WarnerConstCo.
Offline
« on: June 05, 2012, 11:18 PM » |
I just bought a Festo chain mortiser and a Festo power feeder at an auction today. I don't have any pictures yet, since I got there at 9am this morning and did not get out of there until 9:45 pm. Pictures to follow. Wonder if Shane or Rick would be able to track down any literature on them for me?  Good thing I let my 7 year old take my phone for a while today, she took a picture of it for me.
« Last Edit: June 05, 2012, 11:22 PM by WarnerConstCo. »
Kev
Online
« Reply #1 on: June 06, 2012, 01:50 AM » |
Ah yes, the old Domino. Cool !
WarnerConstCo.
Offline
« Reply #2 on: June 06, 2012, 11:22 PM » |
It is broke down in pieces, there are two parts I will have to take my welder to have repaired. Everything except the main base is aluminum. Main base/frame:  Close up of the chains (have a good lead on a box full of bars and chains)  Guards and grease gun (missing the proprietary tip for the zerks) not sure what the middle guard is for, extending the arbor and bar out for wider stock?  Misc. parts:  Looks like the serial number/badge had been removed, but I found a date on the back of the on/off drum switch box. Says 23 January 1955.  Table/fence assembly. It rotates 45 left and right and has 3 different stops for tilt, with one being 0.  The head section. It is a 2.2hp.
Steve R
Offline
« Reply #3 on: June 06, 2012, 11:49 PM » |
Interesting to see it came with came in systainer back then...  Cheers, Steve
WarnerConstCo.
Offline
« Reply #4 on: June 07, 2012, 12:30 AM » |
Interesting to see it came with came in systainer back then...  Cheers, Steve Yeah, when you open it up, the mortiser pops out.
Kev
Online
« Reply #5 on: June 07, 2012, 05:14 AM » |
What's your intent? Showpiece or runner?
WarnerConstCo.
Offline
« Reply #6 on: June 07, 2012, 10:44 AM » |
It needed a good cleaning and the paint was not in the best shape.
It is a pretty simple machine to break down into components and work on each section.
It will get a thorough cleaning, new paint job (maybe new color scheme) lubed, reassembled and dialed in to run.
I buy this stuff to run them and run them hard.
Kev
Online
« Reply #7 on: June 07, 2012, 10:55 AM » |
Fair enough  I was watching a video of the latest high end Powermatic bandsaw the other day. The fellow describing it was effectively saying they're going back to making machines like they were made many years ago ... heavy, lots of cast iron, stable, accurate, etc. Not all "progress" has been for the better
WarnerConstCo.
Offline
« Reply #8 on: June 09, 2012, 09:39 PM » |
Making a little progress. It is crazy hot and humid which really kills my pace and the paint drying pace. I received an email from a friend, which included the name, address and phone number to the son of the man that first started importing Festo. I was told they still have a building with parts, some machines and literature. Hopefully the table and clamp assembly can be put back together tomorrow and I might have some more time tonight to dive into cleaning up the head of this thing. As of now:
jacko9
Offline
« Reply #9 on: June 09, 2012, 09:52 PM » |
Great find, Looks a lot like the stuff I see on the Old Woodworking Machines.Org web site (owwm.org).
WarnerConstCo.
Offline
« Reply #10 on: June 10, 2012, 12:06 AM » |
Head is apart. Bearings were pretty dry with some caked up grease, need a good cleaning and some new grease. Hopefully I can find the correct tip for the Festo grease gun that came with it.
Kev
Online
« Reply #11 on: June 10, 2012, 12:46 AM » |
Making a little progress. It is crazy hot and humid which really kills my pace and the paint drying pace. I received an email from a friend, which included the name, address and phone number to the son of the man that first started importing Festo. I was told they still have a building with parts, some machines and literature. Hopefully the table and clamp assembly can be put back together tomorrow and I might have some more time tonight to dive into cleaning up the head of this thing. As of now:     That is going to be AWESOME when you've finished. I feel guilt every time I move a couple of Systainers from the boot to the garage ... can't imagine how the better half would react to some serious machinery renovation.
WarnerConstCo.
Offline
« Reply #12 on: June 10, 2012, 03:07 PM » |
Motor is all cleaned out, all old grease has been removed from the bearings and it has been reassembled. Rest of the head has been cleaned and prepped for a coat of primer then paint. I started assembling the fence and a couple other parts.
WarnerConstCo.
