Pages: [1]   Go Down
  Print
Author Topic: Festo 5KE copying device: need info  (Read 1417 times)
burley
Offline Offline
« on: February 14, 2012, 12:25 PM »
I got this old festo 5KE copying device from a friend, but have truly no clue how to set it up for use, or whith which router I should/can use it.
Does anybody know something about it and is he/she able to tell me?
SRSemenza
Global Moderator
Online Online
« Reply #1 on: February 14, 2012, 12:50 PM »
Hi Burley,
Welcome to the FOG!  Smile
Did a google search , not much but it looks like it might go with the Basis system.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
VictorL
Offline Offline
« Reply #2 on: February 14, 2012, 01:31 PM »
Here is very bad scan from Festool's  2001/2002 global catalog.
Basis 5 is pre-CMS module for OF-1010, Basis 6 is module for OF-2000. I think it should work with modern CMS system too.
VictorL
rookie08
Offline Offline
« Reply #3 on: February 14, 2012, 01:35 PM »
With the bearing and the bit cover it looks like an old style part of the Festool router table module.
On this video at about 3:15+ you'll see the craftsman using something similar to route some profiles.
Or it could be part produced by their old commercial kitchen accessory division.....just kidding   Big Grin
Teil 03 "Chaostheorie" - Bau eines Wandschranks
Cheers
James
Rob Lee
Festool Dealer
Offline Offline
WWW
« Reply #4 on: February 14, 2012, 03:03 PM »
Hi Burley -
This looks to be functionally equivalent to a pin router attachment. We also make one - and have instructions posted at the link below which you may find helpful!
Pin Router Arm Instructions
Cheers -
Rob
greg mann
Offline Offline
« Reply #5 on: February 14, 2012, 05:19 PM »
It is indeed from the Basis and allows you to follow a top mounted template. I don't believe it is a seamless fit on the new CMS but it should be adaptable with a little work, probably adaptable to a more 'pedestrian' table as well. I know a fellow that has one and he sang its praises as one of his most useful router table attachments.
Greg Mann
Oakland, Michigan
burley
Offline Offline
« Reply #6 on: February 20, 2012, 11:23 AM »
Thanks for your replies!
I guess it will sit in its box for quite some time then, since I don't see any use for it. Being able to copy most things with a copy-bit or the guide ring.
but again thanks for your replies Smiley
SRSemenza
Global Moderator
Online Online
« Reply #7 on: February 21, 2012, 08:53 PM »
Hi Burley,
It looks like a neat item to have available.
Seth R. Semenza
Pages: [1]   Go Up
  Print
Jump to:
