Samer
Offline
www.DrSamer.co.nz
« on: April 29, 2012, 04:16 AM » |
Hello everybody,
Do you know the difference between ( Circular saw TS 55 RTS 55 Plus REBQ and Circular saw TS 55 R TS 55 RQ-Plus) ?
Thanks for you Help
Samer.
« Last Edit: April 29, 2012, 04:26 AM by Samer »
Circular saw TS 55 R, Trimming PRECISIO CS 70, Miter saw KAPEX KS 120, Router OF 1010, MFS 700, DOMINO dowel jointer DF 500, Planer HL 850, sander ROTEX RO 150, CLEANTEX CTL 26,
Alex
Offline
« Reply #1 on: April 29, 2012, 04:19 AM » |
Some Festool terminology:
E = Electronics - variable RPM B = Brake - an electronic brake that stops the machine from spinning in a couple of seconds. Q = Quick (release?) - means it has a plug-it cord instead of a permanently attached cord.
Samer
Offline
www.DrSamer.co.nz
« Reply #2 on: April 29, 2012, 04:27 AM » |
THanks alot Alex
Acrobat
Offline
Location: Upper Right, Middle earth Member Since: Jun 2008
« Reply #3 on: May 02, 2012, 10:40 PM » |
So what's the R?
My Festool addiction fed currently by: Kapex 120, TS55R, DF500 & Domino accessories set, Rotex 125, ETS 150/3, DTS400, C12, Ti15 Impact Driver, Midi vac, Surefix Oiling/waxing Kit, OF1010 Router, Kapex 120 Wish List? Carvex420??, Belt sander with frame and planer with frame. Uncle Festool
DKurzweil
Offline
« Reply #4 on: May 03, 2012, 12:48 AM » |
So what's the R?
Re-engineered? (Probably not correct) Just a thought, Daniel
Addiction includes TS75, OF1010, Domino 500, RO150, T-18 set, CSX, LR-32 set, CT48 and CTMidi
Alex
Offline
« Reply #5 on: May 03, 2012, 05:41 AM » |
So what's the R?
Ok, the R, that's a new one and not yet seen beyond the TS 55 R so I'll have to speculate a bit, but if I read the German Festool site they seem to use the word "Randnahe" rather prominently as their big selling point for this new saw, and Randnahe means "near the edge". One of the biggest improvements on this saw is the possibility that it can cut only 12 mm from an edge, so that's what I think the R might stand for. Only speculating though. And before we get that question, TS = Tauchsäge = plunge(-cut) saw.
Kev
Online
« Reply #6 on: May 03, 2012, 06:07 AM » |
"R" is the noise you make when you cut your finger off.
Truly though ... I'm going with Revised.
Alex
Offline
« Reply #7 on: May 03, 2012, 09:47 AM » |
If you're going to speculate, at least try to do it in German, I believe that's what they speak over there.
« Last Edit: May 03, 2012, 10:03 AM by Alex »