Offline
« Reply #13 on: June 11, 2012, 11:22 PM » |
Little more priming, little more paint an assembly work. Even managed to finish up 2 jobs in the shop too.
ScotF
Offline
Location: Southern Orange County, CA, USA Member Since: Jul 2009
« Reply #14 on: June 12, 2012, 12:41 AM » |
Very cool rebuild...thanks for posting the picks and step-by-step....what kind of Systainer does this thing fit in anyway?
Scot
Kev
Online
« Reply #15 on: June 12, 2012, 01:10 AM » |
Scot
A Palletainer
WarnerConstCo.
Offline
« Reply #16 on: June 14, 2012, 10:33 PM » |
Vindingo
Offline
« Reply #17 on: June 14, 2012, 10:46 PM » |
the new festool color scheme is aewsome!
TomGadwa1
Offline
« Reply #18 on: June 14, 2012, 11:45 PM » |
I am not certain about the machine type that you are restoring, but I can say that you are doing a fine job! Anxious to see the end result and the application of this unit!
TS55 EQ OF1400 EQ DFQ 500 Q RO 125 LR32 SET Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
WarnerConstCo.
Offline
« Reply #19 on: June 14, 2012, 11:50 PM » |
It is a Festo PP chain mortiser.
It has a bar and chain, like a chain saw.
It will chew through some large mortises.
Kev
Online
« Reply #20 on: June 14, 2012, 11:58 PM » |
Yeh, it's the Domino 10000XXXXL. The domino assortment is a stock of 2x4 and 6x4 you cut to length.
ScotF
Offline
« Reply #21 on: June 14, 2012, 11:59 PM » |
Love the project and build. When do you think it will be finished? Are you going to shoot some video when you fire it up? Would love to see it in action...
Scot
WarnerConstCo.
Offline
« Reply #22 on: June 15, 2012, 12:05 AM » |
Scot
I was hoping to have it wrapped up this weekend, but I am still waiting to get a couple parts back from my welding shop and I have to make a 6 hour round trip on Saturday, to haul about 10k pounds of machinery home. Oh, there will be a video. I am hoping to get my hands on a box full of bars and chains for it soon too. Only thing I am missing is the correct tip for the Festo grease gun it came with.
ScotF
Offline
« Reply #23 on: June 15, 2012, 12:25 AM » |
Darcy -- I cannot wait. This might be a stupid question, but I would like to know more about your paint process -- is it just spray paint or something that you mix up?
Thanks!
Scot
WarnerConstCo.
Offline
« Reply #24 on: June 15, 2012, 12:34 AM » |
Thanks!
Scot
I had my local mom and pop paint store mix me up some oil based industrial enamel to match my OF1400 I took her. I just use a good quality brush and put on 2 light coats. Assemble parts and touch up as needed. This paint takes a good 24 hours of dry time between coats. I use a wire wheel on a grinder, couple stiff brushes and Acetone to clean stuff up.
ScotF
Offline
« Reply #25 on: June 15, 2012, 12:36 AM » |
Wow -- it does look great...I thought it was sprayed.
Scot
tjbier
Online
« Reply #26 on: June 15, 2012, 05:49 PM » |
Darcy that is looking good, I like the paint scheme too! Can't wait to see the video, good for you on restoring these old irons!!
Tom- ps, I read these.
WarnerConstCo.
Offline
« Reply #27 on: June 29, 2012, 11:39 PM » |
I just got the parts back from my welder that needed repaired. Almost everything is painted or has 1 coat on it. I am trying to decide how I want to paint the logo on the cover, piece with the round Festo logo. I painted it the dark blue and was just going to do the lettering in green, but I got to thinking about using the grey. Then I thought grey background green lettering or green background with grey lettering.
WarnerConstCo.
Offline
« Reply #28 on: June 30, 2012, 08:42 AM » |
For those members in Europe, I am in need of the correct tip for the Festo Grease gun I got with this machine.
If anyone knows where I may be able to find one, I would appreciate it.
Brice Burrell
Online
Remodeling Contractor
« Reply #29 on: June 30, 2012, 11:59 AM » |
I just got the parts back from my welder that needed repaired. Almost everything is painted or has 1 coat on it.I am trying to decide how I want to paint the logo on the cover, piece with the round Festo logo. I painted it the dark blue and was just going to do the lettering in green, but I got to thinking about using the grey. Then I thought grey background green lettering or green background with grey lettering.  Let me guess, it's not bark blue??
