Author Topic: ETS 125 EQ base plate replacement  (Read 2037 times)
Offline Hank77
« on: January 19, 2017, 11:02 PM »
I chanced into a mostly functional ETS 125 EQ that I was looking to fix up while waiting for my PRO 5 to ship.  The base plate where the pad screws into seems to be stripped.  There is one T15 torx holding the base plate along with the brass counterweight.  I haven't managed to break it loose.
Does anyone know if the screw is reverse threaded?  Also, any recommendations on how to keep the rotor from spinning while trying to loosen the screw?  Thanks!
Offline Chris Wong
  • Festool Dealer
  • I make sculptural furniture.
    • Flair Woodworks
Re: ETS 125 EQ base plate replacement
« Reply #1 on: January 19, 2017, 11:20 PM »
I can tell you that they are not reverse threaded.
Offline Alex
« Reply #2 on: January 20, 2017, 02:16 AM »
They're normally threaded. I had the same thing, screw threads stripped. I just tapped them up to M5 instead of replacing the entire plate.
Offline Hank77
« Reply #3 on: January 20, 2017, 06:05 AM »
Thanks Alex!  I think I'll do the same for mine.  Chris, thanks for the information on the thread direction.  I can't believe how tight the fastener is, considering it's only a T15.  Either that, or I need to hit up the gym more often!
Offline RustE
« Reply #4 on: January 20, 2017, 09:11 AM »
Do you have a soldering iron?  You could try applying heat to the bolts with the tip of the soldering iron.  The idea is to help release any dried Loctite or oil without damage to the mating components.  The bolts should be replaced after doing this process.
Offline Hank77
« Reply #5 on: January 20, 2017, 10:52 AM »
I do have a soldering iron.  I'll go ahead an order a replacement bolt prior to even attempting this, just so I don't conveniently forget to replace it upon reassembly.  Thanks for the tip!
Offline denovo
« Reply #6 on: January 20, 2017, 11:27 AM »
I couldn't get the bolt off holding the sanding pad on my ETS 150.  Using an impact drill with allen key bit quickly solved the problem while hand holding the pad to prevent it from rotating.  The quick impact might be enough to loosen it without much rotation.
