Author Topic: Festool and mafell  (Read 58060 times)
Offline PA floor guy
Festool and mafell
« on: March 19, 2013, 07:06 PM »
Reading a different post got me thinking.  What are the biggest difference between festool and mafell.  I know Mafell makes a lot of different tools than festool offers. But on similar tools, which is better and why....
Offline skids
Re: Festool and mafell
« Reply #1 on: March 19, 2013, 07:09 PM »
Price for one. Mafell is hideously expensive.
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it
Offline Davej
« Reply #2 on: March 19, 2013, 07:34 PM »
But then so is festool verses makita , dewalt etc but you still buy festool. Mafell is ' maybe '  the top tier .
I dont mind growing old but i refuse to grow up
Offline skids
« Reply #3 on: March 19, 2013, 07:56 PM »
Anything more $$ than Festool = Law of Diminishing returns.
« Last Edit: March 19, 2013, 08:09 PM by skids »
Offline GhostFist
« Reply #4 on: March 19, 2013, 08:30 PM »
Imo mafell make the best saws on the market lots of power smooth running extremely well built fantastic machines. Festool are great but mafell really has some brilliant engineering.
Offline greg mann
« Reply #5 on: March 19, 2013, 09:14 PM »
A tool that cost twice as much may only be ten percent better (subjective at best) but that ten percent may make all the difference in the world from the standpoint of commercial or artistic success. Case in point? .300 hitter versus a .250 hitter. One more hit in every 20 at bats. Anyone know what a consistent .400 hitter could ask for these days? One hit in ten better than a .300 hitter that just might go into the Hall of Fame himself.
That said, I really would like to see both Mafell and Protool here in the States. Each of us is crazy in his own way, and I am not sure how crazy I am yet.   ;D
Greg Mann
Oakland, Michigan
Offline woodie
« Reply #6 on: March 19, 2013, 09:15 PM »
Cool tools for sure.  They don't seem to have much interest in the US market though, as they only have one distributor. Unfortunately they don't offer a trial period like they have in other markets and availability of accessories can be a bit spotty.
Green - MFT/3, FS 1080/2, FS 1400/2-LR32, FS 1900/2, FS 3000/2, Parallel Guide Set, CT 26E, CT MIDI, OF1400 EQ, LR32 Drilling Set, MFS 400 Set, MFS 700 Set, Domino DF700 Set, Domino DF500Q Set, C12 NiMH Set, T18+3 Set, 2011 Centrotec Set, RO150 FEQ, RTS400 EQ, LS130 EQ, Planex LHS225, and various accessories
Red - KSS80 EC/370, MT55cc, P1cc, F160, F110 and Aerofix Guide Rails.
Offline jonathan-m
« Reply #7 on: March 20, 2013, 04:30 PM »
This is a sensitive topic, so I hope I don't misstep.
Almost a year ago now I've replaced my TS55 & Carvex with the Mafell counterparts.
Festool makes excellent tools. It's is part of a huge conglomerate and has an enormous line-up with tons of accessories for them. Add to that the excellent service and I can completely understand why someone chooses Festool over anything else. I think they offer a complete package that can't be beat by any other manufacturer at this time.
However I also believe that tool for tool Mafell is better engineered. They pay more attention to details and machining touching surfaces to eliminate any tolerances and play. They also seem to be more robust and resistant to wear and tear in my experience.
« Last Edit: March 20, 2013, 04:54 PM by jonathan-m »
Festool: 2x MFT/3 // OF-1400 // MFS-400 & 700 // RO-90 // SYS-ROLL // VAC-SYS SET SE1 // CT-ASA CT 26/36/SB // KS 120 EB & UG-L & R //  VECTURO OS 400 EQ-Set  // DSG-AG 125 // DSC-AG 125 // DSC-AG 125 FH // HK 85 EB // HK 55 EB
Protool: 2x VCP 260 LE AC // PDP 20-2 // WCP-32
Mafell: MT55cc // P1cc // DD40P // Erika 85 Ec
Offline skids
« Reply #8 on: March 20, 2013, 07:58 PM »
Law of diminishing returns defined.
Offline tdfiver
« Reply #9 on: March 22, 2013, 04:20 AM »
Only mafell I own is the KSP40 saw.
This is one brilliant little saw and I would not be without it. The build quality is as good if not better than Festool, it is without a doubt more robust and can take site work no problem.
Only problem is finding blades for it as it takes 120mm, so blades are expensive.
Offline Dan1210
« Reply #10 on: March 22, 2013, 08:23 AM »
generally my new ts55r doesnt feel as robust as my older ts55, i cant quite put my finger on it... time will tell, should have given the maffell plunge saw a raz!
