Author Topic: Domino XL Connectors - problems fitting  (Read 1404 times)
Offline Hojo133
« on: August 10, 2018, 07:15 AM »
I tried searching for a similar topic but came up empty....looking for some help with the Domino XL connectors for joining side rails to post for a bed. The problem I'm having is the fit of the connectors into the mortises. I bought the Festool 203420 Domino XL Corner Joint Connector Set, 32-Pack. Reading through the instructions it indicates that on a standard corner setup all the mortise are bored with the narrow setting...
Problem 1: I cannot make the horizontal pieces (neither the anchor connector into which the post/bolt threads nor the bolt with the plastic cover attached) fit into the narrow mortise. If cut on the wide setting, I can make the anchor fit with a significant amount of pounding which leaves the wood marred... but I still can't get the bolt with the plastic cover to slide into the rail mortise so that the bolt can engage the transverse connector and be pulled tight.
Problem 2: The transverse mortise is too narrow for the transverse anchor such that again if I want it to fit I have to drill the original mortise at 40mm as indicated and then a second mortise with the fence set at 38mm and even then I have to pound the connector in hard enough that it caused the top of the horizontal mortise in the rail to collapse.
In the videos I've watched, the horizontal connectors require some tapping in but not the force I was using. The transverse anchors appear to be started with finger pressure only and then tapped home. Did I just get a set of connectors that were are out of spec (odd that all of them seem to be this same way) or have other experienced the same thing? Am I just missing something obvious?
Thanks!
Offline Peter Halle
Re: Domino XL Connectors - problems fitting
« Reply #1 on: August 10, 2018, 07:33 AM »
Sorry to read about your situation.  I admit that I don’t have experience with your particular situation.  My first thought after reading numerous Domino fit issue posts would be to check your cutter - especially if it isn’t new.
Offline James Biddle
« Reply #2 on: August 10, 2018, 08:45 AM »
Make sure you're using the right bit.  I just finished a bed using these connectors and everything went together perfectly without having to force anything.
Offline Doug S
« Reply #3 on: August 10, 2018, 09:10 AM »
Think the Domino XL is supplied with 12mm bit as standard but you need 14mm for the connectors?
Offline Gregor
« Reply #4 on: August 10, 2018, 09:37 AM »
As you said the wide setting works (somewhat better) than the narrow one:
In case you use the 14mm cutter: I would guess that it is (literally) broken, it to be shorter = less amplitude at the tip = the mortice not being as wide as it should be.
In case you don't use the 14mm cutter: the mortices made with smaller cutters are less wide, putting the Domino on wide might alleviate this for the long dimension - but you'll still have problems with the smaller (not 14mm sized) dimension of the mortices (as these are not modified by the width setting).
TL;DR: Use a 14mm bit, not doing so is very likely your problem.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #5 on: August 10, 2018, 10:19 AM »
It really does sound as though a 12 mm cutter is being used instead of the 14 mm one. If it helps, here are a pair of videos about the system:
Part 1:
Part 2:
EDIT:
Of course the DF700 comes with a 12 mm cutter only and this system requires the 14 mm cutter.
« Last Edit: August 10, 2018, 12:56 PM by Peter Parfitt »
Offline Birdhunter
« Reply #6 on: August 10, 2018, 02:52 PM »
I built a bed using the XL connectors. The fit required light tapping only.
I suggest trying a 14mm Domino tenon in a test mortise using the narrow setting. That should tell you if your cutter is ok.
Birdhunter
Offline Green Mojo
« Reply #7 on: August 10, 2018, 06:25 PM »
I recently built a large table using the XL connectors to attach the aprons to the legs and had no issues with the fit. Just followed the instructions and all went well. I really like the XL connectors.
Offline Svar
« Reply #8 on: August 10, 2018, 06:41 PM »
The transverse mortise is too narrow for the transverse anchor such that again if I want it to fit I have to drill the original mortise at 40mm as indicated and then a second mortise with the fence set at 38mm ...
@Hojo133 This means that your mortise is 2 mm too narrow. You attempt to do a second cut 2 mm closer to bring the mortise width to 14mm. As others have indicated you are probably using 12 mm cutter instead of 14 mm cutter.
« Last Edit: August 10, 2018, 07:00 PM by Svar »
Offline Hojo133
« Reply #9 on: August 10, 2018, 07:45 PM »
 [embarassed] Well you all have correctly identified the issue... Somewhere in my head I got the idea that the Domino XL ships with the 14mm bit, but no it ships with the 12mm... soooo that would explain the mortise being approx 2mm too narrow.
I do appreciate that everyone politely pointed me in the correct direction without stating the obvious which is that I am a moron...I shall go back to lurking here and learning what I can from people who obviously are more intelligent. I have however confirmed another example of "anything can fit into anywhere if you push hard enough"
Thanks all
Offline Birdhunter
« Reply #10 on: August 10, 2018, 07:49 PM »
We all venture boldly into dumb land. That’s what makes us human. Please post pictures of the finished project.
Birdhunter
Offline Peter Halle
« Reply #11 on: August 10, 2018, 09:04 PM »
Thanks all
I really hope that you will NOT just go back to lurking.  We are far from perfect here, but this community was started to help those who had questions about how to use their tools.  It’s existence and growth over the years is all due to the contributors who may have walked down the path and learned something in their experience: something that they want to share so that others can walk more directly.
Peter Halle
« Reply #12 on: August 11, 2018, 12:05 AM »
Thanks all
As Peter said, do not go back down in the weeds - keep with it and asking questions.
The beauty of making videos is that you can edit out most of the dumb bits - that's why it takes me so long !
Cheers.
Offline Birdhunter
« Reply #13 on: August 11, 2018, 05:38 AM »
A really dumb (intellectually challenged) person would have simply bought a bigger hammer.
Birdhunter
« Reply #14 on: August 11, 2018, 10:27 AM »
Yes, I think I have two bigger hammers !
Isn't wood wonderful - if it does not fit then you can use a hammer, a strong clamp or set light to it and start again.
Offline grobkuschelig
« Reply #15 on: August 11, 2018, 10:33 AM »
Yes, I think I have two bigger hammers!
... use a hammer, a strong clamp or set light to it and start again.
Hi Peter,
Does this mean, there is a Hammer review coming up, followed by a „hot“ project video? [emoji41]
Can’t wait to see that! I think your garden might be large enough for this.
But be careful not to have to start again with the whole house... ;)
Offline Kevin D.
« Reply #16 on: August 13, 2018, 11:14 PM »
Don't feel 'like a moron'.  We all have 'Doh' moments.  Continue your adventures with pride, we've all been there.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
