all get a makeover? my interest goes out to the iwc 18-2
thnx
ALLREADY GOT:Domino XL DF 700 - CS70 precisio - Kapex 120 EB - TS 55 EBQ Saw - EHL 65E - PS 300 EQ - OF 1010 EBQ - OFK 500 R3 - CTL 26 E - CTL Midi - BS 75 e-set - DTS 400 EQ - ROTEX 90 -  FS SYS/2 - FS 1400/2 x2 - FS 800/2 - FS Bag
D 36 HW RS craftsman cleaning kit - D27/D36 portable cleaning kit - RO90 & DTS 400 abrasive sys - Festool & Protool tool-box - carpenter sys - Fein supercut sys - homemade drills&drivers sys - nailguns sys5 -SYS-CART RB-SYS
WORKIN' REALLY HARD FOR: UG-KA-SET - OF 1400 - ETS 125 - ROTEX 125 - Boom Arm - FS/2 3000
Kev
Offline Offline
« Reply #10 on: March 22, 2012, 05:29 AM »
Hi Kev,
Some changes:
- a light
- 3,0 Ah batteries
thanks neeleman,
I am SO GLAD you told me. I would have taken the plunge even though I don't have an immediate need ... Now I'll wait for the new one.
neeleman
Offline Offline
« Reply #11 on: March 22, 2012, 07:43 AM »
@Neeleman,
thnx
Hi RvB,
No the makeover is for all the battery drilling machines.: DRC 12+18-4, PDC 12+18-4 and IWC 18-2.
Why they dumped the 15V I don't know?
builderbob
Online Online
WWW
« Reply #12 on: March 22, 2012, 08:50 AM »
WoodPulp, I do also have the T12 which I use specifically in the shop for predrilling, etc. It's a great drill the size & weight is very comfortable. I purchased the C15 for the light & battery life in the field and put the T12 in the shop. I would certainly recommend the C/T 12 if you're looking for more power than the CXS but not trying to go too heavy in weight.
Bob
wood pulp
Offline Offline
« Reply #13 on: March 22, 2012, 09:40 AM »
Bob
That is what I was looking for, thanks.  Would you trust the T12 to remodel a complete basement, anything from framing to electrical?  I ljust like the size and weight better than the 15 but on the other hand the extra power could never hurt.  After this it will spend its time mostly in the shop.
Pages: [1]   Go Up
  Print
Jump to:
