Pages: [1]   Go Down
  Print
Author Topic: Domino tenon strength.  (Read 1158 times)
rjwz28
Offline Offline
« on: April 19, 2012, 12:02 AM »
How much strength of the Domino tenon joint is from the rounded over sides? The reason I ask is that I want to make custom wider tenons and want to know if I need to make the rounded sides exactly the same radius as the stock ones or it doesn't make difference as the holding power is from the glued opposite wide surface areas of the tenon?
thanks,
Rob
jacko9
Online Online
« Reply #1 on: April 19, 2012, 12:32 AM »
Rob,
I square up the Domino Mortises and leave the tenon with cut shoulders.  I find it easier to do a little chisel work than router table or sanding.
Jack
PaulMarcel
Online Online
WWW
« Reply #2 on: April 19, 2012, 02:32 AM »
The Domino radiused edges seem grooved by compression (instead of by cutting); dunk one in water and watch it and the grooves flatten a bit.  But they don't press hard enough on the sides to give you the good glue joint (unless you use a gap filling glue).  I think the biggest reason to either radius the sides to match the mortise or square the  mortise to match the tenon like Jack does is so the tenon itself doesn't have to rely on glue to not move.  If you put a square-sided tenon in a radiused Domino mortise, you could wiggle it side to side.  Doing that relies on the glue to do all the work.
Shirt size: L Cool
Twitter: @HalfInchShy
barnowl
Offline Offline
« Reply #3 on: April 19, 2012, 09:19 AM »
thanks,
Rob
IMHO, I don't think that the sides add much strength. The lion's share is from the top, and bottom.
I base that on the fact that the Domino has wider settings (position 2 and 3) for the cutter.
And it is recommended to cut only the first Domino at the regular width, for alignment, and all the others at a wider width, for ease of assembly.
I don't think Festool would have designed it that way if the integrity of the joint would be compromised by very much.
best wishes,
Steve
TS-55, assorted rails, Domino, Kapex, OF1400, ETS 125 EQ, RO 125 FEQ, RO 90, PSB 300 EQ, CT-22, CT-26, MFT-3
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #4 on: April 19, 2012, 10:33 AM »
Another thing to consider is that once you get past a couple of inches in width, the wood movement will be significant enough that "exactly matching the tenon to the mortice" becomes meaningless.  I round over shop made tenons, but I'm not trying for a perfect fit.
fritter63
Offline Offline
« Reply #5 on: April 19, 2012, 12:46 PM »
In a traditional M&T joint, all of the strength comes from the glue surfaces on the cheeks and the mechanical joint of the shoulders ,and none is expected from the short (don't have a name for it) part of the tenon. And if you think about this makes sense, as that would be an end grain joint anyway which has ZERO strength in a glue joint.
When I used to do M&T the hard way, I'd rout my mortises with rounded ends, then chamfer the tenons so they'd go in and miss the curves, but never glued them.
However, given the tight fit of the domino's on the narrow setting, I'm sure there is some *mechanical* strength added.
jacko9
Online Online
« Reply #6 on: April 19, 2012, 03:56 PM »
All good answers however, you might want to consider what loads the joint will encounter.  If your making a apron to table leg joint for a large table you want to make sure that you design for racking stresses that the shoulders of the tenon help support the glue joint over many cycles of loading.  The best m&t joint has shoulders and is wedged top and bottom to offer full mechanical strength.  There are many studies to support joint strength both in new joints with an applied load and long term cyclic loading.  But, if your only making a light load joint don't worry about it the glue face joint will suffice.
Pages: [1]   Go Up
  Print
Jump to:
