Author Topic: Dust extraction  (Read 1449 times)
Offline Beertje
Dust extraction
« on: October 17, 2018, 06:16 AM »
Using a TS55 coupled with a C26 extractor i am experiencing quite a lot of dust from the front end as i do cross cuts, obviously i dont expect 100% suction but how much escaped dust should i expect?
Offline aloysius
Re: Dust extraction
« Reply #1 on: October 17, 2018, 06:17 AM »
A little less with a bigger (35mm) hose & some gaffer tape over the arbor nut peep-hole.
FOG-wit since '95:  Some say since birth...
Offline Beertje
Re: Dust extraction
« Reply #2 on: October 17, 2018, 07:01 AM »
Thanks for the advice. I as cross-cutting 45mm thick Pine when i noticed, just done a batch of 25mm and the dust was barely noticeable, so i guess the first lot was approaching the max for the 27mm hose.
Re: Dust extraction
« Reply #3 on: October 17, 2018, 08:22 AM »
Dust from the front end? Do you mean the beginning of the cut or the end of the cut?
There is always dust blow out at the end of the cut as the blade emerges from the wood. If your are doing a lot of cross cuts there will be a lot of dust behind the bench/table. If that’s a problem just add a stop block where the exit kerf will be. That will stop the dust exiting the first cut but be much less effective on subsequent cuts. Just move the stop block over a little for each cut.
Offline Corwin
Re: Dust extraction
« Reply #4 on: October 17, 2018, 01:27 PM »
A piece of masking tape will also work to cover an existing kerf in your cutting table where dust escapes.
Offline Bert Vanderveen
Re: Dust extraction
« Reply #5 on: October 18, 2018, 07:14 AM »
If you are doing cleaning up cuts on eg plywood, you should stay away 5 mm from the edge. Less distance causes a lot of sawdust being projected from the front.
« Last Edit: November 09, 2018, 12:33 PM by Bert Vanderveen »
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400
Re: Dust extraction
« Reply #6 on: October 18, 2018, 07:45 AM »
For edge trimming cuts (I think Bert meant cleaning cuts) I tape a strip,of thin cardboard (cereal box) to the side of the saw so that it just touches the sacrificial surface and also wraps around the front of the saw. That forward end of the cardboard needs to be trimmed/stepped to fit around the saw base and it will require more tape to seal than you might expect but then it allow trimming when half the blade is off the wood with throwing chips all over the place.
Offline rst
Re: Dust extraction
« Reply #7 on: October 18, 2018, 09:05 AM »
I've attached a 1" National Guard Products weatherstrip to my 55 and 75.  Works great for eliminating side thrown chips, also have closed the rectangular opening with a piece of thin ABS.  My next modification will be to get a NGP 6611A style strip and make slots for attaching attaching so I can move the brush down further for edge cuts.
Offline Dick Mahany
Re: Dust extraction
« Reply #8 on: October 18, 2018, 09:10 AM »
Nice idea, thanks for sharing!  My most unfavorite cut is the clean up cut on factory sheet good edges.  This looks like an excellent solution.
« Last Edit: October 18, 2018, 09:13 AM by Dick Mahany »
Offline Mario Turcot
Re: Dust extraction
« Reply #9 on: October 18, 2018, 10:11 AM »
Do you have a splinterguard and is it against the board and is it supported?
Splinterguard
If you make a cut on the very edge of a board, expect more dust since it can easily escape the extractor suction.
Mario
Offline GoingMyWay
Re: Dust extraction
« Reply #10 on: October 18, 2018, 10:54 AM »
@Kriss has a video on how to make an attachment to improve edge cut dust collection: .
Inquiring Minds Want to Know
Offline Beertje
Re: Dust extraction
« Reply #11 on: November 09, 2018, 12:31 PM »
Thanks for all the advice. As a novice it's great to pick your brains, as Hannibal Lecter said/or should have said [tongue]
Offline Peter_C
Re: Dust extraction
« Reply #12 on: November 09, 2018, 03:07 PM »
There also is FESTOOL Cover Plate 491750 which drops lower on the edge and covers the arbor hole. Unfortunately the front needs to be cut out to clear the bolt for the forward tear out green piece if that makes sense. It also can not be used when cutting on an angle.
If cutting on an MFT table you can also set up a stop "fence" at the end of the guide rail, attached to the table, to block any debris from flying further forward.
Re: Dust extraction
« Reply #13 on: November 09, 2018, 04:32 PM »
Any tips to improve dust collection on the HK saws?
Offline Svar
Re: Dust extraction
« Reply #14 on: November 09, 2018, 04:57 PM »
The video is for HK85, but same can be done with 55. Also, you could add a cover to the pendulum part. It will be essentially the same as the cover utilized on VN-HK85 grooving unit, but flat.
« Last Edit: November 09, 2018, 05:03 PM by Svar »
Offline rst
Re: Dust extraction
« Reply #15 on: November 10, 2018, 10:02 AM »
Looks like a great candidate for ABS use.  I used .060 ABS to plug the rectangular holes in my TSs.  I used two layers, one a friction fit in the hole and another glued on top to overlap, preventing accidental dropping into the blade cavity.  They've been in all three saws for a couple years without falling out.  I would not use tee nuts however.  The brush that I use to trap sideways chips is attached with small screws tapped into the blade cover.  I used self tapping 12-24 (steel door hinge screws) and then ground off the ends that protruded into the blade cavity rather than buying undersize taps to ensure that the screws fit tightly.
