Michael Garrett
Offline
« on: May 24, 2012, 08:43 PM » |
Is there a Centrotec Ratchet System?
CT 26 HEPA, MFT/3, TS 75 EQ, OF 1400 EQ, DF 500 SET, CXS SET, CENTROTEC INSTALLER SET 98-PC, TRADESMAN/INSTALLER CLEANING SET, DOMINO ASSORTMENT SYSTEM, LR 32 HOLE DRILLING SET, GUIDE RAIL ACCESSORY KIT, GUIDE RAIL FS 1400/2 (2), GUIDE RAIL FS 1900/2 (2), GUIDE RAIL FS 1400/2 LR 32 (1), Veritas MFT Clamping Kit, Zorbo Forstner Bit Set
jacko9
Offline
« Reply #1 on: May 24, 2012, 08:48 PM » |
Is there an onsite video explaining the Centrotec system? I thought about buying the CSX drill but, I'm not sure that I want to re-purchase a lot of drills and bits to get the most out of a tool (meaning the Centrotec advantage).
RonWen
Retailer
Online
« Reply #2 on: May 24, 2012, 08:59 PM » |
<---- <---- <----Yes.
Michael Garrett
Offline
« Reply #3 on: May 24, 2012, 09:05 PM » |
Where can they be purchased?
RonWen
Retailer
Online
« Reply #4 on: May 24, 2012, 09:07 PM » |
NAINA, most anywhere else.
Samo
Offline
« Reply #5 on: May 24, 2012, 11:50 PM » |
Who is going to make a Fasfix to 1/4" hex shank-quick chuck?
SRSemenza
Global Moderator
Offline
« Reply #6 on: May 25, 2012, 12:15 AM » |
Centrotec pros = ..... Very compact quick change chuck on the drill that makes the drill shorter, not an add on quick change that makes the drill longer. ..... It is a real smooth fast quick change. ..... The bit has a longer portion that fits into the chuck and mates directly into the drill shaft. Very stable and smooth running. ..... The Centrotec chuck changes very quickly with the other compatible chucks, and chucks can be changed with bits already in them. ie; The whole chuck quick changes. For instance you could have a drill bit in the Jacobs and a driver in the Centrotec and swap the whole chuck with the same speed as quick changing bits. Cons = ...... The need to buy Centrotec bits to use the Centrotec chuck, but the Jacobs is always there when you need it. ........ Not sure if there are any others , maybe someone else will think of one. Try this video http://festoolownersgroup.com/festool-tool-reviews/review-of-festool-centrotec-chucks/Seth
Festool Service 800-554-8741
jacko9
Offline
« Reply #7 on: May 25, 2012, 12:49 AM » |
Centrotec pros = ..... Very compact quick change chuck on the drill that makes the drill shorter, not an add on quick change that makes the drill longer. ..... It is a real smooth fast quick change. ..... The bit has a longer portion that fits into the chuck and mates directly into the drill shaft. Very stable and smooth running. ..... The Centrotec chuck changes very quickly with the other compatible chucks, and chucks can be changed with bits already in them. ie; The whole chuck quick changes. For instance you could have a drill bit in the Jacobs and a driver in the Centrotec and swap the whole chuck with the same speed as quick changing bits. Cons = ...... The need to buy Centrotec bits to use the Centrotec chuck, but the Jacobs is always there when you need it. ........ Not sure if there are any others , maybe someone else will think of one. Try this video http://festoolownersgroup.com/festool-tool-reviews/review-of-festool-centrotec-chucks/Seth Thanks Seth, Jack
HowardH
Offline
« Reply #8 on: May 26, 2012, 11:12 PM » |
Centrotec is very fast to operate. I can snap bits in and out in the blink of an eye and I don't have spin the toolless chuck to get a bit centered before tightening. It's one of the best parts of having the drill.
Howard H The Plano Texas Festool Fanatic!
Shelby Metcalf, basketball coach at Texas A&M, recounting what he told a player who received four F's and one D: "Son, looks to me like you're spending too much time on one subject."
mft1080, T15, RO150FEQ, TS55, RTS400, ETS 150/3, OF1400, CT22, CT33, MFS 400 & 700, Boom Arm, 800, 1080, 1400, 1900 rails CSX drill Qwas dogs
