Author Topic: Essential starters for a Rotex 90?  (Read 3032 times)
Offline sprior
« on: July 12, 2018, 01:35 AM »
I've already got an ETS 125 and the Pro 5 sanders and just ordered the Rotex 90 with the 15% ebay discount code.  My favorite grits with the 125mm sanders are 180, 220, 320, and 400 and I'm wondering what could be considered the essential sandpapers/accessories for the RO90.  The initial usecase I've got in mind for the RO90 is a yearly sanding of a cedar Adirondack chair which the 125mm sanders can't get to all the spots on, but I'm also open to suggestions on the RO90's abilities that I might not appreciate yet.  I've already got Mini and CT26 dust extractors so I'm covered on that end.
« Last Edit: July 12, 2018, 01:50 AM by sprior »
Online Sanderxpander
Re: Essential starters for a Rotex 90?
« Reply #1 on: July 12, 2018, 03:59 AM »
It depends wholly on what you want to do but obviously USPs of the Rotex are the delta mode and the rotary mode. So get some delta paper for the grits you need, and if applicable get some low grit paper to strip paint/finish using the rotary mode. And I think it doesn't come with a hard (blue) 90mm pad, that's useful to have.
Offline ear3
« Reply #2 on: July 12, 2018, 06:52 AM »
Extra delta pads!
Especially if you do a lot of corner/joint sanding, it's really easy to burn through the velcro on those pads around the corners, and quickly make it unusable for that application.  Propoer sanding technique can extend the life of the pad (like not digging into corners/edges), but sometimes it's unavoidable when you are working in a really tight spot.
I would definitely get a few interface pads as well, as the R90 is a fantastic contour sander/shaper.
Offline RJNeal
« Reply #3 on: July 12, 2018, 07:00 AM »
Enjoy the 90, it’s one of my favorites.
You might want to also pick up the extended reach delta attachment, you fine on the standard one that comes with the 90 won’t reach far enough.
Rick.
Offline Mario Turcot
« Reply #4 on: July 12, 2018, 08:01 AM »
Since your ETS 125 covers most regular shapes, I suggest you get the random mode 40-60-80 grit and the same grit you use on the ETS 125 for delta mode.
Like ear3 said get some extra pads and interfaces.
Rotary Mode Tip: to get used of the small foot print, I hold the sander one hand basically where the plug it-cord and hose adapter are.
« Last Edit: July 12, 2018, 11:00 AM by Mario Turcot »
Mario
Offline SRSemenza
« Reply #5 on: July 12, 2018, 10:59 AM »
Extra delta pads, maybe the extended delta pad, hard pad, round interface pads. Lower grits in delta and round.  And some 150 in delta and round.
« Reply #6 on: July 12, 2018, 11:34 AM »
Works really well for removing the haze from and polishing plastic headlight covers.
Offline sprior
« Reply #7 on: July 12, 2018, 11:36 AM »
Thanks all for the info.
I remember a while back some dealer in the US was selling Festool sandpaper assortments, I bought one for the ETS125, can't remember who it was - might be time to order another assortment for both the delta and round heads of the RO90.
Offline GoingMyWay
« Reply #8 on: July 12, 2018, 11:47 AM »
I bought my sandpaper assortment from Festool Nirvana: https://www.festoolnirvana.com/collections/sander-accessories-abrasives-assortments.
Inquiring Minds Want to Know
Offline sprior
« Reply #9 on: July 12, 2018, 11:55 AM »
Offline grobkuschelig
« Reply #10 on: July 12, 2018, 11:56 AM »
... the extended delta pad, hard pad...
Part of what Seth said is most helpful for me.
There are a lot of optional extras.
Interface pad is also helpful, if sanding non flat surfaces.
Pick your poison...
