Author Topic: Dominofix boring  (Read 1973 times)
Offline Moses45
Dominofix boring
« on: May 17, 2018, 03:24 PM »
I am ordering 1400 eq router today. To bore material to make my own MFT top I need a 20mm boring bit, a mandrel and what else? I will be using a DOMINOFIX. I have searched here and elsewhere and cannot find anything that lists needed accessories.
Offline Frank-Jan
Re: Dominofix boring
« Reply #1 on: May 17, 2018, 04:21 PM »
The centering mandrel is needed to use a copyring on the OF 1010, on the OF 1400 it is not needed.
So you'll only need the 30 mm copyring for the OF1400.
Offline Moses45
« Reply #2 on: May 17, 2018, 08:08 PM »
Thanks Frank.
Offline Dominofix
    • Dominofix
« Reply #3 on: May 23, 2018, 07:38 AM »
Thanks Frank.
Hi Moses! Exactly what frank says! On the 1400 it has a self centering mechanism. You only need the 30mm copy ring for the 1400 then. If you have any questions, just give a shout!
Offline Moses45
Re: Dominofix availability
« Reply #4 on: May 25, 2018, 06:11 PM »
Does anyone, anywhere have the Dominofix in stock? I am batting .000 so far.
