Matthew Schenker
Offline
« on: August 30, 2007, 08:01 AM » |
« Last Edit: June 10, 2008, 12:06 PM by Matthew Schenker »
Eli
Offline
A Yankee in Kangaroo Court
« Reply #1 on: August 30, 2007, 08:55 AM » |
I'd seen it, but this was timely for a job I'm doing next week. Thanks for posting it, it was a good reference without me having to dig it out from a pile.
Do nothing, stay ahead.
Matthew Schenker
Offline
« Reply #3 on: August 30, 2007, 10:32 AM » |
There's a PDF of the brochure available for download on the festool site. Yes, but getting it into the Gallery, with page descriptions, adds key-word search capabilities for the abrasives. Having more information locatable through key-word searching is one of the grand designs of this forum! Thanks, Matthew
Bob10
OfflineMember Since: May 2008
« Reply #4 on: December 16, 2008, 06:58 PM » |
Not sure people know about this but Industrial Abrassives has started producing discs that are compatible with Festool ROS. The discs aren't listed on the website yet but are priced the same as the 8 hole discs listed. Just thought I would mention it here. I have some ordered and expect to pleased. I have used their 8 hole paper in the past and was pleased with performance and price.
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #5 on: December 26, 2008, 01:50 PM » |
Klingspor offers 125 mm (5 inch) and 150 mm (6 inch) H&L disks with the correct 9-hole patterns for Festool's round disk sanders with grit sizes from 60 to 1500 in packs of 10 and 50 disks. See their website www.woodworkingshop.com. Tel: 1-800-228-0000 They are also a Festool dealer. I would have posted the hyperlinks to these products, but I don't know how to do so. I am not connected in any way to Klingspor except as a long time retail customer. In the past they have also been very helpful to me; they even custom made H&L disks of coarse HD abrasive to fit my old Bosch R) sander for a nominal premium and delvered them within 2 weeks. I do not know if they still offer such service, but if they do, a wide range of additional abrasives materials could become available to owners of Festool sanders. I have been very satisfied with FestoolUSA's abrasive products offerings and have not needed to look elsewhere. Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
MarkF
Offline
Concord, NC
« Reply #6 on: December 26, 2008, 08:07 PM » |
Dave, Some of us are lucky to be in the backyard of Klingspor's US operation in North Carolina and are frequent dumpster divers. They have a bin of roll ends and other reject abrasives in the back of their stores that go for $1 ("F" weight red) or $2 per lb. for the green and gold cloth abrasives. I can cut plenty of sandpaper for that price for my 1/2 sheet and 1/4 sheet sanders. All of their stores have a bin with the Hickory, NC store (~2 miles off I-40) having the best variety and volume. Definitely worth a stop if you're traveling near any of their stores. If you have a drum sander they have 3" rolls cheap also.
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #7 on: January 25, 2009, 05:40 PM » |
Thanks, Mark. I have what is probably more than a lifetime supply of my own of some grits. One of my uncle's worked at a small company that made large abrasive belts sold to the steel mills that used to operate around Pittsburgh. They would scrap any belt that wasn't perfect. Some of the remnants I have kept are ~3ft wide. I tear off strips to whatever lengths and widths I need.
Dave R.
jimbo51
Offline
« Reply #8 on: May 15, 2009, 04:39 PM » |
I looked at the Festool USA website. I looked at Festool Germany site (English version). I searched some of the FOG threads. No luck. There are wide pads and long pads for the LS130 (Duplex). However, I have seen nothing that indicates what size paper is used on them. It also seems that paper that would fit the wide pad would cover the 90 degree pad totally. The 80 x 130 does not cover the entire surface of the 90 degree pad.
Assistance appreciated.
Tom Bellemare
Festool Dealer
Online
« Reply #9 on: May 16, 2009, 03:44 AM » |
I'm not sure what pad you want to cover, but the typical Festool 80 mm x 133 mm paper fits most of the pads for the LS 130. They also, coincidentally, fit the RTS 400, random orbital sander.
jimbo51
Offline
« Reply #10 on: May 16, 2009, 07:25 AM » |
The wide pad for the 130 is 158 x 130. Do you use 2 of the 133 x 80 sheets side by side? The long pad is 80 x 195. Do you use 1.5 sheets end to end?
Alex
Online
« Reply #11 on: May 16, 2009, 08:31 AM » |
Yes. There is no special size paper available for those special pads. And when I check the Dutch Festool side under LS130:Consumables they exclusively list 130x88 size paper.