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #11 on: July 12, 2018, 12:56 PM »
You can use the delta mode with the round pad giving you a 3rd option for sanding
Offline ScotF
« Reply #12 on: July 12, 2018, 10:03 PM »
Basically you get every head and pad combination and you will be all set.  ;D
Offline sprior
« Reply #13 on: July 13, 2018, 03:21 PM »
The mention of headlight covers above did remind me that my fiberglass bathtub has a scratch in it.  Does anyone know what you'd use to fill the scratch and how far off the instructions for the headlight covers would the procedure for fiberglass be?  I would assume this would be very similar to fixing a scratch on a boat.
Offline sprior
« Reply #14 on: July 14, 2018, 12:43 PM »
The Rotex 90 got delivered today.  I'm a little surprised that there were only two sample pieces of sandpaper included, 80 grit in two shapes.  Seemed a little stingy to me, with the Pro5 I got an envelope with a sampling of maybe 5 grits.  Good thing I didn't have something I needed to do with it this weekend.
Offline Goz
« Reply #15 on: July 14, 2018, 02:44 PM »
I had to do more extensive patching in a fiberglass tub... Don't ask...  As the last step, I used Evercoat Marine Gel Coat Scratch Repair Kit.  They sell a couple colors (white, buff, and clear) or a large kit with primary colors to mix a custom color.  I bought from Amazon, but I'm sure it's available other places as well.
Make sure the area is super clean. Apply a little at a time, wait for it to dry, then apply more if necessary. Once the scratch is completely filled, you can sand and polish to make the repair virtually invisible.  I think I started with 220 grit and worked my way up.
Offline sprior
« Reply #16 on: July 22, 2018, 12:18 AM »
Just a week after I got my RO90 I decided that since almost everything in my workshop is on wheels I should clear it out and redo the concrete stain floor.  So the RO90 got called into duty with 40 grit paper to sand down any rough spots in the concrete or places where I had drips of stuff like polyurethane.  That thing's a beast.
The before picture:
282434-0
An hour later cleaning almost everything out all by myself:
282436-1
My new weapon:
282438-2
Offline SRSemenza
« Reply #17 on: July 22, 2018, 01:55 AM »
Nice. So you like the RO90?  [big grin]
Offline sprior
« Reply #18 on: July 22, 2018, 02:08 AM »
It was good on concrete.  When I was goofing around sanding a rough board with the 80 grit paper it came with I felt like I was in a rodeo.  I guess it takes some practice.
« Reply #19 on: July 22, 2018, 09:49 AM »
Which paper works on concrete?
Offline sprior
« Reply #20 on: July 22, 2018, 10:07 AM »
I was just using the Granat 40 grit.  I was doing spot fixes, not stripping the entire floor and it was often more about sanding spots of polyurethane that made little high spots.  But I think in a few places I sanded down some small peaks in the concrete itself.
Offline neilc
« Reply #21 on: July 22, 2018, 10:01 PM »
It is a strong sander.  In rotary mode, I've sometimes wished for a side accessory handle like the RO150.
It's great with the Festool polishing compounds and pads for buffing out tabletops with scratches, countertops and even cars.
An interface pad is also a great choice and foam backed pads up to 4000 grit.
A real workhorse for sure.  One of my most used Festool sanders.
Offline smirak
« Reply #22 on: July 23, 2018, 02:02 PM »
I don't want to hijack a thread, but figured this was better than creating another one with some duplicated information.  My current sander is the Pro5 only.  I like the sander and use it often.  However, I have a large(ish) panel glue up currently (58x15) that I'd like to have something more aggressive for.  That said, as there could be 5000 questions, I'm looking for the best option.  I'm not too overly concerned about the price differences between the 90, 125 and 150.  Also, if you think there is a better sander for me to complement the Pro5, I'm all ears.
Thanks,
Kevin
Offline sprior
« Reply #23 on: July 23, 2018, 02:22 PM »
I think it says a lot that when I bought the RO90 I thought the first project it'd be used for is detail sanding a cedar Adirondack chair, and the first project I'm actually using it for is sanding epoxy patch flush on a concrete floor - and yes it can do either of those jobs depending on the mode you use.
