I am hobbyist DIY / woodworker. It all started with a Pro5 sander. I bought the sander, then I needed sandpaper. The sandpaper assortment 40 grit to 280 grit followed. The initial project went well, but a 2mm finish sander doesn't do well removing existing paint or finish from plywood or prefinished furniture.
The $50 voucher was used to buy a 5mm stroke ETS EC150/5 sander. Oh, what a slippery green slope I am on!
So the plan is to use my new ETS EC150/5 sander:
Project 1: To remove multiple layers of peeling paint from a vertical plywood exterior wall. Then use the Pro5 as the finish sander, before repainting with exterior paint.
Project 2: To refinish a dresser by removing the existing finish with the sander. Then manually sand the profiles, and use the Pro5 as the finish sander.
I didn't get a RO150, as it was a bit big and unwieldy for vertical applications.
What grit recommendations would you recommend, given I will be using a 5mm stroke sander? It is not as aggressive as the gear driven Rotex, but it is a brushless 5mm stroke.
My local Festool dealer (Ultimate Tools), was recommending using Mirka Abranet ACE HD abrasives and the Mirka pad saver/interface pad. I would need to manually hole punch additional holes to fix the Festool holes. The Abranet ACE HD sounds like a good idea, since it doesn't clog as much. I probably don't need a full range of grits for the EC150/5, as I can use the Pro5 to finish the sanding. What do you think of using non-Festool sandpaper? A few FOG users seem to have gone this route as well.
Thanks in advance for helping me with my sander addiction....(Hmm....I could sell my Pro5, then buy a ETS EC125/3 with a 150 pad and then I could have two generalized sanders 150mm with 5mm stroke, 150mm with 3mm stroke and a 125mm with 3mm stroke.)
RWW