Brice Burrell
Offline
Remodeling Contractor
« Reply #12 on: May 16, 2009, 09:36 AM » |
Small correction, Tom must of had a slip of the key board, the RTS is an orbital sander, not a random orbit sander.
Tom Bellemare
Festool Dealer
Online
« Reply #13 on: May 16, 2009, 12:13 PM » |
Thanks, Brice! It is an orbital.
Mac
Offline
A Scotsman living abroad
« Reply #14 on: July 23, 2009, 03:20 PM » |
Matt,
Wanted to say a quick thanks for posting this. I found it really useful having just started exploring the mysteries of festool's abrasive selection.
Mac
Debra Crane
Festool Dealer
Offline
« Reply #15 on: November 04, 2009, 03:12 PM » |
Thanks, Matthew, for posting an easily found copy of the Festool abrasives brochure. As I work for at the Woodcraft store near Nashville, TN, I'm often referencing this abandoned document. It was great having it available back-in-the-day as a POS handout and a primer included in every sander systainer. I considered it Festool University's Abrasives 101 text book. Not only does it explain the differences in abrasives, the core of Sanding Science, but it also guides the user through the specific abrasive sequence based on project material. "Polishing solid surface for the first time? See page 3 for an overview." It makes finishing as simple as following a recipe! Faster. Easier. Smarter. Once I realized the brochure was no longer included in sander systainers, I contacted FestoolUSA to replenish my in-store stash. Unfortunately, they were no longer available in print. They said something about reviewing and improving the document. OK, I could appreciate an ongoing commitment to quality, but why not make the current brochure (which I thought was excellent) available on the FestoolUSA website? Perhaps in the FAQ and/or Support knowledgebases. Or even as a supporting document link directly accessible from the product page. Wouldn't that be faster, easier, smarter? In the mean time, I copied one of my own brochures and placed in our store's Festool Bible for in-store reference by employees or customers. Actually, I found out from the FestoolUSA rep that the abrasive brochure IS available on their website ... just hidden away in the underbelly archives, accessible only if you know the specific url: http://www.festoolusa.com/supplyimages/abrasives_brochure.pdfAnd as for their reviewing and improving the document, if they asked, I'd offer FestoolUSA a suggestion in improving the principle guidelines for selecting Festool abrasives: "Reorder the Festool world view by grafting a Darwinian tree to Abasivology." To be specific, I think of the abrasives as being graded from more aggressive to less aggressive, from coarse to fine. I think of them in this particular order: Saphir - for heavy duty for extreme conditions Crystal - for rapid removal Rubin - for bare wood Brilliant2 - for paints and finishes (also for bare wood) Titan2 - for solid surface, plastics, composites (also for paints and finishes) * Vlies - for matte finishes Platin2 - for gloss finishes Felt & lambs wool - for polishing *Vlies is also used for cleaning and scouring and could therefore enter the line-up elsewhere.I know the abrasive line-up is not linear in reality; there are plenty of overlaps and sidesteps. And Vlies is an odd duck that can slip in between several places. But by reducing it to a linear tree which I can use as a guiding principal, I can remember the progression through the grits. It also gives me an order to place the product on store shelves! I'd also suggest that the FestoolUSA folks expand the brochure to include polishing ? which would mean bringing over the Festool polishes, wouldn't it? As a bonafide, Kool-Aid-drinking Festoolian, I want it all, baby! I hope this bit of drabble doesn't confuse anyone ... just inspire one other Festoolian to read the abrasives brochure and rethink his/her approach to finishing.
« Last Edit: November 04, 2009, 03:18 PM by Debra Crane »
Shane Holland
Festool USA Employee FOG Administrator
Offline
« Reply #16 on: November 04, 2009, 03:21 PM » |
OK, I could appreciate an ongoing commitment to quality, but why not make the current brochure (which I thought was excellent) available on the FestoolUSA website? Perhaps in the FAQ and/or Support knowledgebases. Or even as a supporting document link directly accessible from the product page. Wouldn't that be faster, easier, smarter? In the mean time, I copied one of my own brochures and placed in our store's Festool Bible for in-store reference by employees or customers. Actually, I found out from the FestoolUSA rep that the abrasive brochure IS available on their website ... just hidden away in the underbelly archives, accessible only if you know the specific url: http://www.festoolusa.com/supplyimages/abrasives_brochure.pdf Actually, the abrasives brochure is linked from every abrasives and sander product page. It is listed as the "Festool Abrasives Decision Guide". Edit: And, this is the current URL although the old one Debra referenced will work: http://www.festoolusa.com/media/pdf/abrasives_brochure.pdf
« Last Edit: November 04, 2009, 03:28 PM by Shane Holland »
Debra Crane
Festool Dealer
Offline
« Reply #17 on: November 06, 2009, 12:21 PM » |
Thanks, Shane. Glad to know it's there. I'll pass that info on to my customers.
