Author Topic: Do my new Parallel Guides need to be calibrated?  (Read 4455 times)
Offline Patrick Cox
« on: July 09, 2016, 05:15 PM »
I just received my new Festool Parallel Guides and when I just look at the scale of each guide it appears that they may be off to each other.  If you look at how the scale lines up to the back of the guide attachment, they are off by about 1 mm.  See the pictures below.  Does this mean that I need to calibrate the guides and if so, any tips on doing so?
Thanks!
Pat
On this one you can see 193mm..
And on this one you can only see 192mm...
Offline jobsworth
  • Does Anyone Know What Time It Is?
Re: Do my new Parallel Guides need to be calibrated?
« Reply #1 on: July 09, 2016, 05:21 PM »
Yes they do. There are a number of videos on FestoolTv describing the process along with quite a few threads here on how others have found how to do it.
Offline Patrick Cox
« Reply #2 on: July 09, 2016, 06:43 PM »
I found directions and was able to calibrate long and short cuts.  Now to test to make sure!  :)  Thanks.
Online Peter Halle
  • Another Avatar Coming Soon
« Reply #3 on: July 09, 2016, 07:08 PM »
Calibration is a process so don't be shocked or mad or kick yourself if it isn't absolutely correct on the first try.
Offline truck90278
« Reply #4 on: July 10, 2016, 01:17 PM »
yes they do.  simply goggle Festool parallel guide calibration. it is fairly quick and simple
CT22, CT26, Midi, TS55, MFT3 x 2, Domino 500, DTS 400, RO 125, RO 90, ETS 125, OF1010, CXS, Boom arm, Trion, parallel guides, LR32 system, shop cleaning set, T-18 +3, Kapex
Offline Patrick Cox
« Reply #5 on: July 11, 2016, 05:53 AM »
Well, you were correct.  I am having challenges here.  And I guess I should start with - "what is considered parallel?"  So when I calibrated my short guides, after three attempts the best I could get is a roughly 0.2mm difference.  100.1mm on one end and 99.9mm on the other, as measured with calipers.  So is this parallel enough?  I assumed so but after my long calibration I am not sure.
Now when calibrating the long side, my final measurement is not so straight forward because my calipers aren't that large.  So I tried to cut 250mm and the two picture below will show you the result from each end.  The way I measured the final cut is with a woodpecker rule with an end stop and an adjustable stop.  So I hooked the end stop over one edge then took the final measurement with the adjustable stop tightened against the other edge.  Then I slid the rule across the length of the board.  The pictures below are of my measuring setup and then of the first and 2nd measurement.  They are close but not exact.
I would prefer to be closer then but would appreciate comments.
Thanks.
"E" is for End of Cut
Offline Holmz
« Reply #6 on: July 11, 2016, 06:26 AM »
I would think 0.5-mm is fine.
You would never see it unless it was up against a straight edge.
Many rails are bend more than what you are quoting.
Offline jobsworth
« Reply #7 on: July 11, 2016, 12:29 PM »
How did you joint the board. For ply I will use my TS to clean up the factory edge (joint). Then use that edge to set my guides on . Rip from there.
If the piece isn't jointed 100% straight the PGs will reject the jointed edge
Offline Patrick Cox
« Reply #8 on: July 11, 2016, 03:43 PM »
I did as you describe.  I checked my stops again in a different way (using the woodpecker ruler and ruler stop against the splinter guard on the rail) and I can see the two guide stops are very slightly off so I am going to try to calibrate that way and see how close I get.
Thanks.
Offline Patrick Cox
« Reply #9 on: July 12, 2016, 06:57 PM »
Well, Hallelujah!  I finally got this figured out.  My issue was that my Woodpecker ruler was really too thick to effectively measure from the stop to the inside edge of the blade while measuring under the guide rail.  So, I bought a new ruler that I actually really like.  It is easy to read and well made.  Below are my final board checks at the Beginning and End of my cut as well as pictures of my new ruler and how I used it to measure each stop.  So, now back to my project!
New ruler...  (I found this on Amazon and it is similar to rulers they have at Woodcraft but the measurements are much easier to read.)
How I set the guide stops...
Beginning of cut and End of cut checks...
Thanks again for everyone's help!
Online Peter Halle
« Reply #10 on: July 12, 2016, 07:11 PM »
Glad you got it worked out!  Now go and enjoy!
Offline Naildrivingman
« Reply #11 on: April 21, 2017, 01:27 AM »
I have a follow up question.  Once calibrated to one rail, should I have to calibrate it to another rail?  I'm guessing that the answer is yes or at the very least I should check.  Thoughts?
Dance with who brung ya...
Offline Bob D.
« Reply #12 on: April 21, 2017, 04:43 AM »
I too have a question. The OP spoke of being off by 0.5 mm then 0.2 mm at each end of the cut but this seems like only half the required information to determine how accurate the cut is. You need to know over what distance or the span between the cuts to have a sense of how inaccurate 0.5 or 0.2 mm is. Big difference between 0.2 mm over 300 mm as to 0.2 mm over 1500 mm. Same goes for a measured difference of 0.0 mm. If those two measurements are taken only 300 mm apart that does not mean you are dead on at 3000 mm.
So my question is what was the span between those measurements?
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #13 on: April 21, 2017, 05:53 AM »
i'm just hanging out to see the answers.
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline DrD
  • I might not be fast BUT I sure am slow
« Reply #14 on: April 21, 2017, 07:41 AM »
I used to fuss over the scales on the Festool Parallel Guides until I watched a You Tube video by Stanton Taylor titled "Adjusting the Festool parallel guide system."  What he shows is: 1) fast, 2) very accurate, 3) very simple.  I check mine every now and again (engineer by education) and have found, once set for a particular rail - the 1st part of his video - it's good to go, for that rail.  Set the measurement you wish on one of the guides, follow his procedure - the 2nd part of his video - you're good to go.
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
Offline Bob D.
« Reply #15 on: April 21, 2017, 08:00 AM »
That's a quick and foolproof method of setting the guides to the same length, thanks.
« Reply #16 on: April 22, 2017, 04:54 AM »
Offline Hugh
« Reply #17 on: April 23, 2017, 11:37 AM »
Wow how did I miss that video, awesome idea.
Offline SS Teach
« Reply #18 on: April 23, 2017, 12:59 PM »
Handy to know, I got mine at Christmas. Just a small learning curve. One of the many reasons to keep reading the FOG.
RTS 400, LS 130, Sandpaper Systainer, Profile Systainer. ETS 125, Sandpaper Systainer, Ro 90, Sandpaper Systainer,  Ro 150, Sandpaper Systainer, OF 1400, TS 55 REQ, CT36, CXS Li 1.5 Set, Centrotec Wood-Drill-Set/8pcs, CT Wings, Surfix Set. Domino 500, Domino Systainer, Parallel Guide