Festooligan since 2006
Offline Bob Gerritsen
« Reply #11 on: March 22, 2013, 10:31 AM »
I think I have to agree with Jonathan, really going in to the details and doing a proper A/B comparison will most likely show Mafell is on average just a little bit better per machine. Maybe that is because there are a smaller company and they don't try to fit as much as possible into the overall system as Festool does.
Ever since I got the Mafell KS300 I fell in love with that machine. It is hard to explain until you've used it but that machine is an A+ in engineering. It is hard to overrate that machine, all those possibilities in one sys 4, that is brilliant engineering.To be honest, I'm expecting I will probably replace my TS55 with it's Mafell counterpart, instead of getting the TS55R from all I've read and my experience with the small KS300.
In the end, if you stick with Festool you won't miss Mafell for a second. Festool's system works most of the time and they simply make excellent tools. I do think though every Festool user will be pleasantly surprised when using a Mafell. Maybe not enough to take the jump as it is not only the machines qualities that play part in deciding, but still.
Btw, I don't know how pricing is in the US but over here Mafell and Festool are sort of in the same price range. At least the plunge saws and routers are, Mafell's jigsaw really is something special so it fits that it is a bit more expensive than Festool's.
I know this is the Festool owners group but still I'm a bit surprised the love for Mafell isn't a bit bigger. For me, between those two brands I can find just about all the woodworking hand tools I need. My ideal line up would probably be 65% Festool and 25% Mafell and the odd 10% for other brands.
Offline Jalvis
« Reply #12 on: March 22, 2013, 11:22 AM »
Bob Gerritsen's response is spot on.  Festool is a great company but Mafell takes there fit and finnish a bit farther.  I agree its hard to explain but you will understand after using a Mafell product......its well thought out and the details are perfect in function, feel, and looks.
In the USA Mafell is not close in price and has one Dealer: www.Timberwolftools.com
For the USA that means dealer support is not near as localized but that doesnt stop me from buying Mafell.  Its like the first time you use a Track Saw or a Miter Saw.....you work differently because the options to solutions change.  This is true with many Mafell products such as the KSS300, Duo-Dowel System, MT55 and the Erika pull-push saw(Festool has a version but only Mafell's is available in the USA).
Personally only one function can be enough to select one tool over the other.  For example the Mafell MT55 has the best blade change function...you simply set the saw down, Press a button, pull a lever, and the entire side swings open while locking the blade.  This was a feature that didnt mean anything to me when I bought the MT55 but after use its one of my favorite characteristics and is enough if a re-purchase ever occurred.  Simple things like the F-style rails have a second slot closer to the cutting edge for narrow stock and the joining rail function being fast and dummy proof.
Its important you dont miss understand where I'm coming from......brand loyalty means nothing to me.  I'm not painting my shop Red or Green!  Its about what tool makes your job easier and faster(time=money).  My tools make me Money and have to Perform.  Price is only one part of the equation and since I have a long career ahead its easier to gain over the long run.
Offline Alan m
« Reply #13 on: March 22, 2013, 11:45 AM »
i really like that side opening feature on the mt55. everytime i have to change the ts55 blade i complain about it not having that feature. if i had to replace my ts55 i would buy the mt55
i like the duo doweler but the domino stilll wins overall.
« Reply #14 on: March 22, 2013, 11:58 AM »
Can you elaborate on this or post a picture showing that feature?
Offline kent B
« Reply #15 on: March 22, 2013, 12:38 PM »
 I looked at both the Festool and Mafell MT-55cc .
 Comparing prices the Mafell with extra rails and shipping is approx $300 more , but the Mafell is a much better made saw.
 If I were a bit younger, and had some sons to pass the saws to , I would sure buy the Mafell.
 The timber framers I know use the Mafell's  , do not know any timber framers using the Festools.
Offline Svar
« Reply #16 on: March 22, 2013, 12:54 PM »
Mafell guide rails are definitely superior as mentioned above. Rail connector is self-aligning (same goes to Bosch and EZ rail) acting on the same principle as Betterley StraightLine Connector. In addition, the rail has two T-slots on the bottom one close to the cutting edge that allows clamping of narrow stock.
Michael, here are some pictures:
http://www.woodworking.de/cgi-bin/holzbearbeitungsmaschinen/webbbs_config.pl/md/read/id/63546
There are lots of contraptions people put together to handle narrow stock with Festool rails, but I’m yet to see an elegant solution to that.
I think this is a weak point of the TS system, which Festool could fix perhaps at the cost of back compatibility. Hey, even EZ rail can clamp narrow stock.