The 90mm head might be a bit small for a large panel so maybe get one of the bigger ones, but the Rotex seems like a great compliment for the Pro5.
« Reply #24 on: July 23, 2018, 02:29 PM »
I wouldn't recommend the RO90 for anything "large-ish" unless it's one-time and you intend it for other uses. The pad size is too small to make it quick and in Rotex mode it's also too aggressive to make a larger surface flat.
Offline nvalinski
« Reply #25 on: July 23, 2018, 03:17 PM »
Thanks,
Kevin
For "large(ish)" work, get the 150 unless you want to keep the same sandpaper size as your current Pro5. The 150 is an absolute beast for stripping large surfaces. I can't imagine the 90 would stay as level as you'd like and not dig in, though I don't own one myself to know how bad it would be.
Offline smirak
« Reply #26 on: July 23, 2018, 04:11 PM »
Thanks,
Kevin
Thanks for the reply @nvalinski...I'm sure this has been hashed out ad naseum, but what benefit would I get for the 125 vs the 150 and vise versa?  Assume the 90 is out of the question.  I'm certainly happy spending the additional $100 for the 150 if it gets me "better".
Kevin
Offline nvalinski
« Reply #27 on: July 23, 2018, 04:26 PM »
@smirak, the 150 gets you an additional 40% more surface area on the pad, which presumably means you'll be able to work 40% quicker. The increased area also makes it slightly easier to keep it flat over a 125. I don't think there are any major weight reductions going with the 125, so it really is entirely up to if you want to introduce another sandpaper size into your lineup. Personally, I ended up using both 5" and 6" when I had a Bosch 5" and then acquired an RO 150. The Rotex convinced me to switch entirely over to 6" when my Bosch died, but it's not much more than an upfront expense to obtain more sandpaper of a different size.
Offline guitarchitect
« Reply #28 on: July 27, 2018, 05:02 PM »
The before picture:
(Attachment Link)
(Attachment Link)
My new weapon:
(Attachment Link)
this makes me curious, is there any danger to doing general shop cleanup without the AS hose? I'm assuming what shows in the Empty picture is the non-as hose? I'd like to make a systainer-based thien separator for my CT26 so that i can use the CT as a general shop vac, but was worried about not having a full Antistatic chain through the whole thing. (and no, i won't be purchasing the new cyclone separator... it's not a true cyclone and costs 480CAD!)
also, a side question, whats the footprint of your grinder stand? I'm about to embark on the same build!
« Last Edit: July 27, 2018, 05:05 PM by guitarchitect »
Offline sprior
« Reply #29 on: July 27, 2018, 05:26 PM »
The hose you see in the picture is from the Festool Universal Cleaning Set and is non-antistatic.  Besides being lots cheaper than an AS hose it is a lot more flexible, supposedly the new AS hoses are less stiff, but I haven't tried them yet.  I would assume it's safe to use the non-antistatic hose otherwise Festool wouldn't sell it.  I do notice that static cling causes dust to stick to the outside of the plastic hose sections from the set, but I assume that's because they are plastic.
I've standardized on a workshop cabinet size and the grinder cabinets (there are two of them in the picture) are that size.  I make them from one sheet of 3/4" plywood with 1/2" ply for the drawer boxes, 1/4" for the drawer bottoms, and melamine for the top.  The double locking casters I use are 100mm from floor to top of plate.  I use 3/4" ply for the back and fasten everything together with dominos since it has to be structurally sound standalone.  I make the doors and drawer fronts from one piece that I cut from the original piece of 3/4" ply and I make the cuts such that the grain matches through the doors and drawers (yeah, that kinda nuts).  The drawer boxes are 100mm high, the drawer fronts are 130mm high.  I use the LR32 system for the shelf holes and hinges.  I've been lazy for the last few cabinets and cut the pieces for the drawer boxes including the through and stopped dados for the drawer bottoms on the X-Carve CNC.
I can't remember the other dimensions offhand, but if you like I'll post a cutlist (except for the drawer boxes) and CAD drawing sometime tonight/this weekend.
