Author Topic: Festool Edge Bander vs co-matic br500  (Read 2605 times)
Offline Steven Owen
« on: November 01, 2017, 12:18 AM »
How do you feel the Festool Conturo Edge bander compares to other edge banders like the co-matic BR500?
The Festool seems more elegant and the design is more contemporary than many of the competing edge bander models.  Festool seems to be the only one using glue pucks rather than pellets.
The Festool Edge bander also seems be more seemless and can move with greater agility than it’s competitors.  They’re all a huge upgrade over an iron, a heat gun; and a whole lot of swearing when the band doesn’t stay in place.
Festool CT Midi, Festool ETS 125, DF 700 Domino Coming Soon
Offline Timtool
    • My website
Re: Festool Edge Bander vs co-matic br500
« Reply #1 on: November 01, 2017, 04:40 AM »
I have the conturo, but I'm surprised at how well designed the Le-Matic system is. The edge bander itself looks more archaic however, but it seems to do the job. One thing that strikes me though is how far it extends forward under the work piece, while the conturo practically doesn't. Lots of pieces would be too narrow to do freehanded with Le-Matic, looks like their table is indispensable for those. The band cut tool on the table set up is a great feature to streamline work.
However they seem to use the table to set up the trimmers, in reality you have to band two parallel sides of a panel, trim them, and only then is it possible to band the other two sides. You'd need a separate table in reality or do it by hand if you want to avoid switching tools in the table constantly.
The passive vacuum clamps look great, not sure how effective they are on veneer though. And I wonder how the glue pellets work, I suppose the machine has to melt the entire batch, which if comparable to stationary edge banders, could take 20 minutes or much more. And there would be a lengthy pause between refills, and is there a clean up required after each use?
The conturo is more fool proof, heats up quite rapidly and can be used or held at angles without spilling dangerously hot glue. It also tells you on screen how much you can do, and when done you turn it off and let it cool down, no maintenance or clean up.
So I'd say the conturo is the better machine, but Le-Matic has a much more complete and thought-through system built around theirs, since you can probably purchase those separately you could set up the perfect Frankenstein system by taking the best of both.
« Last Edit: November 01, 2017, 04:43 AM by Timtool »
BR10, MFK 700, OS 400, ETS EC 150/3, KA 65-plus,TS55R, CT22E, CTLmini, CTL MIDI, CTM 36 AC HD, Kapex KS120, ETS125, ETS150/5, RO150, RO90, CXS-set, T-15+3 set, DTS400, OF900, OF1010, OF2200 set, Carvex PS420 EBQ set, EHL 65, SSU 200, Centrotec installer set, LR32-sys, FS-800, FS-LR-1400x2, domino 500+domino sys, domino 700 XL, Surfix-sys, Sys-box 1, Syslite, LEV-350, Sys-box,MFTB/1-2-4... MFTC, MFSC
Offline Tim Raleigh
    • Oakville Cabinetry
« Reply #2 on: November 01, 2017, 11:17 AM »
I have not seen this system other than the videos. Not a big fan of Chinese products...I have enough of them.
Wurth also is selling a portable system, it's cheaper than the Festool one
Offline Steven Owen
« Reply #3 on: November 01, 2017, 08:28 PM »
The Festool Conturo appears to be the only true hand held in the group.  The other models seem to rely on being inside a table and lack the ergonomics required to use the Edge bander free hand.
The sticker shock is probably the biggest disadvantage of the Festool Edge bander.
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #4 on: November 01, 2017, 09:44 PM »
Love my Conturo.
Offline Peter Kelly
« Reply #5 on: November 05, 2017, 09:03 AM »
(Attachment Link)
Made in Brasil by Makiswa. I think they also make the hand-held ones that Adwood/Virutex/Felder re-sell.
http://maksiwa.com/produto/coladeira-de-borda-portatil-cbc-e-2
https://www.woodcraft.com/products/maksiwa-portable-edgebander
Offline Tim Raleigh
« Reply #6 on: November 08, 2017, 09:42 AM »
Love my Conturo.
Same, PVC edging is so much better than iron on. Once dialed in works flawlessly even with the thinnest PVC.
Tim