« Last Edit: March 22, 2013, 01:15 PM by Svar »
Offline Jalvis
« Reply #17 on: March 22, 2013, 01:22 PM »
Thanks for posting the photo.  Two clamping slots on the rails is great but my all time favorite is the self housing, fast setting, perfect alignment connector for the rails.  Oh.....and the slot holder for the guide strip is a major plus. I hate how my Festool guide strips start coming off.
Offline Jalvis
« Reply #18 on: March 22, 2013, 01:24 PM »
Well....wins for some applications.  You can't drill shelf pins with the Domino.
Offline Alan m
« Reply #19 on: March 22, 2013, 02:01 PM »
over all the domino wins but the duo doweler can do the shelf pins.
i used the duo doweler in colage. it was good but i found it a pian to keep aligned properly. a few of the holes were slightly mis aligned. not sure why
they both have a place in the arsenal of tools
i like how you can take off one bit and have only one dowel or put different sized bits on so that the piece can only go together one way
« Reply #20 on: March 23, 2013, 06:53 AM »
Well I think that is because Festool doesn't really make saws for timber framing, Mafell does. Protool would be Festools timber framing/construction brand so to speak.
I didn't know Mafell is so much more expensive in the US. That's too bad.
It seems that Mafell, at least for now simply isn't that interested in finding a bigger market.
Offline GhostFist
« Reply #21 on: March 23, 2013, 08:18 AM »
Festool was a rarer item only a few years back and protool isn't available at all in na. Perhaps being a smaller company still, they dont have the resources for a north American push yet or they simply feel the premium premium market isn't as profitable here yet for power tools. Festool is showing up more and more on job sites  and are really pushing the marketing as of late. With their success I think we'll see more of of the premium brands here in a few years time.
« Reply #22 on: March 24, 2013, 06:02 AM »
I think Mafell still is a family business, for some reason I can imagine they're fine with the size they are. Mind you, I don't think Mafell was that much smaller when I started almost 20 years ago were as Festool, then Festo, clearly was. Even here in Europe you still have to search for a Mafell dealer were Festool has dealers in every town.
Whatever you think of them, they are an interesting brand. Mainly focused on timber framing/construction but then the couple tools they have that can be used in a precision wood shop are very precise indeed. They keep Festool on their toes and vice versa and that is great for all of us.
Seriously, we're a lucky bunch with all the precision tools that exist nowadays. And not even at the cost of hand tools, you mix your Festools and Mafells (Lamellos and Leicas etc) with your Lie-Nielsen, Veritas and what not and you have no more excuses, it sets the bar for a very high quality output. And I would even argue at a very reasonable cost.
Offline Bob Marino
  • Festool Dealer
« Reply #23 on: March 24, 2013, 08:55 AM »
 Interesting discussion. Years ago, there was a collaboration of sorts  between the 2 companies. The Festool OF 2000 router was made (at least in part) by Mafell and Mafell's small router was Festool's OF 1000  router.
  Bob
Former Festool  Dealer since 2002; user well before that!
Offline GhostFist
« Reply #24 on: March 24, 2013, 09:56 AM »
On the subject of Festool and Mafell routers (I know next to nothing of Mafell routers). Swiss company Arunda has had dovetail routing templates for timber framing made specifically for the Mafell router, but are currently in Developement of a template for the OF 2200. Does this suit anyones fancy?
Check it out.... (Note conflicting background music and funny costumes)
Offline Jalvis
« Reply #25 on: March 24, 2013, 01:42 PM »
Thats a great promo video.  Although not exactly costumes......those are signs of great distinction in the Trades.
Once again Bob is making some valid points about competition and the age of artisan tools were all currently in.  The only negative(and Positive) of competition is patents.  Can you image what tools would be made if Festool and Mafell collaborated together?  Each company has some great features that if combined would make the ultimate in tools.
Offline jeep jake
« Reply #26 on: March 24, 2013, 01:46 PM »
depending on the price of the template I would be interested.
Offline Bob Marino
  • Festool Dealer
« Reply #27 on: March 24, 2013, 02:09 PM »
On a similar but lighter note; IIRC and I may be off here,
But about 10 years ago I heard that one of the executives in Festool got married to one of the executives from Fein!
Black/green and orange!
Bob
« Last Edit: March 25, 2013, 08:48 PM by Bob Marino »
Offline GhostFist
« Reply #28 on: March 25, 2013, 06:57 PM »
I didn't even know how much they cost, just that there are templates in development  for the 2200  [big grin]
Online SRSemenza
« Reply #29 on: March 25, 2013, 08:46 PM »
For more on the timber framing jigs see Here