BTW, will some version of the brochure be added back into the sander systainers?
Matthew Schenker
Offline
« Reply #18 on: November 27, 2009, 01:09 PM » |
As I work for at the Woodcraft store near Nashville, TN, I'm often referencing this abandoned document. It was great having it available back-in-the-day as a POS handout and a primer included in every sander systainer. Debra, Thanks for the comments. The reason I scanned and posted the abrasives brochure here was to give everyone a quicker way to access the information. I figured it might be easier to go to this page and show customers the abrasives pages. Glad it helps. Stay in touch, Matthew
imaginarynumber
Offline
« Reply #19 on: December 18, 2009, 04:46 PM » |
Does anyone know why the titan range is largely limited to the rotary range.
When sanding latex mdf primer I often have to resort to using the 150mm disks on, for eg, my dts400, punching dust holes as necessary.
Although the paper eventually clogs it lasts much longer than the corresponding brilliant paper.
Alex
Online
« Reply #20 on: December 18, 2009, 06:51 PM » |
Because Titan is mainly developed for the automotive industry and rotary sanders rule the automotive industry.
ccarrolladams
Online
Location: Hollywood, California USA Member Since: Apr 2010
« Reply #21 on: December 15, 2010, 09:07 PM » |
Although on other forums we have discussed the new Granat abrasives, it was not clear if this product would replace Brilliant 2 and Rubin for sanding wood products prior to application of finishing materials.
Just a few minutes ago I received the current SysNotes as e-mail. Scrolling down the page, passed the glowing discussion of the RO 90 DX, there is a chart showing all the Festool abrasives.
I find what this says about Granat fascinating:
"Granat A premium abrasive composed of hardened Aluminum Oxide and Ceramic Grit for scratch resistant coatings and high VOC coatings."
Nowhere does that chart mention the use of Granat on bare wood.
Could members who have been using Granat provide some more information and experiences?
davee
Offline
« Reply #22 on: February 15, 2011, 12:39 PM » |
At the Advanced Router training in Lebanon last week we were told that Granat was a viable option for bare wood. We were given a couple of sample sheets, and with a sample size of one it was pretty impressive. I used it for quite a while without noticing degradation. In switching to sanding an edge, it caught and tore. The paper backing is definitely not as robust as Rubin. I plan to purchase Granat.
fritter63
Offline
« Reply #23 on: March 12, 2011, 01:05 PM » |
After a successful week of eBaying unused tools, I'm heading down to pick up my RO 90 later today.
From what I gather, the abrasives systainer is only available empty, right? Any word on the package that Shane was trying to put together?
Brice Burrell
Offline
« Reply #24 on: March 12, 2011, 03:33 PM » |
Yes the abrasive Systainer is empty. The package Festool wanted to put together didn't happen as hoped and isn't going to be available in the immediate future.
Timtool
Retailer
Offline
« Reply #25 on: April 10, 2011, 04:17 AM » |
i have the ETS 150/5 that came with an assortment of different sheets, and when i look at the print on the rubin paper from the box i bought, and the print on the rubin paper that came with the sander, they have a different code printed on them. both say festool rubin p120 and then a code; the code is different on both, and the grit surface also looks different. one looks shiney, the other one looks dull. can't remember the codes, but i can look it up if neccesary. anybody know what this means?
Shane Holland
Offline
« Reply #26 on: May 09, 2011, 10:24 AM » |
Just adding a new abrasives poster (PDF) that was designed to simplify the abrasives line. It also includes a brief overview of the various types of pads and their uses. The image is just a preview, download the attached PDF.
« Last Edit: May 11, 2011, 02:17 PM by Shane Holland »
SRSemenza
Global Moderator
Online
« Reply #27 on: May 09, 2011, 10:43 AM » |
I have noticed this also. I don't know what the difference is except for the surface sheen of the abrasive. Seth
Festool Service 800-554-8741
VictorL
Online
« Reply #28 on: May 09, 2011, 11:39 AM » |
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
Does Festool drop Rubin for RAS-115? It's grayed out. Thanks, VictorL
Shane Holland
Offline
« Reply #29 on: May 09, 2011, 11:58 AM » |
Oops, looks like I had a pre-finalized version. That had been corrected. I'll update my poster with the latest version. Thanks for the heads up, Victor.
