Author Topic: Dust extraction for cordless drills  (Read 1364 times)
Online Slowlearner
« on: April 11, 2019, 11:43 AM »
Hopefully this is something that can be done. I do a lot of work in finished apts/houses where i have to drill holes to mount anchors, mollys,towel bars,toilet paper holders etc.  Most of it is through plaster and some concrete. It would really put festool ahead if there was a dust extraction connection to drill.  No need for plastic bag and painters tape or vacuum afterwards. The concrete dust is fine and can be a pain to get it all up. Just a thought and would be a buyer of the drill if it was available. Im also available for product testing as well. Lol
Offline Dick Mahany
Re: Dust extraction for cordless drills
« Reply #1 on: April 11, 2019, 11:51 AM »
Both Festool and Bosch make dust extraction connections for drills.  They work well.
Offline GoingMyWay
« Reply #2 on: April 11, 2019, 11:52 AM »
I believe you're looking for the Drill Dust Collection Nozzle: https://www.festoolproducts.com/festool-500483-drill-dust-collection-nozzle.html
Inquiring Minds Want to Know
Online Slowlearner
« Reply #3 on: April 11, 2019, 11:53 AM »
Woww i love this wish list. That happened quick lol i didnt see it under accessories. Great now im a buyer..
Offline elfick
« Reply #4 on: April 11, 2019, 12:23 PM »
Combine it with a bluetooth battery and vac module and you don't even need to manually turn on the vac when you drill.
Offline Alex
« Reply #5 on: April 11, 2019, 12:30 PM »
Forget about the crazy expensive Festool and Bosch solutions, I have this one for under €5 and it's much more user friendly.
Online Slowlearner
« Reply #6 on: April 11, 2019, 02:38 PM »
Where did you get that. In in states ill look for one similiar
Offline DashZero
« Last Edit: April 11, 2019, 03:29 PM by DashZero »
Online demographic
« Reply #8 on: April 11, 2019, 03:37 PM »
DeWalt do a brushless SDS drill that has a small vacuum atachment thats powered off the tool battery.
I have the drill which is great but so far I've not bought the vacuum atachment.
It means you don't have to lug a massive extractor about when you're just drilling a few holes and moving on.
Online six-point socket II
  • aka @the_black_tie_diyer
« Reply #9 on: April 11, 2019, 06:32 PM »
Hi!
Owning and working exentensively with both dust extraction accessories that @Dick Mahany has shown, I can only strongly suggest getting at least the Festool Drilling dust nozzle D 27-BSD 500483 and if you use hole saws in masonry/concrete a lot, also the Bosch.
Both are absolute game changers.
The Festool (which essentially is a Starmix product: "Bohrfixx" https://www.starmix.de/en/bohrfixx ) uses a 2 chamber system, so your drilling dust and debris will never come in contact with the wall/material you put it on. Perfect for use inside otherwise finished/ lived in rooms.
The Bosch is excellent for use with hole saws up to 68 mm, the amount of dust and debris collected it enormous.
Kind regards,
Oliver
Kind regards,
Oliver
Offline Peter_C
« Reply #10 on: April 11, 2019, 07:17 PM »
A fairly expensive option, but one any contractor should consider. The M12 lineup always amazes me.
https://www.milwaukeetool.com/Products/Power-Tools/Dust-Management/Tool-Assisted-Vacuums/2306-20
Offline Alex
« Reply #11 on: April 12, 2019, 02:33 AM »
At my local hardware store in Holland for €4.95
https://www.vacuumspares.com.au/drill-nozzle-attachment-p/drill.htm
https://www.ebay.com/itm/Power-Drill-Dust-Catcher-Hose-Attachment-Nozzle-for-LG-Vacuum-Cleaner-Hoover-/281793425630
I googled "Drill Nozzle Attachment"
I prefer and like my Festool one for $23
Ouch!  [eek]
Nothing like getting rich quick.
Offline threesixright
« Reply #12 on: April 12, 2019, 02:40 AM »
For 17 EUR, I would buy a original festool. Fits also nicely in a systainer (if you have a BHC 18).
Offline Kevin D.
« Reply #13 on: April 12, 2019, 08:31 AM »
Bosch also offers the Speed Clean bits.  Pricey, but the most compact and efficient method.  No need to clean out the bottom of holes either unlike other styles of drill/vac devices.
https://www.boschtools.com/us/en/more/news-and-extras/specials/speed-clean/
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
« Reply #14 on: April 12, 2019, 09:39 AM »
Milwaukee also came out with their version of the vacuum bit for both SDS Plus and SDS Max. Home Depot has them on display and they are spendy. They average around 4x-6x the cost of a standard Milwaukee bit.  But if that's what you need...
https://www.milwaukeetool.com/Products/Accessories/Concrete-Drilling-and-Chiseling/Vacuum-Drill-Bits-and-Dust-Management
Offline Kevin D.
« Reply #15 on: April 12, 2019, 10:36 AM »
(Attachment Link)
(Attachment Link)
They're likely made by Bosch for Milwaukee.  Bosch and Hilti make a lot of the SDS stuff for other brands.
« Reply #16 on: April 12, 2019, 10:54 AM »
My thought exactly as they had Made in Germany stamped on them.
How similar do these look?
Offline Kevin D.
« Reply #17 on: April 12, 2019, 11:08 AM »
(Attachment Link)
(Attachment Link)
Those components may be made by either, but most of the actually Hammer Steel stuff is likely Bosch or Hilti.
I even have an Hitachi adapter and extensions that neither Bosch or Hilti sell as far as I'm aware, and they also look like they are made by Bosch or Hilti.  They have the same markings on the components and are made in Germany.
https://www.amazon.com/Hitachi-725780-Change-Drilling-Adapter/dp/B0014JJLAQ/ref=pd_bxgy_img_2/147-4628163-3206953?_encoding=UTF8&pd_rd_i=B0014JJLAQ&pd_rd_r=8d3d063e-5d34-11e9-801d-fb1ab33d1700&pd_rd_w=gAOlO&pd_rd_wg=hWLnx&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=8334G13TE05NYGDC1A9J&psc=1&refRID=8334G13TE05NYGDC1A9J
https://www.amazon.com/Hitachi-725784-43-Inch-Rotary-Extension/dp/B000M9J40G
A lot of people are not aware that Bosch and Hilti came up with the SDS systems as a joint venture way back in the 70s.
